path: root/c/src (follow)
* 2002-05-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-144-0/+6
| | | | | | * src/i386/any/remdeb_svc.c, src/m68k/any/remdeb_svc.c, src/powerpc/new_exception_processing/remdeb_svc.c: Per PR220 remove these files from CVS.
* 2001-05-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-093-4/+9
| | | | | * include/i960CA.h, include/i960RP.h: Correct inline assembly forward reference labels.
* 2001-05-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-094-2/+20
| | | | | | | | | | * startup/linkcmds: In support of gcc 3.1, added one of more of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*, .gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections and direction of segments to memory regions may also have been addressed. This was a sweep across all BSPs. * startup/linkcmds.real: Ditto. * clock/ckinit.c: Add volatile to Clock_driver_ticks.
* 2001-05-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-092-5/+20
| | | | | | | * src/exinit.c: Slightly rework initialization so there is a valid thread as _Thread_Executing when the pre_tasking hook is called. This allows one directives and malloc to potentially use mutex protection.
* 2001-05-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-0980-94/+450
* 2002-04-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-016-42/+38
| | | | | | | | | * custom/Makefile.am: Remove. * compilers/Makefile.am: Remove. * compilers/.cvsignore: Remove. * Makefile.am: Merge-in former */Makefile.ams. Add more vars to <BSP>.cache. * configure.ac: Reflect changes above. Cosmetic fixes.
* 2002-05-01 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-05-014-2/+12
| | | | | * machine/in_cksum.h: Per PR200 fix multi-line inline assembly to satisfy gcc 3.1 and newer.
* 2002-05-01 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-05-015-41/+47
| | | | | | * console/console.c, fatal/bspfatal.c, startup/bspclean.c, startup/page_table.c: Per PR200 fix multi-line inline assembly to satisfy gcc 3.1 and newer.
* 2002-04-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-013-0/+69
| | | | | | * rtems/powerpc/cache.h: New file (extracted from old-exceptions/cpu.h) * Makefile.am: Relect changes above.
* 2002-04-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-014-0/+12
| | | | * cpu.c: Include <rtems/powerpc/cache.h>.
* 2002-04-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-013-42/+19
| | | | | | | * rtems/score/ppc.h: Remove rtems_multilib. Add mpc555 (Based on comments from Sergei Organov <osv@javad.ru>). * rtems/old-exceptions/cpu.h: Remove _CPU_Data_Cache_Block_Flush. Remove _CPU_Data_Cache_Block_Invalidate.
* 2002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2002-05-012-2/+9
| | | | | | | * monitor/mon-command.c: Per PR192 the RTEMS monitor makes everything lowercase. The capture engine need to set triggers or watches on task with uppercase names. Also stop the monitor repeating command when enter is pressed.
* 2002-04-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-014-2/+10
| | | | * startup/spurious.c: Use defined(mpc604) instead of defined(ppc604).
* 2001-04-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-272-1/+7
| | | | * src/objectcomparenamestring.c: Fix typos.
* 2001-04-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-264-29/+42
| | | | | | | | | | * include/rtems/score/object.h, inline/rtems/score/object.inl, src/objectcomparenamestring.c: Address PR81 that reworked POSIX message queues to add a descriptor separate from the underlying message queue. This allows non-blocking to follow the "open" not the underlying queue. As part of debugging this it became clear that _Objects_Compare_name_string was broken and a simple version using strncmp() was substituted.
* 2001-04-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-262-13/+36
| | | | | | | * psxmsgq01/init.c: Reflect changes made to address PR81 that reworked POSIX message queues to add a descriptor separate from the underlying message queue. This allows non-blocking to follow the "open" not the underlying queue.
* 2001-04-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-2612-75/+168
| | | | | | | | | | * include/rtems/posix/mqueue.h, inline/rtems/posix/mqueue.inl, src/mqueue.c, src/mqueueclose.c, src/mqueuecreatesupp.c, src/mqueuegetattr.c, src/mqueuenotify.c, src/mqueueopen.c, src/mqueuerecvsupp.c, src/mqueuesendsupp.c, src/mqueuesetattr.c: Per PR81 reworked to add a message queue descriptor separate from the underlying message queue. This allows non-blocking to follow the "open" not the underlying queue.
* 2001-04-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-262-5/+9
| | | | * include/bsp.h: Change SIS to ERC32_BSP.
* 2001-04-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-263-2/+7
| | | | | * libc/gxx_wrappers.c: Fix to keep prototype same as in gcc and remove warning.
* 2002-04-26 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-04-264-8/+26
| | | | | * netinet/in_cksum_i386.c: Add volatile so the more agressive optimization in gcc 3.1 does not reorder things.
* 2001-04-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-222-0/+6
| | | | | * src/task.c (_ITRON_Task_User_extensions): Add new fields to be correct in respect to newly added fields for separate switch list.
* 2001-04-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-192-2/+6
| | | | | * src/powerpc/rdbg_f.c: Always include <rtems.h> instead of internal include files.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-192-3/+6
| | | | * start/start.S: remove targopts.h.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-194-6/+10
| | | | * asm.h: Use cpuopts.h instead of targopts.h.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-192-4/+4
| | | | * rtems/score/hppa.h: Remove rtems/score/targopts.h.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-183-5/+9
| | | | | | * src/powerpc/rdbg_cpu_asm.S: Reflect changes to <rtems/score/cpu.h>. * src/powerpc/rdbg_f.c: Ditto.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-183-2/+10
| | | | * pppd/utils.c: Adapt to gcc-3.x.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-182-4/+7
| | | | | * network/dec21140.c: Reflect changes to powerpc's rtems/score/cpu.h. Use __PPC__ for gcc-3.x compliance.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-1814-337/+36
| | | | | | | | | | | | | | | | | * shared/include/cpu.h: Removed. * shared/include/Makefile.am: Reflect changes above. * shared/include/spr.h: Include rtems/powerpc/registers.h instead of libcpu/cpu.h. * mpc6xx/clock/c_clock.c: Reflect changes to <rtems/score/cpu.h>. * mpc6xx/exceptions/asm_utils.S: Ditto. * mpc6xx/exceptions/raw_exception.c: Ditto. * mpc6xx/mmu/mmuAsm.S: Ditto. * mpc6xx/timer/timer.c: Ditto. * mpc8260/exceptions/asm_utils.S: Ditto. * mpc8260/exceptions/raw_exception.c: Ditto. * mpc8xx/exceptions/asm_utils.S: Ditto. * mpc8xx/exceptions/raw_exception.c: Ditto. * ppc403/vectors/vectors.S: Include <asm.h> instead of "asm.h".
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-188-2202/+22
| | | | | * rtems/score/cpu.h: Removed. * Makefile.am: Reflect changes above.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-1810-17/+28
| | | | | | | | | | | | * bootloader/exception.S: Reflect changes to <rtems/score/cpu.h>. * bootloader/head.S: Ditto. * bootloader/misc.c: Ditto. * console/polled_io.c: Ditto. * irq/irq.c: Ditto. * irq/irq_asm.S: Ditto. * irq/irq_init.c: Include <rtems/bspIo.h>. * start/start.S: Reflect changes to <rtems/score/cpu.h>. * vectors/vectors.S: Ditto.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-182-1/+5
| | | | * vectors/vectors.S: Include <asm.h>.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-183-2/+8
| | | | | * startup/bspstart.c: Include <rtems/bspIo.h>. * vectors/align_h.S: Use <> instead of "" for include files.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-186-8/+15
| | | | | | | | * irq/irq.c: Reflect changes to <rtems/score/cpu.h>. * irq/irq_asm.S: Ditto. * network/network.c: Include <rtems/bspIo.h>. * start/start.S: Include <asm.h> instead of "asm.h". * vectors/vectors.S: Reflect changes to <rtems/score/cpu.h>.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-185-8/+16
| | | | | | | | * irq/irq.c: Reflect changes to <rtems/score/cpu.h>. Fix loopCounter. * irq/irq_asm.S: Reflect changes to <rtems/score/cpu.h>. * vectors/vectors.S: Ditto. * vectors/vectors_init.c: Include <rtems/bspIo.h>.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-185-7/+14
| | | | | | | * irq/irq.c: Reflect changed to <rtems/score/cpu.h>. * irq/irq_asm.S: Ditto. * vectors/vectors.S: Ditto. * vectors/vectors_init.c: Include <rtems/bspIo.h>.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-187-17/+382
| | | | | | | | | | | | * asm.h: Include cpuopts.h instead of targopts.h. * rtems/new-exceptions/cpu.h: Relocated from libbsp/powerpc/support/new_exception_processing/rtems/score/cpu.h * rtems/old-exceptions/cpu.h: Relocated from c/src/lib/libbsp/powerpc/support/old_exception_processing/rtems/score/cpu.h * rtems/powerpc/registers.h: Relocated and renamed from libcpu/powerpc/shared/include/cpu.h. * rtems/score/cpu.h: New. * Makefile.am: Reflect changes above.
* 2002-04-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-181-0/+0
| | | | | | * startup/nulsystbl.c: Fix braces. * startup/Makefile.am: Remove types.h. * startup/types.h: Remove.
* 2002-04-18 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-04-182-6/+14
| | | | | | * rtems/score/cpu.h (CPU_ISR_Disable and CPU_ISR_Enable): Correct them where they correctly inform the compiler about the register they are modifying.
* 2002-04-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-184-43/+12
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-182-15/+5
| | | | * include/rtems/system.h: Remove targopts.h.
* 2001-04-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-173-1/+7
| | | | * shared/include/cpu.h: Added ifndef ASM.
* 2002-04-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-179-0/+19
| | | | | | | | | | | * base_sp/apptask.c: Include <stdlib.h>. * hello/init.c: Ditto. * paranoia/init.c: Ditto. * ticker/tasks.c: Ditto. * unlimited/init.c: Ditto. * unlimited/test1.c: Ditto. * unlimited/test2.c: Ditto. * unlimited/test3.c: Ditto.
* 2002-04-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-173-4/+6
| | | | * libc/scandir.c: Initialize nitems = 0.
* 2002-04-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-172-1/+6
| | | | | * include/rtems/system.h: Add the sparc to the target supporting multlibs.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-171-1/+4
| | | | | | * irq/irq.c: Define loopCounter iff DISPATCH_HANDLER_STAT is set. * startup/bspstart.c: include <bsp/irq.h>, <libcpu/cpuIdent.h>, <rtems/bspIo.h>
* 2001-04-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-171-2/+10
| | | | * ChangeLog: Corrected paths on past few commits.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-172-2/+4
| | | | * shared/include/cpu.h: Don't include cpuIdent.h.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-173-0/+6
| | | | * exceptions/raw_exception.c: Include <libcpu/cpuIdent.h>.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-171-0/+4
