* | Corrected descent to a hardcoded directory and made it dependent on the cpu ↵ | Joel Sherrill | 1997-08-04 | 1 | -1/+1 | |
| | | | | model | |||||
* | Fixed typo and removed duplicated code | Joel Sherrill | 1997-08-04 | 1 | -4/+1 | |
* | First attempt at values for PPC | Joel Sherrill | 1997-08-04 | 3 | -0/+9 | |
* | Trying to support all models | Joel Sherrill | 1997-08-04 | 1 | -20/+4 | |
* | Trying to support all models. | Joel Sherrill | 1997-08-04 | 1 | -0/+6 | |
* | consolex built for all models. | Joel Sherrill | 1997-08-04 | 1 | -8/+4 | |
* | moved header files into the motorola and zilog subdirectories | Joel Sherrill | 1997-08-04 | 8 | -9/+8 | |
* | Correcting difference between mvme162lx and mvme162. All versions have | Joel Sherrill | 1997-08-04 | 1 | -0/+5 | |
| | | | | four serial ports. | |||||
* | moved header files into the motorola and zilog subdirectories | Joel Sherrill | 1997-08-04 | 4 | -5/+7 | |
* | Modified to reflect changes in mc68681.h header file. | Joel Sherrill | 1997-08-04 | 1 | -104/+200 | |
* | Header files moved into zilog subdirectory. | Joel Sherrill | 1997-08-04 | 1 | -2/+2 | |
* | Moved files into the zilog and motorola subdirectories. | Joel Sherrill | 1997-08-04 | 1 | -3/+12 | |
* | Added GNAT configuration parameters. | Joel Sherrill | 1997-08-04 | 2 | -8/+38 | |
* | moved from main include directory | Joel Sherrill | 1997-08-04 | 10 | -0/+956 | |
* | Added these files to contain bodies for routines included in the API | Joel Sherrill | 1997-08-02 | 3 | -1/+102 | |
| | | | | | but which did not have real bodies. This is necessary for languages like Ada95 which must have real entries in a library for bindings. | |||||
* | Added conditional for KA9Q. | Joel Sherrill | 1997-08-01 | 1 | -0/+4 | |
* | Added include of termios.h which was accidentally left out. | Joel Sherrill | 1997-08-01 | 1 | -0/+2 | |
* | Added consolex to wrapup | Joel Sherrill | 1997-08-01 | 1 | -0/+1 | |
* | Corrected typo. | Joel Sherrill | 1997-08-01 | 1 | -1/+1 | |
* | Made to work. | Joel Sherrill | 1997-08-01 | 1 | -1/+1 | |
* | Removed warnings. | Joel Sherrill | 1997-08-01 | 1 | -2/+2 | |
* | Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd. | Joel Sherrill | 1997-08-01 | 16 | -11/+1603 | |
| | | | | | | | (Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers. | |||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 82 | -0/+12476 | |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | |||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 6 | -5/+79 | |
* | Added support for rtems_message_queue_get_number_pending. | Joel Sherrill | 1997-07-31 | 4 | -0/+21 | |
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 6 | -30/+139 | |
* | Added comment to indicate what the commented out C_PIECES indicated. | Joel Sherrill | 1997-07-31 | 1 | -2/+3 | |
* | fixed typo | Joel Sherrill | 1997-07-18 | 2 | -8/+8 | |
* | Reordered specs. | Joel Sherrill | 1997-07-10 | 1 | -4/+4 | |
* | fixed milliseconds and microseconds to tick conversion routines. | Joel Sherrill | 1997-07-10 | 1 | -11/+10 | |
* | Added information on different MVME162 models. | Joel Sherrill | 1997-07-10 | 1 | -0/+11 | |
* | Strip the trace bit from the SR register when dispatching a thread when | Joel Sherrill | 1997-07-10 | 1 | -3/+5 | |
| | | | | | exiting from an ISR. This allows the trace bit to be set on a per task basis and tracing to be limited to that task. | |||||
* | Repository damaged -- file re-added | Joel Sherrill | 1997-07-09 | 3 | -0/+555 | |
* | Repository damaged -- files readded. | Joel Sherrill | 1997-07-09 | 2 | -0/+411 | |
* | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 1997-07-09 | 3 | -3/+3 | |
| | | | | Ada interface where entry is a keyword. | |||||
* | Used macro instead of hard coded number. | Joel Sherrill | 1997-07-09 | 1 | -1/+1 | |
* | Added postswitch extension. | Joel Sherrill | 1997-07-09 | 2 | -0/+4 | |
* | Added post switch extension. | Joel Sherrill | 1997-07-09 | 2 | -0/+10 | |
* | Corrected typos and spacing. | Joel Sherrill | 1997-07-09 | 2 | -6/+6 | |
* | This code was in the tree but not actually being compiled. There | Joel Sherrill | 1997-07-09 | 34 | -140/+140 | |
| | | | | | | | were a number of minor problems which had to be fixed to get it to compile including modifying the compile rule to handle C++ comments, changing the syntax of the include statement, and getting rid of "%" as part of register names. | |||||
* | Added sp, sfc, and fpcsr register defines. | Joel Sherrill | 1997-07-09 | 1 | -0/+4 | |
* | new file | Joel Sherrill | 1997-06-04 | 2 | -0/+90 | |
* | corrected name of test suite | Joel Sherrill | 1997-06-03 | 30 | -30/+30 | |
* | fixed comment | Joel Sherrill | 1997-06-03 | 1 | -1/+1 | |
* | Removed configuration information. | Joel Sherrill | 1997-06-03 | 1 | -54/+0 | |
* | new file | Joel Sherrill | 1997-06-03 | 4 | -0/+181 | |
* | Removed Configuration Information. | Joel Sherrill | 1997-06-03 | 1 | -54/+0 | |
* | new files. | Joel Sherrill | 1997-06-03 | 2 | -0/+89 | |
* | Removed configuration information. | Joel Sherrill | 1997-06-03 | 1 | -42/+0 | |
* | new files | Joel Sherrill | 1997-06-03 | 5 | -0/+362 | |
