* libchip/serial/ns16550.c: Modified
ISR to work with PPC new exception processing
* irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: Added parameter
to irq handler
* clock/ckinit.c, console/console.c, console/ps2_mouse.c,
console/serial_mouse.c, timer/timer.c: Added parameter to irq handler
* network/network.c: Fix warnings.
* GT64260/GT64260TWSI.c, GT64260/GT64260TWSI.h, irq/GT64260Int.c,
network/GT64260eth.c, pci/pci.c, startup/bspclean.c,
startup/reboot.c: Fix warnings.
* clock/clock.c: Fix multiple defined warning
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h,
mpc8260/console-generic/console-generic.c: add parameter to new
exception interrupt handlers in powerpc bsps
PR 779/bsp
* vmeUniverse/vmeUniverse.c: add parameter to new exception interrupt
PR 779/bsp
* irq/irq.c, irq/irq.h, irq/irq_init.c: add parameter to new exception
PR 779/bsp
* irq/irq.c, irq/irq.h, irq/irq_init.c, network/GT64260eth.c: add
parameter to new exception interrupt handlers in powerpc bsps
PR 779/bsp
* clock/p_clock.c, irq/irq.c, irq/irq.h, irq/irq_init.c,
network/network.c: add parameter to new exception interrupt handlers
in powerpc bsps
PR 779/bsp
* irq/irq.c, irq/irq.h: add parameter to new exception
PR 779/bsp
* clock/p_clock.c, console/console.c, console/uart.c, console/uart.h,
powerpc: add parameter to new exception interrupt handlers
* startup/linkcmds: add missing section to link cmds
PR 778/bsps
* include/bsp.h, include/gen2.h, startup/FPGA.c, startup/Hwr_init.c,
startup/bspstart.c, tod/tod.c:
modify SCORE_.. to BSP_.. for externally used define's.
PR 777/bsps
* include/bsp.h: Add a Processor_Synchronize command in bsp.h
* au1x00/.cvsignore: New file.
* include/.cvsignore: Fixed typo.
* network/network.c: Now compiles with GCC 4.0.
* libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_fxp.c: Continue PCI API unification. All use
pci_find_device(). Network drivers manufacture a signature since all
calls have not been converted yet.
* vmeUniverse/README.porting, vmeUniverse/vmeUniverse.c: Continue PCI
API unification. All use pci_find_device().
* pci/pci.c, pci/pci.h, pci/pcifinddevice.c: Continue PCI API
unification. All use pci_find_device(). Also reformat to remove tabs.
* pci/pci.h, pci/pcifinddevice.c: Continue PCI API unification. All use
pci_find_device().
* pci/pcibios.c, pci/pcibios.h: Continue PCI API unification. All use
pci_find_device().
* sh7750/sci/sh4uart.c: Now compiles under gcc 4.x and reformatted.
* startup/init68360.c: Add _RomBase declaration.
* acinclude.m4: Removed vegaplus BSP.
* vegaplus/.cvsignore, vegaplus/ChangeLog, vegaplus/Makefile.am,
vegaplus/bsp_specs, vegaplus/configure.ac, vegaplus/clock/clockdrv.c,
vegaplus/include/.cvsignore, vegaplus/include/bsp.h,
vegaplus/include/registers.h, vegaplus/include/tm27.h,
vegaplus/irq/bsp_irq_asm.S, vegaplus/irq/bsp_irq_init.c,
vegaplus/irq/irq.c, vegaplus/irq/irq.h, vegaplus/start/start.S,
vegaplus/startup/bspstart.c, vegaplus/startup/exit.c,
vegaplus/startup/linkcmds: Removed.
* acinclude.m4: Added gp32 BSP.
* gp32/.cvsignore, gp32/Makefile.am, gp32/README, gp32/bsp_specs,
gp32/configure.ac, gp32/console/.cvsignore, gp32/console/conio.c,
gp32/console/console.c, gp32/console/defaultfont.c,
gp32/include/.cvsignore, gp32/include/bsp.h, gp32/include/conio.h,
gp32/include/tm27.h, gp32/start/.cvsignore, gp32/start/start.S,
gp32/startup/.cvsignore, gp32/startup/bspstart.c,
gp32/startup/exit.c, gp32/startup/linkcmds, gp32/startup/memmap.c: New files.
* Makefile.am, configure.ac: Added gp32 BSP.
* s3c2400/.cvsignore, s3c2400/Makefile.am, s3c2400/clock/clockdrv.c,
s3c2400/include/s3c2400.h, s3c2400/irq/bsp_irq_asm.S,
s3c2400/irq/bsp_irq_init.c, s3c2400/irq/irq.c, s3c2400/irq/irq.h,
s3c2400/timer/timer.c: New files.
noted in "Device Errata MCF5282DE", Rev. 1.7, 09/2004.
* mc9328mxl/irq/irq.h: Fixed error in declaration of bsp_vector_table.
* Makefile.am: Add timerstub so more tests link.
* startup/linkcmds: Hacked so there is enough memory to link pppd.exe.
* .cvsignore, ChangeLog, include/.cvsignore: New files.
* libchip/network/dec21140.c, libchip/network/if_fxp.c: Make PCI
initialize function part of the unified PCI API as pci_initialize().
* vmeUniverse/README.porting, vmeUniverse/vmeUniverse.c: Make PCI
* pci/pci.c, pci/pcifinddevice.c, startup/bspstart.c: Make PCI
* include/bsp.h, pci/pci.c, startup/bspstart.c: Make PCI initialize
* pci/pci.c, pci/pci.h, startup/bspstart.c: Make PCI initialize
* shared/pci/pcibios.c, shared/pci/pcibios.h: Make PCI initialize
* acinclude.m4: Remove arm_bare_bsp.
PR bsps/771
* configure.ac: Remove reference to arm_bare_bsp in
AC_CONFIG_SRCDIR. Use ../arm instead.
PR bsps/771
