path: root/c/src (follow)
* Corrected to include shared console driver.Joel Sherrill1999-05-281-1/+1
* At the request of Gumby, the cpu is now halted rather than spinningJoel Sherrill1999-05-281-1/+1
| | | | on a fatal exception.
* Renamed config.c to conscfg.c to avoid naming conflicts.Joel Sherrill1999-05-282-284/+1
* Renamed config.s to todcfg.c to avoid naming conflicts.Joel Sherrill1999-05-282-80/+1
* Renamed fatal.c to bspfatal.c to avoid name conflicts withJoel Sherrill1999-05-282-128/+1
| | | | Fatal Error handler in SuperCore.
* Renamed tod.c to coretod.c to remove conflicts with "Time Of Day"Joel Sherrill1999-05-282-240/+2
| | | | device drivers.
* Renamed clock.c to rtclock.c to avoid conflicts with clock driversJoel Sherrill1999-05-282-24/+1
| | | | in various BSPs.
* Switched from picking up the .rel for each subdirectory in theJoel Sherrill1999-05-2733-33/+33
| | | | | BSP (BSP_PIECES) to picking up the .o files. This should help reduce the minimum size of an application.
* Patch from Eric Norum <eric@pollux.usask.ca> to eliminate a panic when theJoel Sherrill1999-05-279-441/+264
| | | | network stack runs out of mbufs.
* Split out the routine rtems_assoc_name_bad().Joel Sherrill1999-05-2710-58/+166
* Removed usage of printf.Joel Sherrill1999-05-275-5/+5
* Split initialization and reserve resources from termios to reduceJoel Sherrill1999-05-277-119/+188
| | | | size of mininum application.
* Split out polled io, debug puts, and console reserve resources toJoel Sherrill1999-05-274-83/+146
| | | | reduce dependencies and shrink minimum executable size.
* Disabled running size_rtems until all file splitting is finished.Joel Sherrill1999-05-271-1/+1
* Regenerated.Joel Sherrill1999-05-2712-947/+1693
* Corrected so rtems.o is built and installed on all targets.Joel Sherrill1999-05-2710-31/+20
* Corrected macro names.Joel Sherrill1999-05-271-2/+6
* Initiated updating this to reflect split up.Joel Sherrill1999-05-261-2/+4
* Renamed to rtemstimer.c to avoid conflict with timer drivers in EVERYJoel Sherrill1999-05-202-53/+2
| | | | BSP as we transition to more .o's and less .rel's.
* Removed all post 4.0 changes.Joel Sherrill1999-05-203-243/+234
* Patch from Daniel Kelley <dank@icube.com>:Joel Sherrill1999-05-182-8/+8
| | | | | | I found a small buglet in the mips64orion _CPU_ISR_Set_level; the original was wiping out the level argument, and then comparing the current interrupt level with some random value of v0. See patch below.
* Regenerated.Joel Sherrill1999-05-1814-1695/+949
* Spacing correction.Joel Sherrill1999-05-181-1/+0
* Reworked to avoid pulling in the jump point entry in EVERY executable.Joel Sherrill1999-05-1711-19/+50
* Fixed some typos.Joel Sherrill1999-05-171-4/+4
* Split Interrupt Manager into one routine per file.Joel Sherrill1999-05-173-41/+63
* Split Signal Manager into one routine per file.Joel Sherrill1999-05-174-109/+158
* Dual-Ported Memory Manager split into one routine per file.Joel Sherrill1999-05-177-237/+351
* Split Partition Manager into one routine per file.Joel Sherrill1999-05-177-307/+429
* Split Timer Manager into one routine per file.Joel Sherrill1999-05-1710-618/+475
* Split Event Manager into one routine per file.Joel Sherrill1999-05-177-343/+460
* Split Rate Monotonic Manager into one routine per file.Joel Sherrill1999-05-179-417/+573
* Split the Semaphore Manager into one routine per file.Joel Sherrill1999-05-178-485/+771
* Moved some MP routines to semmp.c.Joel Sherrill1999-05-172-55/+54
* Forgot to actually remove the routines. :)Joel Sherrill1999-05-171-748/+0
* Split Message Manager into one routine per file.Joel Sherrill1999-05-1713-1/+1112
* Moved an MP routine from msg.c to here.Joel Sherrill1999-05-171-0/+26
* Cleaned up some multiprocessing issues.Joel Sherrill1999-05-171-17/+15
* Split Clock Manager into one routine per file.Joel Sherrill1999-05-176-259/+199
* Split Region Manager into one routine per file.Joel Sherrill1999-05-179-456/+623
* Splitting the Thread Handler forced the inclusion of more prototypes.Joel Sherrill1999-05-171-0/+33
* Moved _Entry_Table to its own file to avoid having every RTEMS directiveJoel Sherrill1999-05-173-95/+107
| | | | pulled in.
* Added simple test to find minimum code size of executive with this BSPJoel Sherrill1999-05-175-1/+125
| | | | and RTEMS configuration.
* Split Task Manager into multiple files. Eventually this effort willJoel Sherrill1999-05-1716-962/+1387
| | | | reduce the size of executables.
* Thread Handler split into multiple files. Eventually, as RTEMS isJoel Sherrill1999-05-1726-1305/+1990
| | | | split into one function per file, this will decrease the size of executables.
* Patch from D. V. Henkel-Wallace <gumby@zembu.com> to remove compilerJoel Sherrill1999-05-179-12/+12
| | | | warnings.
* Patch from D. V. Henkel-Wallace <gumby@zembu.com>:Joel Sherrill1999-05-171-0/+16
| | | | | | Here's a tiny patch that shreds memory returned to the pool (such as by free() and delete). This may help people find some nasty bugs, so here it is.
* Added testing for C++ exceptions from Rosimildo DaSilvaJoel Sherrill1999-05-141-17/+90
| | | | <rdasilva@connecttel.com>.
* Added 3COM 3C509 driver from Rosimildo DaSilva <rdasilva@connecttel.com>.Joel Sherrill1999-05-147-2/+2247
* Enabled compilation of rtems_servers at request of Jake JanovetzJoel Sherrill1999-05-148-12/+16
| | | | <janovetz@tempest.ece.uiuc.edu>.
