* make/custom/lpc24xx.cfg: New (relocated from /make/custom).
* make/custom/lpc24xx_ea.cfg: New (relocated from /make/custom).
* make/custom/lpc24xx_ncs_ram.cfg: New (relocated from /make/custom).
* make/custom/lpc24xx_ncs_rom_ext.cfg: New (relocated from /make/custom).
* make/custom/lpc24xx_ncs_rom_int.cfg: New (relocated from /make/custom).
* make/custom/gumstix.cfg: New (relocated from /make/custom).
* make/custom/gp32.cfg: New (relocated from /make/custom).
* make/custom/arm1136jfs.cfg: New (relocated from /make/custom).
* make/custom/arm1136js.cfg: New (relocated from /make/custom).
* make/custom/arm7tdmi.cfg: New (relocated from /make/custom).
* make/custom/arm920.cfg: New (relocated from /make/custom).
* make/custom/armcortexa9.cfg: New (relocated from /make/custom).
* make/custom/gba.cfg: New (relocated from /make/custom).
* make/custom/edb7312.cfg: New (relocated from /make/custom).
* make/custom/csb337.cfg: New (relocated from /make/custom).
* make/custom/csb637.cfg: New (relocated from /make/custom).
* make/custom/csb336.cfg: New (relocated from /make/custom).
* make/custom/rbtx4938.cfg: New (relocated from /make/custom).
* make/custom/rbtx4925.cfg: New (relocated from /make/custom).
* make/custom/jmr3904.cfg: New (relocated from /make/custom).
* make/custom/hurricane.cfg: New (relocated from /make/custom).
* make/custom/genmongoosev.cfg: New (relocated from /make/custom).
* make/custom/csb350.cfg: New (relocated from /make/custom).
* make/custom/m32csim.cfg: New (relocated from /make/custom).
* make/custom/m32rsim.cfg: New (relocated from /make/custom).
* make/custom/lm32_evr.cfg: New (relocated from /make/custom).
* make/custom/icecube.cfg, make/custom/pm520_cr825.cfg,
make/custom/pm520_ze30.cfg:
* make/custom/hsc_cm01.cfg, make/custom/mpc8313erdb.cfg
make/custom/mpc8349eamds.cfg:
* ne2000/ne2000.c: Add --ne2k-irq and --ne2k-port boot command
line configure options.
* ide/ide.c: Fix a bug which left 4 words in the buffer of the
disk. Some devices do not follow the standard and terminate the
command which a new command occurs and/or low data ready when data
is still to be read.
* make/custom/eZKit533.cfg: New (relocated from /make/custom).
* make/custom/bf537Stamp.cfg: New (relocated from /make/custom).
* make/custom/brs5l.cfg: New (relocated from /make/custom).
* make/custom/h8sim.cfg: New (relocated from /make/custom).
* make/custom/h8sxsim.cfg: New (relocated from /make/custom).
* make/custom/c3xsim.cfg: New (relocated from /make/custom).
* make/custom/c4xsim.cfg: New (relocated from /make/custom).
* make/custom/pghplus.cfg: New (relocated from /make/custom).
* make/custom/tqm8xx.cfg: New (relocated from /make/custom).
* make/custom/tqm8xx_stk8xx.cfg: New (relocated from /make/custom).
* make/custom/ss555.cfg: New (relocated from /make/custom).
* make/custom/score603e.cfg: New (relocated from /make/custom).
* make/custom/qemuppc.cfg: New (relocated from /make/custom).
* make/custom/psim.cfg: New (relocated from /make/custom).
* make/custom/mvme5500.cfg: New (relocated from /make/custom).
* make/custom/mvme3100.cfg: New (relocated from /make/custom).
* make/custom/mpc8260ads.cfg: New (relocated from /make/custom).
* make/custom/mpc5566evb.cfg: New (relocated from /make/custom).
* make/custom/mpc55xx.cfg: New (relocated from /make/custom).
* make/custom/mcp750.cfg: New (relocated from /make/custom).
* make/custom/mtx603e.cfg: New (relocated from /make/custom).
* make/custom/mvme2100.cfg: New (relocated from /make/custom).
* make/custom/mvme2307.cfg: New (relocated from /make/custom).
* make/custom/mbx821_001.cfg: New (relocated from /make/custom).
* make/custom/mbx821_002b.cfg: New (relocated from /make/custom).
* make/custom/mbx821_002.cfg: New (relocated from /make/custom).
* make/custom/mbx860_001b.cfg: New (relocated from /make/custom).
* make/custom/mbx860_002.cfg: New (relocated from /make/custom).
* make/custom/mbx860_005b.cfg: New (relocated from /make/custom).
* make/custom/mbx860_1b.cfg: New (relocated from /make/custom).
* make/custom/mbx8xx.cfg: New (relocated from /make/custom).
* make/custom/haleakala.cfg: New (relocated from /make/custom).
* make/custom/gen83xx.cfg: New (relocated from /make/custom).
* make/custom/gen5200.cfg: New (relocated from /make/custom).
* make/custom/ep1a.cfg: New (relocated from /make/custom).
* make/custom/virtex.cfg: New (relocated from /make/custom).
* make/custom/nios2_iss.cfg: New (relocated from /make/custom).
* make/custom/leon3.cfg: New (relocated from /make/custom).
* make/custom/leon2.cfg: New (relocated from /make/custom).
* make/custom/erc32.cfg: New (relocated from /make/custom).
* make/custom/sis.cfg: New (relocated from /make/custom).
* make/custom/avrtest.cfg: New (relocated from /make/custom).
* make/custom/ts_386ex.cfg: New (relocated from /make/custom).
