path: root/c/src (follow)
* 2002-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-131-77/+2
| | | | | | | | * Part of addressing PR281. * main.cfg: Added recognition of VARIANT=DEBUG on command line. * compilers/gcc-target-default.cfg: Removed remaining support for RTEMS_USE_GCC272 and RTEMS_LIBC_DIR as well as added -qrtems_debug as one of the LDFLAGS when the debug variant is specified.
* 2002-09-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-09-082-1/+4
| | | | * configure.ac: Remove duplicate timer/Makefile in AC_CONFIG_FILES.
* 2002-09-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-09-084-3/+8
* 2002-09-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-09-082-1/+5
| | | | * Makefile.am: Don't use RTEMS_TOPdir in ACLOCAL_AMFLAGS.
| | | | * Makefile.am: ACLOCAL_AMFLAGS = -I ../../../../../../aclocal.
| | | | * configure.ac: Remove duplicate mpc6xx/timer/Makefile from CONFIG_FILES.
| | | | * configure.ac: Remove duplicate timer/Makefile from CONFIG_FILES.
* 2002-09-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-072-1/+6
| | | | | * clock/clock.c: Disabled use of fast idle since it seems broken with gcc 3.2.
* 2002-09-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-072-0/+42
| | | | * samples/base_mp/config.h: New file previously missed.
* 2002-09-07 Chris Johns <ccj@acm.org>Joel Sherrill2002-09-076-195/+1437
| | | | | | | | | * network/Makefile.am, network/README.cs8900, network/cs8900.c, network/cs8900.h: Significant update which corrects the problem where the cs8900.c file was actually the BSP glue. Joel did some hacking so this file will compile. Previously it required providing a target.h file to compile. * network/cs8900.c.bsp: New file.
* 2002-09-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-073-0/+7
| | | | | * pppd/ipcp.c, rtems_servers/ftpd.c: Add include files to resolve warnings.
* 2002-09-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-09-062-2/+9
| | | | | * Makefile.inc.in: Comment out RTEMS_USE_GCC272. Comment out RTEMS_LIBC_DIR.
* 2002-09-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-0337-1404/+44
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * base_mp now builds and can be considered a bit of an example for the other mptests. * mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, samples/base_mp/mptest.adb, samples/base_mp/mptest.ads, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am: Modified to make compile. * mptests/mp01/node1/mptest-per_node_configuration.adb, mptests/mp01/node2/mptest-per_node_configuration.adb, mptests/mp02/node1/mptest-per_node_configuration.adb, mptests/mp02/node2/mptest-per_node_configuration.adb, mptests/mp03/node1/mptest-per_node_configuration.adb, mptests/mp03/node2/mptest-per_node_configuration.adb, mptests/mp04/node1/mptest-per_node_configuration.adb, mptests/mp04/node2/mptest-per_node_configuration.adb, mptests/mp05/node1/mptest-per_node_configuration.adb, mptests/mp05/node2/mptest-per_node_configuration.adb, mptests/mp06/node1/mptest-per_node_configuration.adb, mptests/mp06/node2/mptest-per_node_configuration.adb, mptests/mp07/node1/mptest-per_node_configuration.adb, mptests/mp07/node2/mptest-per_node_configuration.adb, mptests/mp08/node1/mptest-per_node_configuration.adb, mptests/mp08/node2/mptest-per_node_configuration.adb, mptests/mp09/node1/mptest-per_node_configuration.adb, mptests/mp09/node2/mptest-per_node_configuration.adb, mptests/mp10/node1/mptest-per_node_configuration.adb, mptests/mp10/node2/mptest-per_node_configuration.adb, mptests/mp11/node1/mptest-per_node_configuration.adb, mptests/mp11/node2/mptest-per_node_configuration.adb, mptests/mp12/node1/mptest-per_node_configuration.adb, mptests/mp12/node2/mptest-per_node_configuration.adb, mptests/mp13/node1/mptest-per_node_configuration.adb, mptests/mp13/node2/mptest-per_node_configuration.adb, mptests/mp14/node1/mptest-per_node_configuration.adb, mptests/mp14/node2/mptest-per_node_configuration.adb, samples/base_mp/node1/mptest-per_node_configuration.adb, samples/base_mp/node2/mptest-per_node_configuration.adb: Removed as this information should come from config.h.
* 2002-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-09-022-1/+5
| | | | * rtems_webserver/md5.h: Add missing newline.
* 2002-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-09-022-0/+7
| | | | | * mpc8260/exceptions/raw_exception.c: #include <string.h>. #include <bspIo.h>.
* 2002-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-09-022-0/+6
| | | | * pci/pcibios.c: #include <string.h>.
* 2002-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-09-0231-0/+93
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mptests/mp01/node1/.cvsignore: New. * mptests/mp01/node2/.cvsignore: New. * mptests/mp02/node1/.cvsignore: New. * mptests/mp02/node2/.cvsignore: New. * mptests/mp03/node1/.cvsignore: New. * mptests/mp03/node2/.cvsignore: New. * mptests/mp04/node1/.cvsignore: New. * mptests/mp04/node2/.cvsignore: New. * mptests/mp05/node1/.cvsignore: New. * mptests/mp05/node2/.cvsignore: New. * mptests/mp06/node1/.cvsignore: New. * mptests/mp06/node2/.cvsignore: New. * mptests/mp07/node1/.cvsignore: New. * mptests/mp07/node2/.cvsignore: New. * mptests/mp08/node1/.cvsignore: New. * mptests/mp08/node2/.cvsignore: New. * mptests/mp09/node1/.cvsignore: New. * mptests/mp09/node2/.cvsignore: New. * mptests/mp10/node1/.cvsignore: New. * mptests/mp10/node2/.cvsignore: New. * mptests/mp11/node1/.cvsignore: New. * mptests/mp11/node2/.cvsignore: New. * mptests/mp12/node1/.cvsignore: New. * mptests/mp12/node2/.cvsignore: New. * mptests/mp13/node1/.cvsignore: New. * mptests/mp13/node2/.cvsignore: New. * mptests/mp14/node1/.cvsignore: New. * mptests/mp14/node2/.cvsignore: New. * samples/base_mp/node1/.cvsignore: New. * samples/base_mp/node2/.cvsignore: New.
* 2002-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-09-029-15/+157
| | | | | | | | | | | * mptests/Makefile.am: New. * mptests/mp01/Makefile.am: New. * mptests/mp01/node1/Makefile.am: New. * mptests/mp01/node2/Makefile.am: New. * samples/base_mp/Makefile.am: Comment out building mptest$(EXEEXT). * samples/base_mp/node1/Makefile.am: New. * samples/base_mp/node2/Makefile.am: New. * configure.ac: Add mptests/mp01. Add samples/base_mp.
* 2002-08-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-312-1/+5
| | | | * rtems_webserver/webmain.c: Commented out rootWeb to eliminate warning.
* 2002-08-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-303-3/+7
| | | | | * shell/shell.c: #include <time.h> * wrapup/Makefile.am: Eliminate LIBNAME.
* 2002-08-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-302-8/+4
| | | | * tmtests/tm20/Makefile.am: Remove EXPADA.
* 2002-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-302-1/+4
| | | | * samples/base_mp/mptest.ads: Removed lingering reference to BSP_MPCI.
* 2002-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-302-11/+6
| | | | * rtems.adb (IO_Initialize): Make this match the C prototype.
* 2002-08-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-295-0/+12
| | | | | | | | * console/Makefile.am: Add $(PROJECT_INCLUDE)/rtems to PREINSTALL_FILES. * console/mouse_parser.c: Include <string.h> (for strcmp). * console/vt.c: Include <string.h> (for memcpy). * wd8003/wd8003.c: Include <string.h> (for memcpy, memset).
* 2002-08-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-281-0/+4
| | | | * samples/base_mp/.cvsignore: New file.
* 2002-08-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-282-0/+13
| | | | * configure.ac: Add ada-tests.
* 2002-08-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-271-0/+2
* 2002-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-278-22/+16
| | | | | | | | | | * sptests/sp09/Makefile.am: Remove EXPADA. * sptests/sp09/sptest.adb: Remove RESULT from SCREEN_13. * sptests/sp19/Makefile.am: Remove EXPADA. * sptests/sp21/Makefile.am: Remove EXPADA. * sptests/sp21/sptest.adb: Remove RESULT from TASK_1. * tmtests/tmoverhd/dummy_rtems.adb: Reflect changes to IO_Managers. * tmtests/tmoverhd/dummy_rtems.ads: Reflect changes to IO_Managers.
* 2002-08-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-273-9/+5
| | | | | * tmtests/tm20/tmtest.adb, tmtests/tmoverhd/tmtest.adb: Fixed call to RTEMS IO Manager services.
* 2002-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-272-2/+6
| | | | * sptests/sp19/sptest.adp: Fix include paths.
* 2002-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-273-53/+13
| | | | | | * sptests/sp19/sptest.adb: Remove. * sptests/sp19/Makefile.am: Let m4 generate sptests.adb from sptests.adp.
* 2002-08-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-272-2/+5
| | | | * rtems.ads: Corrected binding for Io_Initialize.
| | | | | * sptests/sp21/sptest.adb: Fixed IO_Initialize invocations to match corrected prototype.
* 2002-08-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-272-0/+404
| | | | * sptests/sp19/sptest.adp: Added from old Ada implementation.
* 2002-08-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-272-2/+4
| | | | * tmtests/tm27/.cvsignore: Removed. Missed in previous attempts.
* RemovedRalf Corsepius2002-08-271-2/+0
* 2002-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-276-17/+23
| | | | | | | | | * sptests/sp09/sptest.adb: Add Result to SCREEN_13. Remove Status from TASK_1. * sptests/sp21/sptest.adb: Add Result to TASK_1. * tmtests/tm20/tmtest.adb: Remove various RETURN_VALUEs. * ada.am: Remove ADACOMPILE, ADAC. Add AM_LDFLAGS, LDFLAGS. * configure.ac: Check for m4. Abort if HAS_GNAT = no.
* 2002-08-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-263-73/+5
| | | | | * tm27 and tm27 are irrelevant as Ada binding tests. * tmtests/tm26/config.h, tmtests/tm26/config.h: Removed.
* 2002-08-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-2614-2054/+6
| | | | | | | | | | * tm27 and tm27 are irrelevant as Ada binding tests. * tmtests/tm26/Makefile.am, tmtests/tm26/README, tmtests/tm26/tm26.adb, tmtests/tm26/tmtest.adb, tmtests/tm26/tmtest.adp, tmtests/tm26/tmtest.ads, tmtests/tm27/Makefile.am, tmtests/tm27/README, tmtests/tm27/tm27.adb, tmtests/tm27/tmtest.adb, tmtests/tm27/tmtest.ads: Removed. * configure.ac, tmtests/Makefile.am: Modified to reflect above.
* 2002-08-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-263-29/+85
| | | | | | * sptests/sp19/sptest.adb: Modified to follow pattern of SP01 even though this test is not supported. * sptests/sp19/sp19.adb: New file.
* 2002-08-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-2616-16/+16
| | | | | | | | | | | | * mptests/mp01/mptest.ads, mptests/mp02/mptest.ads, mptests/mp03/mptest.ads, mptests/mp04/mptest.ads, mptests/mp05/mptest.ads, mptests/mp06/mptest.ads, mptests/mp07/mptest.ads, mptests/mp08/mptest.ads, mptests/mp09/mptest.ads, mptests/mp10/mptest.ads, mptests/mp11/mptest.ads, mptests/mp12/mptest.ads, mptests/mp13/mptest.ads, mptests/mp14/mptest.adb, mptests/mp14/mptest.ads: Per PR274, identify the need for the BSP_MPCI package. It was a trivial dependency and eliminated.
* 2002-08-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-262-0/+5
| | | | | * sptests/sp19/sp19.adb: Removed/Renamed to sptest.adb. * sptests/sp19/sptest.adb: Added/Renamed from sptest.adb.
* 2002-08-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-262-22/+0
| | | | | * sptests/sp09/sptest.adb, sptests/sp21/sptest.adb: All RTEMS IO Manager directives take fewer arguments than these tests used.
* 2002-08-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-262-1/+7
| | | | | * startup/linkcmds: Move .init section after text section so C+ global constructors work.
* 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-262-1/+5
| | | | * sptests/sp04/Makefile.am: Remove init.$(OBJEXT).
* 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-2627-36/+114
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am: Activate tmtests. * configure.ac: Activate tmtests. * samples/base_mp/Makefile.am: Add nodeX subdirs. * sptests/sp01/Makefile.am: Add *.scn. * sptests/sp02/Makefile.am: Add *.scn. * sptests/sp03/Makefile.am: Add *.scn. * sptests/sp04/Makefile.am: Add *.scn. * sptests/sp05/Makefile.am: Add *.scn. * sptests/sp06/Makefile.am: Add *.scn. * sptests/sp07/Makefile.am: Add *.scn. * sptests/sp08/Makefile.am: Add *.scn. * sptests/sp09/Makefile.am: Add *.scn. * sptests/sp11/Makefile.am: Add *.scn. * sptests/sp12/Makefile.am: Add *.scn. * sptests/sp13/Makefile.am: Add *.scn. * sptests/sp14/Makefile.am: Add *.scn. * sptests/sp15/Makefile.am: Add *.scn. * sptests/sp16/Makefile.am: Add *.scn. * sptests/sp17/Makefile.am: Add *.scn. * sptests/sp19/Makefile.am: Add *.scn. * sptests/sp20/Makefile.am: Add *.scn. * sptests/sp21/Makefile.am: Add *.scn. * sptests/sp22/Makefile.am: Add *.scn. * sptests/sp23/Makefile.am: Add *.scn. * sptests/sp24/Makefile.am: Add *.scn. * sptests/sp25/Makefile.am: Add *.scn.
* 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-2634-0/+1196
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tmtests/Makefile.am: New. * tmtests/tm01/Makefile.am: New. * tmtests/tm02/Makefile.am: New. * tmtests/tm03/Makefile.am: New. * tmtests/tm04/Makefile.am: New. * tmtests/tm05/Makefile.am: New. * tmtests/tm06/Makefile.am: New. * tmtests/tm07/Makefile.am: New. * tmtests/tm08/Makefile.am: New. * tmtests/tm09/Makefile.am: New. * tmtests/tm10/Makefile.am: New. * tmtests/tm11/Makefile.am: New. * tmtests/tm12/Makefile.am: New. * tmtests/tm13/Makefile.am: New. * tmtests/tm14/Makefile.am: New. * tmtests/tm15/Makefile.am: New. * tmtests/tm16/Makefile.am: New. * tmtests/tm17/Makefile.am: New. * tmtests/tm18/Makefile.am: New. * tmtests/tm19/Makefile.am: New. * tmtests/tm20/Makefile.am: New. * tmtests/tm21/Makefile.am: New. * tmtests/tm22/Makefile.am: New. * tmtests/tm23/Makefile.am: New. * tmtests/tm24/Makefile.am: New. * tmtests/tm25/Makefile.am: New. * tmtests/tm26/Makefile.am: New. * tmtests/tm26/tmtest.adb * tmtests/tm27/Makefile.am: New. * tmtests/tm28/Makefile.am: New. * tmtests/tm29/Makefile.am: New. * tmtests/tmck/Makefile.am: New. * tmtests/tmoverhd/Makefile.am: New.
* 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-2610-0/+263
| | | | | | | | | | | | * Makefile.am: New. * configure.ac: New. * ada.am: New. * support/Makefile.am: New. * samples/Makefile.am: New. * samples/base_mp/Makefile.am: New. * samples/base_sp/Makefile.am: New. * samples/hello/Makefile.am: New. * samples/ticker/Makefile.am: New.
* 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-2626-0/+438
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * sptests/Makefile.am: New. * sptests/sp01/Makefile.am: New. * sptests/sp02/Makefile.am: New. * sptests/sp03/Makefile.am: New. * sptests/sp04/Makefile.am: New. * sptests/sp05/Makefile.am: New. * sptests/sp06/Makefile.am: New. * sptests/sp07/Makefile.am: New. * sptests/sp08/Makefile.am: New. * sptests/sp09/Makefile.am: New. * sptests/sp11/Makefile.am: New. * sptests/sp12/Makefile.am: New. * sptests/sp13/Makefile.am: New. * sptests/sp14/Makefile.am: New. * sptests/sp15/Makefile.am: New. * sptests/sp16/Makefile.am: New. * sptests/sp17/Makefile.am: New. * sptests/sp19/Makefile.am: New. * sptests/sp20/Makefile.am: New. * sptests/sp21/Makefile.am: New. * sptests/sp22/Makefile.am: New. * sptests/sp23/Makefile.am: New. * sptests/sp24/Makefile.am: New. * sptests/sp25/Makefile.am: New. * sptests/spsize/Makefile.am: New.
* 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-2679-0/+240
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ChangeLog: New. * .cvsignore: New. * mptests/.cvsignore: New. * mptests/mp01/.cvsignore: New. * mptests/mp02/.cvsignore: New. * mptests/mp03/.cvsignore: New. * mptests/mp04/.cvsignore: New. * mptests/mp05/.cvsignore: New. * mptests/mp06/.cvsignore: New. * mptests/mp07/.cvsignore: New. * mptests/mp08/.cvsignore: New. * mptests/mp09/.cvsignore: New. * mptests/mp10/.cvsignore: New. * mptests/mp11/.cvsignore: New. * mptests/mp12/.cvsignore: New. * mptests/mp13/.cvsignore: New. * mptests/mp14/.cvsignore: New. * samples/.cvsignore: New. * samples/base_sp/.cvsignore: New. * samples/hello/.cvsignore: New. * samples/ticker/.cvsignore: New. * sptests/.cvsignore: New. * sptests/sp01/.cvsignore: New. * sptests/sp02/.cvsignore: New. * sptests/sp03/.cvsignore: New. * sptests/sp04/.cvsignore: New. * sptests/sp05/.cvsignore: New. * sptests/sp06/.cvsignore: New. * sptests/sp07/.cvsignore: New. * sptests/sp08/.cvsignore: New. * sptests/sp09/.cvsignore: New. * sptests/sp11/.cvsignore: New. * sptests/sp12/.cvsignore: New. * sptests/sp13/.cvsignore: New. * sptests/sp14/.cvsignore: New. * sptests/sp15/.cvsignore: New. * sptests/sp16/.cvsignore: New. * sptests/sp17/.cvsignore: New. * sptests/sp19/.cvsignore: New. * sptests/sp20/.cvsignore: New. * sptests/sp21/.cvsignore: New. * sptests/sp22/.cvsignore: New. * sptests/sp23/.cvsignore: New. * sptests/sp24/.cvsignore: New. * sptests/sp25/.cvsignore: New. * sptests/spsize/.cvsignore: New. * support/.cvsignore: New. * tmtests/.cvsignore: New. * tmtests/tm01/.cvsignore: New. * tmtests/tm02/.cvsignore: New. * tmtests/tm03/.cvsignore: New. * tmtests/tm04/.cvsignore: New. * tmtests/tm05/.cvsignore: New. * tmtests/tm06/.cvsignore: New. * tmtests/tm07/.cvsignore: New. * tmtests/tm08/.cvsignore: New. * tmtests/tm09/.cvsignore: New. * tmtests/tm10/.cvsignore: New. * tmtests/tm11/.cvsignore: New. * tmtests/tm12/.cvsignore: New. * tmtests/tm13/.cvsignore: New. * tmtests/tm14/.cvsignore: New. * tmtests/tm15/.cvsignore: New. * tmtests/tm16/.cvsignore: New. * tmtests/tm17/.cvsignore: New. * tmtests/tm18/.cvsignore: New. * tmtests/tm19/.cvsignore: New. * tmtests/tm20/.cvsignore: New. * tmtests/tm21/.cvsignore: New. * tmtests/tm22/.cvsignore: New. * tmtests/tm23/.cvsignore: New. * tmtests/tm24/.cvsignore: New. * tmtests/tm25/.cvsignore: New. * tmtests/tm26/.cvsignore: New. * tmtests/tm27/.cvsignore: New. * tmtests/tm28/.cvsignore: New. * tmtests/tm29/.cvsignore: New. * tmtests/tmck/.cvsignore: New. * tmtests/tmoverhd/.cvsignore: New.
