path: root/c/src (follow)
* Added a routine to remove a semaphore name from its namespace.Jennifer Averett1999-11-181-0/+15
* Removed IT_COUNT since it was not used.Joel Sherrill1999-11-181-13/+0
* Patch rtems-rc-19991117-0.diff.gz from Ralf CorsepiusJoel Sherrill1999-11-185-10/+11
| | | | | <corsepiu@faw.uni-ulm.de> which corrects some configuration problems and cleans up a few Makefile.in's.
* Patch rtems-rc-19991105-3.diff.gz from Ralf CorsepiusJoel Sherrill1999-11-1833-40/+71
| | | | | <corsepiu@faw.uni-ulm.de> which turns OPERATION_COUNT into a configure time option.
* Comment added.Jennifer Averett1999-11-171-1/+2
* Updated copyright notice.Joel Sherrill1999-11-171748-3488/+1750
* Now allows override of base address via -Ttext command to linker.Joel Sherrill1999-11-171-39/+47
* + Updated copyright information.Jennifer Averett1999-11-173-4/+5
* + Updated copyright information.Jennifer Averett1999-11-17133-52/+347
* New file documenting the on board monitor (PPCBUG) configuration usedJoel Sherrill1999-11-172-0/+156
| | | | | to be able to boot the archives located in powerpc-rtems/c/mcp750/bin. This information was provided by Eric Valette <valette@crf.canon.fr>
* Conditionally take out the offensive pragma pack when on RTEMS in additionJoel Sherrill1999-11-171-2/+2
| | | | to UnixWare (UW).
* New shell of a test for ITRON Mailbox Manager.Joel Sherrill1999-11-177-1/+154
* Updated Mailbox Manager submitted and split into multiple files.Joel Sherrill1999-11-1711-344/+470
* Update from Andrew D. McDowell <amcdowel@cs.uah.edu> with modificationsJoel Sherrill1999-11-171-7/+257
| | | | | by Joel and Jennifer based on experience merging the other managers and cleaning them up. No test code is available at this point.
* Fixed screen.Joel Sherrill1999-11-161-1/+1
* Added TERMINAL_IDENTIFICATION pieces.Joel Sherrill1999-11-161-3/+4
* Fixed alignment problem on _endtext.Joel Sherrill1999-11-161-0/+1
* Moved task_variable pointer to basic shared part of TCB instead ofJoel Sherrill1999-11-165-38/+26
| | | | | | | RTEMS API extension to avoid problems when the extension is freed. Eventually the task variable switch extension should become part of the core context switch and the Ada tcb self implemented in terms of it.
* Added proper nesting level for dispatch disable check.Joel Sherrill1999-11-163-3/+3
* Added code so if dispatching level is specified to be -1, then noJoel Sherrill1999-11-161-1/+1
| | | | | check is performed. This is needed in some timer service routines since they are called from multiple disable levels.
* Corrected nesting level on dispatching verification.Joel Sherrill1999-11-161-1/+1
* Corrected disable dispatch nesting count checks.Joel Sherrill1999-11-161-7/+7
* Added check to return passed if task is not suspended.Jennifer Averett1999-11-162-1/+7
* Added code to catch the error of suspend count exceding the counter value.Jennifer Averett1999-11-161-0/+4
* Fixed bug.Jennifer Averett1999-11-162-6/+6
* Added handler for fsync. For the memfile it is the same as the data sync.Jennifer Averett1999-11-163-3/+3
* Fixed typo.Joel Sherrill1999-11-161-1/+1
* Inserted output from the erc32 run into the output file.Jennifer Averett1999-11-161-3/+71
* Use miniIMFS like hello from samples.Joel Sherrill1999-11-161-0/+2
* Increased stack space because message buffers are on the stack.Joel Sherrill1999-11-161-0/+1
* Removed leading space from output.Jennifer Averett1999-11-162-4/+4
* Added comment indicating that dup is known to be broken.Jennifer Averett1999-11-161-1/+1
* Added data to the log file so it matches the real output.Jennifer Averett1999-11-161-3/+61
* Added comment to log file indicating that task order is notJennifer Averett1999-11-161-1/+3
| | | | critical.
* Added test case of rsm_tsk and frsm_tsk on a task not suspended.Jennifer Averett1999-11-162-3/+14
| | | | This should result in nothing happening, but an E_OK result.
* Added BSP_MAXIMUM_OPERATION_COUNT and BSP_ITERATION_COUNTJoel Sherrill1999-11-161-2/+27
| | | | | | | | | which allow the BSP to override the default number of objects that will be created in the timing tests. This is useful for reducing memory consumption on small targets. The BSP_ITERATION_COUNT can be used to reduce the number of repititions in some of the tests. This is useful for extremely slow targets (we haven't seen any slow enough to justify modifying this one yet though. :)
* Added code to the macros which checked directive status to alsoJoel Sherrill1999-11-161-20/+44
| | | | | | | check that the _Thread_Dispatch_disable_level is set to the proper value (0 99% of the time). This automatic check significantly reduces the chance of mismatching disable/enable dispatch pairs while doing internal RTEMS work.
* Use the miniIMFS to reduce code space.Joel Sherrill1999-11-161-0/+2
* Added test cases for uname().Joel Sherrill1999-11-162-0/+25
* Web server uses the POSIX API. Therefor, it must be disabled when theJoel Sherrill1999-11-164-3/+26
| | | | POSIX API is disabled.
* Removed start subdirectory and distributed contents to the appropriateJoel Sherrill1999-11-163-10/+3
| | | | places under the libbsp tree.
* Added comments.Joel Sherrill1999-11-163-3/+10
* Now use _Thread_Reset().Joel Sherrill1999-11-161-19/+4
* Added threadreset.c.Joel Sherrill1999-11-161-1/+1
* Added prototype for _Thread_Reset() and numerous comments.Joel Sherrill1999-11-161-4/+28
* Only check for System V IPC if multiprocessing is enabled. The unixJoel Sherrill1999-11-163-2/+15
| | | | | | | | port only uses System V IPC for shared memory and semaphores to communicate between nodes in a multiprocessor configuration. If you disable multiprocessing, then this code should be unused. Thus systems like Cygwin which are POSIX but do not support System V IPC should not work.
* Fixed so can be included multiple times in the executive source.Joel Sherrill1999-11-161-0/+9
* Works now.Joel Sherrill1999-11-163-57/+36
| | | | | Removed times() since the version in the C Library support code is fine.
* Return a reasonable error other than ENOSYS.Joel Sherrill1999-11-161-1/+1
* Added call to _Watchdog_Remove to remove the sporadic timer. It wasJoel Sherrill1999-11-161-0/+1
| | | | being reinserted onto the ticks chain.
