* | Split threadq.c into multiple files. | Joel Sherrill | 1999-11-02 | 17 | -2/+1280 | |
* | The object memfile.o was being included in the miniIMFS even though it | Joel Sherrill | 1999-11-02 | 31 | -385/+682 | |
| | | | | | | | should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS. | |||||
* | Split object.c into multiple files. | Joel Sherrill | 1999-11-02 | 17 | -983/+1375 | |
* | Split types.s into individual files. | Joel Sherrill | 1999-11-02 | 12 | -172/+306 | |
* | Final tuning required to drop out POSIX timers. | Joel Sherrill | 1999-11-02 | 4 | -47/+59 | |
* | *** empty log message *** | Joel Sherrill | 1999-11-02 | 4 | -923/+985 | |
* | Split cancel.c into multiple files. | Joel Sherrill | 1999-11-02 | 8 | -186/+280 | |
* | Missed these in the initial split up. | Joel Sherrill | 1999-11-02 | 2 | -0/+177 | |
* | Split key.c into multiple files. | Joel Sherrill | 1999-11-02 | 7 | -226/+294 | |
* | Wrong routine was initially cut into this file. | Joel Sherrill | 1999-11-02 | 1 | -14/+6 | |
* | Split time.c into multiple files. | Joel Sherrill | 1999-11-02 | 14 | -366/+578 | |
* | Split condition variables into multiple files. | Joel Sherrill | 1999-11-02 | 15 | -484/+544 | |
* | Split the POSIX semaphore manager into multiple files. | Joel Sherrill | 1999-11-02 | 18 | -588/+838 | |
* | Split some more stuff out of psignal.c. | Joel Sherrill | 1999-11-02 | 7 | -236/+345 | |
* | Split mutex.c into multiple files. | Joel Sherrill | 1999-11-02 | 23 | -703/+1037 | |
* | Split mqueue into multiple files. | Joel Sherrill | 1999-11-02 | 1 | -0/+28 | |
* | Removed warnings. | Joel Sherrill | 1999-11-02 | 1 | -2/+2 | |
* | Split mqueue.c into a variety of files. | Joel Sherrill | 1999-11-02 | 17 | -673/+1127 | |
* | Minor changes to make the screen match a bit better. | Joel Sherrill | 1999-11-02 | 2 | -4/+4 | |
* | Minor fixes to make screen match a bit better. | Joel Sherrill | 1999-11-02 | 2 | -11/+15 | |
* | Added more proper checking of F_GETFL and F_SETFL. | Joel Sherrill | 1999-11-02 | 1 | -5/+17 | |
| | | | | | | Disabled test of F_DUPFD since it does not work. Added comment to indicate that seekdir(NULL) was being called. | |||||
* | Fixed F_SETFL to properly convert between internal | Joel Sherrill | 1999-11-02 | 2 | -4/+6 | |
| | | | | libio flags and external fcntl.h style flags. | |||||
* | Added support for configuring base filesystem. First attempt at | Joel Sherrill | 1999-11-02 | 2 | -34/+82 | |
| | | | | | | a full mount table at initialization. This is the wrong place to mount filesystems 2-n since no device drivers are initialized yet. | |||||
* | Install imfs.h so base filesystem can be configured or IMFS mounted | Joel Sherrill | 1999-11-02 | 1 | -1/+1 | |
| | | | | by an application. | |||||
* | Check for NULL being passed in. | Joel Sherrill | 1999-11-02 | 8 | -4/+34 | |
* | Fixed typo where memfile_handlers set twice and directory_handlers | Joel Sherrill | 1999-11-02 | 3 | -9/+9 | |
| | | | | was not set. | |||||
* | Properly initialize location variable. | Joel Sherrill | 1999-11-02 | 3 | -0/+24 | |
* | Split console_reserve_resources into its own file to reduce dependencies. | Joel Sherrill | 1999-11-02 | 3 | -10/+30 | |
| | | | | Still need to move debug io routines out. | |||||
* | Fixed bug which resulted in misaligned object control structures | Joel Sherrill | 1999-11-02 | 1 | -3/+5 | |
| | | | | | being allocated. This bug manifested itself on the SPARC since it uses ldd/std in its context save/restore routines. | |||||
* | Added a comment to indicate that if a task blocked on a priority | Joel Sherrill | 1999-11-02 | 1 | -0/+5 | |
| | | | | | based thread queue were to be reinserted based on its new priority, this is where the logic would go. | |||||
* | Added code to allocate by index. This is the object ID style used | Joel Sherrill | 1999-11-02 | 1 | -27/+134 | |
| | | | | | | by ITRON. Corrected spacing. | |||||
* | Added maximum count detection logic. | Joel Sherrill | 1999-11-02 | 2 | -4/+16 | |
* | Added support for message priority as required by POSIX. | Joel Sherrill | 1999-11-02 | 2 | -5/+43 | |
* | Corrected spacing. | Joel Sherrill | 1999-11-02 | 1 | -2/+2 | |
* | Added message queues and semaphores. | Joel Sherrill | 1999-11-02 | 1 | -0/+11 | |
* | Added CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES and | Joel Sherrill | 1999-11-02 | 1 | -0/+24 | |
| | | | | CONFIGURE_MAXIMUM_POSIX_SEMAPHORES. | |||||
* | Added comment to make sure Classic API priority to Core priority | Joel Sherrill | 1999-11-02 | 1 | -0/+1 | |
| | | | | is added in the future. | |||||
* | Added comments for _RTEMS_tasks_Create_extension, | Joel Sherrill | 1999-11-02 | 1 | -4/+9 | |
| | | | | | _RTEMS_tasks_Start_extension, _RTEMS_tasks_Delete_extension, and _RTEMS_tasks_Switch_extension. | |||||
* | Added a case to support the core semaphore error returned when the | Joel Sherrill | 1999-11-02 | 1 | -0/+8 | |
| | | | | maximum semaphore count is exceeded. | |||||
* | Added code to utilize the maximum_count attribute of core semaphores | Joel Sherrill | 1999-11-02 | 1 | -0/+7 | |
| | | | | | and initialize it to a value that would keep it from every being a problem. | |||||
* | Now much closer to working. | Joel Sherrill | 1999-11-02 | 1 | -7/+61 | |
* | Added assert in case _Objects_Get_information fails since this | Joel Sherrill | 1999-11-02 | 1 | -0/+4 | |
| | | | | should NEVER occur. | |||||
* | Commented out lines causing warning. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 | |
* | Added #define for SEM_FAILED. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 | |
* | Added include of <sys/siginfo.h>. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 | |
* | Added message queues and semaphores. | Joel Sherrill | 1999-11-02 | 1 | -1/+3 | |
* | Backed out change that increased the minimum stack size since it | Joel Sherrill | 1999-11-02 | 31 | -31/+0 | |
| | | | | | was unnecessary. The real fix was an alignment error in the object extend memory allocation scheme. | |||||
* | Modified to use minimum stack size and reserve the necessary amount | Joel Sherrill | 1999-11-02 | 5 | -7/+13 | |
| | | | | of space in the workspace. | |||||
* | Corrected wildcard to pickup CPU model dependent library pieces. | Joel Sherrill | 1999-11-01 | 1 | -4/+2 | |
* | Enabled configuring mini or full IMFS. | Joel Sherrill | 1999-11-01 | 1 | -0/+29 | |
