* | event.h: _Event_Manager_initialization no longer a static inline | Joel Sherrill | 1996-04-19 | 2 | -38/+0 |
* | event.h: _Event_Manager_initialization no longer a static inline | Joel Sherrill | 1996-04-19 | 4 | -0/+24 |
| | | | | support.h: updated to use RTEMS_APPLICATION macro | ||||
* | modified to generate fatal error when an unconfigured directive is invoked. | Joel Sherrill | 1996-04-19 | 24 | -8/+794 |
* | changes to compile in macro configuration without warnings. | Joel Sherrill | 1996-04-19 | 6 | -4/+48 |
* | minor mods to get to compile locally | Joel Sherrill | 1996-03-21 | 2 | -3/+4 |
* | some instructions altered for older binutils | Joel Sherrill | 1996-03-21 | 2 | -16/+16 |
* | updated | Joel Sherrill | 1996-03-21 | 1 | -15/+0 |
* | *** empty log message *** | Joel Sherrill | 1996-03-21 | 3 | -8/+4 |
* | updated for 68302 and so gen68360 bsp would compile | Joel Sherrill | 1996-03-21 | 2 | -1/+13 |
* | update to reflect internal threads reorganization | Joel Sherrill | 1996-03-21 | 2 | -0/+44 |
* | include of mc68360.h changed to m68360.h to reflect filename change. | Joel Sherrill | 1996-03-06 | 4 | -4/+4 |
* | Added 68360 support submitted by W. Eric Norum (eric@skatter.usask.ca). | Joel Sherrill | 1996-03-06 | 2 | -2/+12 |
| | | | | Also increased minimum stack size from 1K to 2K. | ||||
* | Generic 68360 BSP (gen360) submitted by: W. Eric Norum <eric@skatter.usask.ca>. | Joel Sherrill | 1996-03-06 | 12 | -0/+2355 |
| | | | | | | | | | | | Contact information: W. Eric Norum Saskatchewan Accelerator Laboratory 107 North Road University of Saskatchewan Saskatoon, Saskatchewan, CANADA S7N 5C6 | ||||
* | As part of reducing visibility into rtems and hiding the .inl files | Joel Sherrill | 1996-03-06 | 19 | -0/+19 |
| | | | | | from the application code, this file required more visibility than is given by default to application code. | ||||
* | Removed prototyes for static inline routines and moved the comments into | Joel Sherrill | 1996-03-06 | 159 | -6881/+2426 |
| | | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana. | ||||
* | Removed prototyes for static inline rgutines and moved the comments into | Joel Sherrill | 1996-03-06 | 1 | -41/+2 |
* | The name of the test support routine pause was changed to rtems_test_pause | Joel Sherrill | 1996-02-22 | 13 | -42/+38 |
| | | | | to avoid conflict with the standard POSIX routine pause(2). | ||||
* | Changed io manager initialization routine to not be static and added it here. | Joel Sherrill | 1996-02-21 | 1 | -0/+37 |
* | Changed io manager initialization routine to not be static. | Joel Sherrill | 1996-02-21 | 2 | -0/+16 |
* | changed io manager initialization routine to not be static | Joel Sherrill | 1996-02-21 | 2 | -6/+2 |
* | Dispersal of internal thread handler resulted in removal of some | Joel Sherrill | 1996-02-21 | 1 | -16/+11 |
| | | | | variables and renaming of others. | ||||
* | Dispersal of internal thread handler resulted in the SYSI task being | Joel Sherrill | 1996-02-21 | 16 | -21/+20 |
| | | | | | | only required in a multiprocessor system. It was replace by the MPCI Receive Server. As a result, the CPU Table field for extra stack for the SYSI task was changed to be extra stack for the MPCI Receive Server. | ||||
* | Removed the internal thread objects and dispersed its contents to | Joel Sherrill | 1996-02-21 | 16 | -17/+778 |
| | | | | | | | | | | the thread handler (IDLE), MPCI object (SYSI now MP Receive) and initialize_executive_early (IO initialization). The SYSI task no longer exists in a single processor configuration. This reduces single processor Workspace requirements by a TCB and a stack which is often larger than the minimum stack size. Moving the IO initialization plus accompanying BSP hooks eliminated an initialization ordering problem in which a global task could be created before the MPCI was initialized. | ||||
* | Dispersal of internal thread handler resulted in IDLE thread becoming | Joel Sherrill | 1996-02-21 | 11 | -52/+49 |
| | | | | | part of the Thread Handler. This required the name of the optional CPU dependent IDLE thread implementation to change. | ||||
* | MPCI Receive became a thread and the prototype changed. | Joel Sherrill | 1996-02-21 | 2 | -2/+6 |
* | Removed the internal thread objects and dispersed its contents to | Joel Sherrill | 1996-02-21 | 1 | -12/+14 |
* | Removed arguments from _Thread_Start_multitasking. | Joel Sherrill | 1996-02-14 | 2 | -8/+2 |
* | idle thread now created before system initialization thread. | Joel Sherrill | 1996-02-14 | 1 | -4/+1 |
| | | | | Also system initialization thread only created in MP systems. | ||||
* | removed arguments from _Thread_Start_multitasking | Joel Sherrill | 1996-02-14 | 1 | -12/+10 |
* | white space problem | Joel Sherrill | 1996-02-14 | 1 | -1/+0 |
* | Moved some initialization from the system initialization thread to | Joel Sherrill | 1996-02-14 | 1 | -2/+42 |
| | | | | | initialize_executive_early. This was done to clear up an ordering problem in which global tasks could be created before the MPCI layer was initialized. | ||||
* | removed post switch extension | Joel Sherrill | 1996-02-13 | 5 | -5/+0 |
* | fixed bug when outbyte had argument in wrong order relative to those invoking it | Joel Sherrill | 1996-02-13 | 1 | -3/+3 |
* | changed post task extension from user set to api set and added flag | Joel Sherrill | 1996-02-13 | 16 | -121/+76 |
| | | | | in each thread which must be set when the post switch extension is to be run. | ||||
* | added clear of _ISR_Signals_to_thread_executing | Joel Sherrill | 1996-02-13 | 1 | -1/+4 |
* | more comments added and existing ones cleaned up in synchronization paths | Joel Sherrill | 1996-02-13 | 1 | -1/+13 |
* | comma removed from end of last enumerated element | Joel Sherrill | 1996-02-13 | 2 | -2/+2 |
* | comment added to describe synchronization logic in timeout routine | Joel Sherrill | 1996-02-13 | 1 | -0/+21 |
* | *** empty log message *** | Joel Sherrill | 1996-02-12 | 1 | -4/+0 |
* | As part of implementing the new isr synchronization algorithm using a | Joel Sherrill | 1996-02-09 | 1 | -1/+1 |
| | | | | single enumerated set of states the set of event manager variables changed. | ||||
* | new isr synchronization algorithm using a single enumerated set of states. | Joel Sherrill | 1996-02-09 | 12 | -66/+110 |
* | added rtems_interrupt_is_in_progress | Joel Sherrill | 1996-02-09 | 2 | -0/+28 |
* | added clear of _ISR_Signals_to_thread_executing | Joel Sherrill | 1996-02-09 | 2 | -0/+2 |
* | changed synchronization algorithm to be a single list of enumerated states | Joel Sherrill | 1996-02-08 | 2 | -4/+4 |
* | alignment on workspace changed from CPU_ALIGNMENT to CPU_HEAP_ALIGNMENT | Joel Sherrill | 1996-02-08 | 2 | -2/+2 |
* | Swapped order of nested acquisition check and check for returning unsatisfied. | Joel Sherrill | 1996-02-01 | 1 | -6/+6 |
* | synchronization state bugs address | Joel Sherrill | 1996-02-01 | 1 | -7/+12 |
* | invalid use of tcb field resource count | Joel Sherrill | 1996-02-01 | 1 | -1/+0 |
* | new times for 3.5.1 | Joel Sherrill | 1996-01-22 | 1 | -33/+33 |
* | Added RTEMS API control structure to per task memory usage macro. | Joel Sherrill | 1996-01-19 | 1 | -1/+2 |
