path: root/c/src (follow)
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-188-2202/+22
| | | | | * rtems/score/cpu.h: Removed. * Makefile.am: Reflect changes above.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-1810-17/+28
| | | | | | | | | | | | * bootloader/exception.S: Reflect changes to <rtems/score/cpu.h>. * bootloader/head.S: Ditto. * bootloader/misc.c: Ditto. * console/polled_io.c: Ditto. * irq/irq.c: Ditto. * irq/irq_asm.S: Ditto. * irq/irq_init.c: Include <rtems/bspIo.h>. * start/start.S: Reflect changes to <rtems/score/cpu.h>. * vectors/vectors.S: Ditto.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-182-1/+5
| | | | * vectors/vectors.S: Include <asm.h>.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-183-2/+8
| | | | | * startup/bspstart.c: Include <rtems/bspIo.h>. * vectors/align_h.S: Use <> instead of "" for include files.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-186-8/+15
| | | | | | | | * irq/irq.c: Reflect changes to <rtems/score/cpu.h>. * irq/irq_asm.S: Ditto. * network/network.c: Include <rtems/bspIo.h>. * start/start.S: Include <asm.h> instead of "asm.h". * vectors/vectors.S: Reflect changes to <rtems/score/cpu.h>.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-185-8/+16
| | | | | | | | * irq/irq.c: Reflect changes to <rtems/score/cpu.h>. Fix loopCounter. * irq/irq_asm.S: Reflect changes to <rtems/score/cpu.h>. * vectors/vectors.S: Ditto. * vectors/vectors_init.c: Include <rtems/bspIo.h>.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-185-7/+14
| | | | | | | * irq/irq.c: Reflect changed to <rtems/score/cpu.h>. * irq/irq_asm.S: Ditto. * vectors/vectors.S: Ditto. * vectors/vectors_init.c: Include <rtems/bspIo.h>.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-187-17/+382
| | | | | | | | | | | | * asm.h: Include cpuopts.h instead of targopts.h. * rtems/new-exceptions/cpu.h: Relocated from libbsp/powerpc/support/new_exception_processing/rtems/score/cpu.h * rtems/old-exceptions/cpu.h: Relocated from c/src/lib/libbsp/powerpc/support/old_exception_processing/rtems/score/cpu.h * rtems/powerpc/registers.h: Relocated and renamed from libcpu/powerpc/shared/include/cpu.h. * rtems/score/cpu.h: New. * Makefile.am: Reflect changes above.
* 2002-04-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-181-0/+0
| | | | | | * startup/nulsystbl.c: Fix braces. * startup/Makefile.am: Remove types.h. * startup/types.h: Remove.
* 2002-04-18 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-04-182-6/+14
| | | | | | * rtems/score/cpu.h (CPU_ISR_Disable and CPU_ISR_Enable): Correct them where they correctly inform the compiler about the register they are modifying.
* 2002-04-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-184-43/+12
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-182-15/+5
| | | | * include/rtems/system.h: Remove targopts.h.
* 2001-04-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-173-1/+7
| | | | * shared/include/cpu.h: Added ifndef ASM.
* 2002-04-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-179-0/+19
| | | | | | | | | | | * base_sp/apptask.c: Include <stdlib.h>. * hello/init.c: Ditto. * paranoia/init.c: Ditto. * ticker/tasks.c: Ditto. * unlimited/init.c: Ditto. * unlimited/test1.c: Ditto. * unlimited/test2.c: Ditto. * unlimited/test3.c: Ditto.
* 2002-04-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-173-4/+6
| | | | * libc/scandir.c: Initialize nitems = 0.
* 2002-04-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-172-1/+6
| | | | | * include/rtems/system.h: Add the sparc to the target supporting multlibs.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-171-1/+4
| | | | | | * irq/irq.c: Define loopCounter iff DISPATCH_HANDLER_STAT is set. * startup/bspstart.c: include <bsp/irq.h>, <libcpu/cpuIdent.h>, <rtems/bspIo.h>
* 2001-04-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-171-2/+10
| | | | * ChangeLog: Corrected paths on past few commits.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-172-2/+4
| | | | * shared/include/cpu.h: Don't include cpuIdent.h.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-173-0/+6
| | | | * exceptions/raw_exception.c: Include <libcpu/cpuIdent.h>.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-171-0/+4
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-174-0/+12
| | | | * startup/bspstart.c: Include <libcpu/cpuIdent.h>, <rtems/bspIo.h>.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-172-0/+5
| | | | * startup/bspstart.c: Include <libcpu/cpuIdent.h>.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-172-1/+8
* 2002-04-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-165-25/+58
| | | | | | | * shared/include/cpuIdent.h: New. * shared/include/cpuIdent.c: Reflect having added cpuIdent.h. * shared/include/cpu.h: Ditto. * shared/include/Makefile.am: Add cpuIndent.h. Fix EXTRA_DIST.
* 2002-04-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-162-2/+4
| | | | * configure.ac: Remove ENABLE_GCC28.
* 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-1622-17/+44
* 2002-04-16 Chris Johns <ccj@acm.org>Joel Sherrill2002-04-162-0/+21
| | | | | | | * src/threadinitialize.c: Per PR181, clear the array of user extension pointers. This lets user extensions that have hooked the switch handler know if a task has been processed by the user extension before. If a user extension is created after a task is started it may not know it.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-166-0/+114
| | | | | | | * include/Makefile.am: Add stdint.h and inttypes.h. (reported by Mike Siers <mikes@poliac.com>) * include/stdint.h: New file. * include/inttypes.h: New file.
* 2002-04-11 Chris Johns <ccj@acm.org>Joel Sherrill2002-04-132-2/+8
| | | | | | | * network/rtems_bsdnet.h: To address PR59, added the drv_ctrl driver control block field to the ifconfig network driver structure. This field is needed by the i82586 driver which was ported from NetBSD as it had better hardware abstraction.
* 2002-04-11 Chris Johns <ccj@acm.org>Joel Sherrill2002-04-134-0/+28
| | | | | | | * c/src/libnetworking/rtems/rtems_bsdnet.h: To address PR59, added the drv_ctrl driver control block field to the ifconfig network driver structure. This field is needed by the i82586 driver which was ported from NetBSD as it had better hardware abstraction.
* 2002-03-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-124-123/+0
| | | | | | | | | * tbr/Makefile.am: Remove. * tbr/.cvsignore: Remove. * tbr/tbr.c: Remove. * tbr/tbr.h: Remove. * configure.ac: Remove tbr subdir. * Makefile.am: Remove tbr subdir.
* 2002-04-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-122-1/+5
| | | | * include/rtems/system.h: Add i386 to multilib-able targets.
* 2002-03-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-124-83/+13
| | | | | | | * cache.c: Include <rtems/score/registers.h> instead of <libcpu/registers.h>. * cpu.h: Ditto. Remove parts moved to score/cpu/i386. * registers.h: Add BIG-FAT warning.
* 2002-03-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-127-4/+346
| | | | | | | | | | | | | | * rtems/score/idtr.h: New file, extracted from libcpu/cpu.h. * rtems/score/interrupts.h: New file, extracted from libcpu/cpu.h. * rtems/score/registers.h: New file, moved from libcpu. * Makefile.am: Reflect changes above. * cpu.c: Don't include cpuModel.h, #include <rtems.h>, #include <rtems/score/i386types.h>, #include <rtems/score/idtr.h>. * rtems/score/cpu.h: Don't include libcpu/cpu.h. #include <rtems/score/interrupts.h>, #include <rtems/score/registers.h>.
* 2001-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-113-75/+48
| | | | | | | * macros/rtems/score/userext.inl: Now works after merging patch for functionality requested in PR174. * inline/rtems/score/userext.inl: Added a comment explaining the order in which routines appear since it is not the obvious order.
* 2002-04-08 Chris Johns <ccj@acm.org>Joel Sherrill2002-04-093-1/+10
| | | | | | * Per PR141 and PR174, make task switch extension its own list and fix all odd problems introduced by providing macro version. * inline/rtems/score/userext.inl: Fix.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-085-2/+7
| | | | | * libc/stat.c: include <string.h>. * libc/printk.c: Remove libcpu/cpu.h.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-086-0/+16
| | | | | * src/ramdisk.c: include <string.h>. * src/blkdev.c: include <string.h>.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-0812-0/+28
| | | | | | | | * src/imfs/imfs_getchild.c: include <string.h>. * src/imfs/imfs_gtkn.c: Include <string.h>. * src/imfs/ioman.c: Include <string.h>. * src/imfs/linearfile.c: Include <string.h>. * src/imfs/memfile.c: Include <string.h>.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-081-1/+0
| | | | * console-generic/console-generic.c: Remove unused variable "res".
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-082-52/+56
| | | | * score/cpu_asm.c: Adapt inline asm to gcc-3.0.4.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-084-0/+15
| | | | * configure.ac: Add BSPOPTS_*(DISPATCH_HANDLER_STAT).
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-082-1/+9
| | | | | * configure.ac: Add BSPOPTS_*(DISPATCH_HANDLER_STAT). Remove RTEMS_ENABLE_LIBCDIR.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-083-2/+6
| | | | * include/mvme16x_hw.h: Include <bsp.h> instead of targopts.h.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-082-5/+9
| | | | * include/rtems/bspIo.h: Fix cpp-guards, remove references to i386.
| | | | * rtems.c: Adaptation to gcc-3.0.x.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-082-0/+5
| | | | * src/psignal.c: Include <stdlib.h>.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-082-8/+16
| | | | * ChangeLog: Fix dates.
* 2001-04-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-082-1/+5
| | | | * src/tasks.c: Pre-initialized switch extension for list.
