path: root/c/src (follow)
* Remove CVS-Ids.Ralf Corsépius2012-05-0447-127/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-043-9/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-042-6/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-04109-217/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-046-16/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-046-18/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-0410-30/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-0436-111/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-044-12/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-0413-42/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-0448-144/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-045-14/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-048-25/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-0420-68/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-042-8/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-042-7/+0
* nds/linkcmds - Remove execute permissionJoel Sherrill2012-05-031-0/+0
* libcpu misc m68k and sh - Correct formatting and remove weird Id stringsJoel Sherrill2012-05-036-59/+41
* General - Remove extraneous blank line in license messageJoel Sherrill2012-05-0398-85/+0
| | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly.
* Libcpu misc files - Remove execute permission on source files.Joel Sherrill2012-05-0310-0/+0
* rtems-message_queue.adb - Convert DOS to UNIX CF/LFJoel Sherrill2012-05-031-245/+245
* smdk2410 - Remove odd $Id$Joel Sherrill2012-05-021-2/+0
* gp32 - Remove odd $Id$Joel Sherrill2012-05-021-3/+0
* pc386 - Remove odd $Id$Joel Sherrill2012-05-027-14/+0
* libchip hcms29xx - Remove odd $Id$ and clean up file headerJoel Sherrill2012-05-025-17/+1
* score603e - Remove bad $Id$ and clean up file headerJoel Sherrill2012-05-021-4/+6
* libcpu/m68k/mcf532x - Remove bad $Id$ and clean up file headerJoel Sherrill2012-05-021-3/+3
* libchip z85c30 - Remove bad $Id$ and clean up file headerJoel Sherrill2012-05-021-4/+6
* LEON3 - Remove bad $Id$ and clean up file headerJoel Sherrill2012-05-021-4/+6
* LEON2 - Remove bad $Id$ and clean up file headerJoel Sherrill2012-05-021-4/+6
* MRM332 - Remove incorrect $Id$ string and correct file headerJoel Sherrill2012-05-022-2/+26
* bsps/stackalloc: Add initialization hookSebastian Huber2012-04-262-16/+23
* bsp/mpc55xxevb: Enable stack allocatorSebastian Huber2012-04-246-4/+10
* bsps/stackalloc: Use stack section symbolsSebastian Huber2012-04-245-55/+26
* bsps/powerpc: Add no cache sectionSebastian Huber2012-04-2414-89/+78
