* sptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* minimum/Makefile.am: Fix comments to make automake-1.5 happy.
* sample.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* cdtest/Makefile.am: Remove LD_LIBS.
* psxtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* mptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* libtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* rtems++/Makefile: Remove LD_LIBS.
* itrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* Makefile.am: Use SUBDIRS = instead of SUBDIRS += to make
automake-1.5 happy.
* include/rtems/score/Makefile.am: Use CLEANFILES = to make
automake-1.5 happy.
* bsp.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
* wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
* include/sys/Makefile.am: Use = instead of += to setup
NETWORKING_H_FILES and NEWLIB_H_FILES.
* libc/Makefile.am: Revamp INCLUDES handling to make automake-1.5
happy.
* wrapup/rtems/Makefile.am: Fix comments to make automake-1.5 happy.
* optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5.
* optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5 happy.
* src/Makefile.am: Adapt INCLUDES to make automake-1.5 happy.
automake-1.5 happy.
automake-1.5 happy.
* src/Makefile.am: Revamp INCLUDES handling to make automake-1.5
* include/rdbg/rdbg.h, src/ptrace.c: Modifications to make gcc 3.x happy.
* libc/gxx_wrappers.c: Modifications to make gcc 3.x happy.
* startup/init68360.c: Modifications to make gcc 3.x happy.
* scitab/Makefile.am: Remove stray blank from SCITAB rule.
* configure.in, rootfs/Makefile.am: Added conditional to make sure
rootfs does not get built with networking is disabled. Also
added include of compile.am to rootfs/Makefile.am.
* wrapup/Makefile.am: Added rootfs conditionally if networking enabled.
* network/Makefile.am: Fixed typo on file name.
* network/i82586.c: Commented out line 318 which is referencing
a member of a structure that is not currently there. This
needs to be worked out with Chris Johns <ccj@acm.org>.
Switched C++ style comments to C style.
* src/tasks.c: Dereference pointer passed to destructor.
* README: Bring it more in line with reality.
* lib/tftpDriver.c: Add some debugging capability.
* network/README.i82586, network/i82586.c, network/i82586reg.h,
network/i82586var.h: New files. Network driver for Intel
i82586.
* nfs/bootp_subr.c, rtems/rtems_bootp.c, rtems/rtems_bsdnet.h,
rtems/rtems_bsdnet_internal.h Added support for populating the
initial "root" filesystem with information obtained via the DHCP
response.
* Added support for populating the initial "root" filesystem
with information obtained via the DHCP response.
* rootfs: New directory.
* rootfs/.cvsignore, rootfs/Makefile.am, rootfs/mkrootfs.c,
rootfs/mkrootfs.h: New files.
* configure.in, Makefile.am: Modified to reflect addition.
* tm27/Makefile.am: include leaf.am instead of leaf.cfg.
* tm26/Makefile.am: include leaf.am instead of leaf.cfg.
* tm24/Makefile.am: include leaf.am instead of leaf.cfg.
* tm16/Makefile.am: include leaf.am instead of leaf.cfg.
* tm18/Makefile.am: include leaf.am instead of leaf.cfg.
* tm02/Makefile.am: include leaf.am instead of leaf.cfg.
* tm10/Makefile.am: include leaf.am instead of leaf.cfg.
* tm11/Makefile.am: include leaf.am instead of leaf.cfg.
* tm15/Makefile.am: include leaf.am instead of leaf.cfg.
* tm19/Makefile.am: include leaf.am instead of leaf.cfg.
* tm04/Makefile.am: include leaf.am instead of leaf.cfg.
* tm17/Makefile.am: include leaf.am instead of leaf.cfg.
* tm28/Makefile.am: include leaf.am instead of leaf.cfg.
* tmck/Makefile.am: include leaf.am instead of leaf.cfg.
* tm08/Makefile.am: include leaf.am instead of leaf.cfg.
* tm12/Makefile.am: include leaf.am instead of leaf.cfg.
* tm03/Makefile.am: include leaf.am instead of leaf.cfg.
* tm13/Makefile.am: include leaf.am instead of leaf.cfg.
* tm29/Makefile.am: include leaf.am instead of leaf.cfg.
* tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg.
* tm20/Makefile.am: include leaf.am instead of leaf.cfg.
* tm09/Makefile.am: include leaf.am instead of leaf.cfg.
* tm01/Makefile.am: include leaf.am instead of leaf.cfg.
* tm21/Makefile.am: include leaf.am instead of leaf.cfg.
* tm07/Makefile.am: include leaf.am instead of leaf.cfg.
* tm25/Makefile.am: include leaf.am instead of leaf.cfg.
* tm22/Makefile.am: include leaf.am instead of leaf.cfg.
* tm06/Makefile.am: include leaf.am instead of leaf.cfg.
* tm05/Makefile.am: include leaf.am instead of leaf.cfg.
* tm14/Makefile.am: include leaf.am instead of leaf.cfg.
* tm23/Makefile.am: include leaf.am instead of leaf.cfg.
* tmitronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* sp20/Makefile.am: include leaf.am instead of leaf.cfg.
* sp02/Makefile.am: include leaf.am instead of leaf.cfg.
* sp19/Makefile.am: include leaf.am instead of leaf.cfg.
* sp11/Makefile.am: include leaf.am instead of leaf.cfg.
* sp25/Makefile.am: include leaf.am instead of leaf.cfg.
* sp04/Makefile.am: include leaf.am instead of leaf.cfg.
* spsize/Makefile.am: include leaf.am instead of leaf.cfg.
* sp01/Makefile.am: include leaf.am instead of leaf.cfg.
* sp16/Makefile.am: include leaf.am instead of leaf.cfg.
* sp05/Makefile.am: include leaf.am instead of leaf.cfg.
* sp09/Makefile.am: include leaf.am instead of leaf.cfg.
* spfatal/Makefile.am: include leaf.am instead of leaf.cfg.
* sp06/Makefile.am: include leaf.am instead of leaf.cfg.
* sp23/Makefile.am: include leaf.am instead of leaf.cfg.
* sp28/Makefile.am: include leaf.am instead of leaf.cfg.
* sp03/Makefile.am: include leaf.am instead of leaf.cfg.
* sp29/Makefile.am: include leaf.am instead of leaf.cfg.
* sp13/Makefile.am: include leaf.am instead of leaf.cfg.
* sp27/Makefile.am: include leaf.am instead of leaf.cfg.
* sp14/Makefile.am: include leaf.am instead of leaf.cfg.
* sp07/Makefile.am: include leaf.am instead of leaf.cfg.
* sp15/Makefile.am: include leaf.am instead of leaf.cfg.
* sp17/Makefile.am: include leaf.am instead of leaf.cfg.
* sp22/Makefile.am: include leaf.am instead of leaf.cfg.
* sp12/Makefile.am: include leaf.am instead of leaf.cfg.
* sp26/Makefile.am: include leaf.am instead of leaf.cfg.
* sp21/Makefile.am: include leaf.am instead of leaf.cfg.
* sp24/Makefile.am: include leaf.am instead of leaf.cfg.
* sp08/Makefile.am: include leaf.am instead of leaf.cfg.
* unlimited/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* hello/Makefile.am: include leaf.am instead of leaf.cfg.
* base_sp/Makefile.am: include leaf.am instead of leaf.cfg.
* paranoia/Makefile.am: include leaf.am instead of leaf.cfg.
* cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* ticker/Makefile.am: include leaf.am instead of leaf.cfg.
* minimum/Makefile.am: include leaf.am instead of leaf.cfg.
* psx01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx11/Makefile.am: include leaf.am instead of leaf.cfg.
* psxcancel/Makefile.am: include leaf.am instead of leaf.cfg.
* psx02/Makefile.am: include leaf.am instead of leaf.cfg.
* psx13/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtime/Makefile.am: include leaf.am instead of leaf.cfg.
* psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx07/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtimer/Makefile.am: include leaf.am instead of leaf.cfg.
* psx10/Makefile.am: include leaf.am instead of leaf.cfg.
* psx08/Makefile.am: include leaf.am instead of leaf.cfg.
* psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg.
* psxfile01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx05/Makefile.am: include leaf.am instead of leaf.cfg.
* psx09/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmount/Makefile.am: include leaf.am instead of leaf.cfg.
* psxstat/Makefile.am: include leaf.am instead of leaf.cfg.
* psx12/Makefile.am: include leaf.am instead of leaf.cfg.
* psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg.
* psxsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx03/Makefile.am: include leaf.am instead of leaf.cfg.
* psx04/Makefile.am: include leaf.am instead of leaf.cfg.
* psx06/Makefile.am: include leaf.am instead of leaf.cfg.
* mp02/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp02/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp04/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp04/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp14/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp14/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp06/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp06/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp08/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp08/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp03/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp03/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp10/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp10/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp05/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp05/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp13/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp13/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp01/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp01/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp07/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp07/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp11/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp11/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp12/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp12/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp09/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp09/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* malloctest/Makefile.am: include leaf.am instead of leaf.cfg.
* monitor/Makefile.am: include leaf.am instead of leaf.cfg.
* termios/Makefile.am: include leaf.am instead of leaf.cfg.
* putenvtest/Makefile.am: include leaf.am instead of leaf.cfg.
* rtems++/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* stackchk/Makefile.am: include leaf.am instead of leaf.cfg.
* rtmonuse/Makefile.am: include leaf.am instead of leaf.cfg.
* cpuuse/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask03/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask04/Makefile.am: include leaf.am instead of leaf.cfg.
* itronmbf01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronhello/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontime01/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask01/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask02/Makefile.am: include leaf.am instead of leaf.cfg.
* itronmbox01/Makefile.am: include leaf.am instead of leaf.cfg.
* ChangeLog: Fixed some mistakes.
* ChangeLog: New file.
* devnull/devnull.c: Eliminate warning.
* src/sysconf.c: Fix typo syntax error accidentally committed.
* configure.in: autoupdate to autoconf-2.52, new CONFIG_SUBDIRS
handling.
* src/mprotect.c: New file. Stub required by some gcc's to pass tests.
In particular, about 350 ACATS tests fail if this is not present.
* src/getpagesize.c: Ditto.
* src/sysconf.c: Addition of Solaris value for _SC_STACK_PROT required
to pass about 350 ACATS test cases.
* src/Makefile.am: Added new files.
* network/network.c: Fix to account for return value when
installing interrupts handler.
* startup/linkcmds: Modified to work better with gcc 2.8.1 and
gnat 3.13p.
* src/coremutex.c, src/coremutexseize.c, src/coremutexsurrender.c,
inline/rtems/score/coremutex.inl: The per thread field resource_count
should only be manipulated when a mutex is priority ceiling or
priority inherit. This was reported by Chris Johns <ccj@acm.org>
who also noticed that the use of switches for all disciplines
generated less efficient code than using explicit tests for the one
or two cases we were really interested in. Further review of his
modifications made it apparent that the "isa" methods to test mutex
discipline were not being used so this modification was swept into
the code as well.
* inline/rtems/rtems/attr.inl: Correct typo and use correct
attribute RTEMS_SYSTEM_TASK. Reported by Chris Johns <ccj@acm.org>.
* src/coremutexseize.c: Add missing code for proper handling
of nesting acquisitions. This only impacts building with
inlines disabled on the source with the "fast mutex" optimizations.
This was post the 4.5 branch and did not impact released versions.
* macros/rtems/posix/mqueue.inl: Add cast so negation works.
* include/Makefile.am: Include coverhd.h so tmtests will compile.
* include/rtems/libio_.h: Added ifdef to ensure that LOGIN_NAME_MAX
is defined on GNU/Linux (RedHat 6.2 distribution).
* libc/unixlibc.c: Added stubs for rtems_io_register_name() and
rtems_io_lookup_name() so UNIX port would compile the IO manager
sptest that registers /dev/null.
