* console/console.c: Add BSP_poll_char.
* startup/bspstart.c: Add BSP_poll_char.
* console/debugio.c: Add BSP_poll_char.
* console/console.c: Add BSP_poll_char. Reformat.
PR 1599/cpukit
* sh7032/score/cpu_asm.c, sh7045/score/cpu_asm.c,
sh7750/score/cpu_asm.c, shgdb/score/cpu_asm.c: Rename
_Context_Switch_necessary to _Thread_Dispatch_necessary to more
properly reflect the intent.
PR 1599/cpukit
* new-exceptions/bspsupport/ppc_exc_hdl.c: Rename
PR 1599/cpukit
* shared/irq/exception.S: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
PR 1532/testing
* host.cfg.in: Add initial tests for untar capabilities. This required
BIN2C.
PR 1634/bsps
* shared/console/conscfg.c: Add BSP_poll_char.
* umon/tfsDriver.c: Update for LibIO API changes.
* start/start.S: Replace the call to _return_to_monitor by
hlt instruction.
* startup/ldsegs.S: Remove the _return_to_monitor function.
* timer/timer.c: Do not do the indirect call if NULL.
PR 1606/cpukit
* shared/startup/panic.c: Remove
INTERNAL_ERROR_INVALID_WORKSPACE_ADDRESS since it is not generated.
* byteorder.h: added ld_le16, st_le16.
* shared/irq/exception.S: Removed _ISR_Signals_to_thread_executing
declaration.
* umon/tfsDriver.c: Remove extra brace.
* umon/tfsDriver.c: Corrected filesystem mknod entry to call the
default handler.
PR 1588/cpukit
* start/start.S: Renamed defines SR0 .. SR15 in
PPC_SR0 .. PPC_SR15.
* umon/tfsDriver.c: Changed NULL methods in filesystem tables to be
default methods.
* new-exceptions/bspsupport/ppc_exc_asm_macros.h: Added include of
bspopts to resolve compilation problem.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* shared/irq/irq_asm.S: Rename rtems_per_cpu_info.
* configure.ac: Added AC_CHECK_SIZEOF macro.
PR 1573/cpukit
* shared/score/interrupt.S: Add a per cpu data structure which contains
the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
PR 1573/cpukit
sh7750/score/cpu_asm.c, shgdb/score/cpu_asm.c: Add a per cpu data
structure which contains the information required by RTEMS for each
CPU core. This encapsulates information such as thread executing,
heir, idle and dispatch needed.
PR 1573/cpukit
* mpc5xx/irq/irq.c, mpc5xx/irq/irq_asm.S,
new-exceptions/bspsupport/ppc_exc.S,
new-exceptions/bspsupport/ppc_exc_asm_macros.h,
new-exceptions/bspsupport/ppc_exc_hdl.c: Add a per cpu data structure
which contains the information required by RTEMS for each CPU core.
This encapsulates information such as thread executing, heir, idle
PR 1573/cpukit
* irq/irq.c: Add a per cpu data structure which contains the
information required by RTEMS for each CPU core. This encapsulates
information such as thread executing, heir, idle and dispatch needed.
PR 1573/cpukit
* shared/irq/exception.S: Add a per cpu data structure which contains
dispatch needed.
PR 1573/cpukit
* shared/irq/irq.c, shared/irq/irq_asm.S: Add a per cpu data structure
PR 1591/bsps
* preinstall.am: Regenerate.
PR 1586/misc
* libchip/i2c/spi-sd-card.h, libchip/i2c/spi-sd-card.c: Add retries to
SD card accesses.
* make/custom/lpc32xx_mzx_boot_int.cfg,
startup/linkcmds.lpc32xx_mzx_boot_int: Removed files.
* include/boot.h, include/emc.h, include/i2c.h, include/nand-mlc.h,
make/custom/lpc32xx_mzx.cfg, make/custom/lpc32xx_mzx_stage_1.cfg,
make/custom/lpc32xx_mzx_stage_2.cfg, misc/boot.c, misc/emc.c,
misc/i2c.c, misc/nand-mlc.c, misc/nand-mlc-read-blocks.c,
misc/nand-mlc-write-blocks.c, misc/restart.c,
startup/linkcmds.lpc32xx, startup/linkcmds.lpc32xx_mzx,
startup/linkcmds.lpc32xx_mzx_stage_1,
startup/linkcmds.lpc32xx_mzx_stage_2: New files.
* configure.ac, Makefile.am, preinstall.am: Reflect changes above.
* include/bsp.h, include/lpc32xx.h, irq/irq.c, rtc/rtc-config.c,
startup/bspstart.c, startup/bspstarthooks.c,
startup/linkcmds.lpc32xx_phycore: Changes throughout.
* make/custom/lpc23xx_tli800.cfg, startup/linkcmds.lpc23xx_tli800: New
files.
* Makefile.am, configure.ac: Reflect changes above.
* startup/linkcmds.lpc2362: Typos.
* README: Documentation.
* shared/startup/linkcmds.base: Define bsp_vector_table_size
unconditionally. Use bsp_vector_table_in_start_section.
PR 1580/misc
* libchip/i2c/spi-sd-card.c: Use bigger chunks and yield processor
while waiting for read data.
PR 1579/misc
* libchip/i2c/spi-sd-card.c: Gradually increasing sleep times when
waiting for write to finish.
PR 1567/misc
* libchip/i2c/spi-sd-card.h, libchip/i2c/spi-sd-card.c: Fixed
timeouts.
* startup/m68k-stub.c: PR 1539. Fix buffer overrun.
* README: Remove more ITRON references.
* shared/comm/GDB.HOWTO: Remove more ITRON references.
PR 1583/bsps
* shared/startup/panic.c: Remove reference to ITRON.
PR 1576/misc
* libchip/i2c/spi-sd-card.c: Enable CRC checks.
PR 1569/misc
* libchip/i2c/spi-sd-card.c: Added CRC checks.
* shared/start/start.S, shared/startup/linkcmds.base,
shared/include/linker-symbols.h: Added and use bsp_vector_table_begin,
bsp_vector_table_size and bsp_vector_table_end.
* .cvsignore: New file.
* .cvsignore, include/.cvsignore: New files.
* Makefile.inc.in, bsp.cfg.in, configure.ac, target.cfg.in:
Remove itron.
* aclocal/check-itron.m4, aclocal/enable-itron.m4: Remove.
* ChangeLog, Makefile.am, acinclude.m4, configure.ac, shared/asm/asm.S,
shared/clock/ckinit.c, shared/console/conscfg.c,
shared/helenos/LICENSE, shared/helenos/README,
shared/helenos/boot/genarch/balloc.c,
shared/helenos/boot/genarch/ofw.c,
shared/helenos/boot/genarch/ofw_tree.c,
shared/helenos/boot/generic/string.c,
shared/helenos/boot/include/align.h,
shared/helenos/boot/include/balloc.h,
shared/helenos/boot/include/gentypes.h,
shared/helenos/boot/include/main.h,
shared/helenos/boot/include/ofw.h,
shared/helenos/boot/include/ofw_tree.h,
shared/helenos/boot/include/ofwarch.h,
shared/helenos/boot/include/register.h,
shared/helenos/boot/include/stack.h,
shared/helenos/boot/include/types.h,
shared/helenos/boot/sparc64/loader/main.c,
shared/helenos/boot/sparc64/loader/ofwarch.c,
shared/helenos/boot/sparc64/loader/ofwasm.S,
shared/helenos/kernel/genarch/include/ofw/ofw_tree.h,
shared/helenos/kernel/generic/include/align.h,
shared/helenos/kernel/sparc64/include/arch.h,
shared/helenos/kernel/sparc64/include/boot.h,
shared/helenos/kernel/sparc64/include/regdef.h,
shared/helenos/kernel/sparc64/include/stack.h,
shared/helenos/kernel/sparc64/include/mm/cache_spec.h,
shared/helenos/kernel/sparc64/include/mm/frame.h,
shared/helenos/kernel/sparc64/include/mm/mmu.h,
shared/helenos/kernel/sparc64/include/mm/page.h,
shared/helenos/kernel/sparc64/include/mm/tlb.h,
shared/helenos/kernel/sparc64/include/mm/tte.h,
shared/helenos/kernel/sparc64/include/mm/sun4u/frame.h,
shared/helenos/kernel/sparc64/include/mm/sun4u/mmu.h,
shared/helenos/kernel/sparc64/include/mm/sun4u/page.h,
shared/helenos/kernel/sparc64/include/mm/sun4u/tlb.h,
shared/helenos/kernel/sparc64/include/mm/sun4u/tte.h,
shared/helenos/kernel/sparc64/include/sun4u/arch.h,
shared/helenos/kernel/sparc64/src/cache.S,
shared/helenos/kernel/sparc64/src/sun4u/takemmu.S,
shared/include/asm.h, shared/include/traptable.h,
shared/start/start.S, shared/start/trap_table.S,
shared/startup/bspgetworkarea.c, shared/startup/bspstart.c,
shared/startup/linkcmds, shared/startup/setvec.c: New files.
