tested that the same file could not be created twice.
joel@OARcorp.com wrote:
> Chris,
> sp09 fails on the rtems_port_delete(0) call. This is supposed to give an
> invalid id error. I can't find any changes other than the unlimited
> objects patch which would have tripped this so would appreciate it if you
> could look into it. I suspect that this is a side-effect of the unlimited
> objects patch.
It is me.
> Basically, there are 0 ports configured in sp09. The test ends up
> dereferecing NULL in local_table[0] and comes up with a non-NULL invalid
> pointer.
The issue is not actually allocating a local_table for an object type
which has a maximum value of 0. I cannot remember the exact workings of
the id values and the local_table. I might have changed the nature from
the pre-unlimited change. As you know the id's are an interesting game
where performance is most important.
> I know the problem could be solved by adding a check for index == 0. But
> I hate to slow this path down. I think you may have changed the way the
> object information structure gets initialized.
---- CVS log ----
This change lets the unlimited and sp09 tests run on the posix Linux
BSP. A static local variable `null_local_table' has been added. This
variable is always set to NULL. The `**local_table' element of the
information structure is set to point to this variable earily in the
initialisation. If the object type has more than 0 elements the
`local_table' element is updated. All object types which have 0 elements
reference `null_local_table'. This change fixes the problem sp09 found
yet does not add any extra processing to the critical
`_Objects_Get_local_object' function.
---- CVS log ----
included and we ended up with undefined references.
sequence.
and _POSIX_signals_Set_process_signals was done twice.
Ian Lance Taylor <ian@airs.com> to note that condition codes
are modified.
register support to this driver.
rtems-rc-19990326-2.diff: Enhancements to autoconf support for librdbg
* autoconf-checks for AWK and RPCGEN
* disable librdbg if either AWK, RPCGEN or librdbg/$target_cpu
cannot be found
releasing a snapshot:
1. Cleanup to aclocal/
cvs rm -f aclocal/cygwin.m4
cvs rm -f aclocal/exeext.m4
2. rtems-rc-19990328-0.diff
Some (minor) bug-fixes:
3. rtems-rc-19990328-1.diff
-ac -am -ci.
(reduces size of configure.in
problem.
Emmanuel Raguet <raguet@crf.canon.fr> to eliminate a problem
during the boot process on the pc386 BSP. On fast PC's the
calibration routine would hand.
Problem: Sometimes the output file "FOO.BT" is smaller that the second
image.
Solution: Opening files, input/output, in "binary mode".
routines.
There seems to be an ugly dependency between posix-headers and
libcsupport.
Configuring rtems with
../rtems-rc-19990324-0/configure \
--target=i386-rtems \
--prefix=<somewhere> \
--disable-posix
"make RTEMS_BSP=pc386" results into:
/opt/rtems/bin/i386-rtems-gcc --pipe
-B/users/rtems/src/multi/build/pc386/lib/ -specs bsp_specs -qrtems
-I/users/rtems/src/multi/build/pc386/lib/include/networking -g -Wall
-ansi -fasm -O4 -fomit-frame-pointer -c -o o-pc386/utime.o
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c
In file included from
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:16:
/opt/rtems/i386-rtems/include/utime.h:4: sys/utime.h: No such file or
directory
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:24: warning:
`struct utimbuf' declared inside parameter list
its scope is only this definition or declaration,
which is probably not what you want.
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c: In function
`utime':
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:34:
dereferencing pointer to incomplete type
make[4]: *** [o-pc386/utime.o] Error 1
make[3]: *** [all] Error 1
make[2]: *** [all] Error 1
make[1]: *** [all] Error 1
make[1]: Leaving directory `/lfs/poseidon/users/rtems/src/multi/build/c'
make: *** [all] Error 1
Apparently sys/utime.h is one of the posix headers and therefore gets
not installed (I suppose this is correct).
IMO, this probably indicates that sys/utime.h has to be moved to another
include subdirectory and should not be part of the posix-package.
[AFAIK, sys/*.h are system dependent headers, so why should it be a
posix-header? - Hmm]
With my most recent automake patch (automake II) we could even simplify more
files below make/, because the host-compiler related parts of those files
aren't used anymore :-.
Whatsoever, the patch below should fix this problem.
Note: This is a mere bug fix, it doesn't move any of the variables involved
to target.cfg nor does it try to eliminate any variable.
interface naming convention.
by Jiri Gaisler <jgais@ws.estec.esa.nl>.
fix some problems encountered when reusing this driver on
a SPARC ERC32 based Tharsys board. He eliminted the need
for TX interrupts and added code that can optionally ensure that
the IP address is 32-bit aligned. He also fixed a handful of
problems that only occured because the 8 Mhz ERC32 was
enough slower than the 100 Mhz PPC603e that timing
issues in this driver were magnified.
network interface names. This change does not introduce any
compatibility problems.
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
issues.
egcs/contrib/egcs_update).
ATTENTION:
* "make RTEMS_BSP=<bsp> dist"
2 lines of code that did not get included when Joel tried to manually
add a rejected patch.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
and automake.
reorg-bsp_specs.sh script.
significantly.
fcntl support and an external fcntl handler for sockets.
Erik Ivanenko pointed out a problem in the ne2000.c driver I
submitted: it did not work correctly with bootp. Here is a patch,
based on a patch he sent me.
are:
