path: root/c/src (follow)
* bsp/virtex4: Move mmu.c to bspsSebastian Huber2018-04-252-568/+1
| | | | | | This patch is a part of the BSP source reorganization. Update #3285.
* bsp/gensh4: Move hw_init.c to bspsSebastian Huber2018-04-252-284/+1
* bsps: Move arm-cp15-set-ttb-entries.c to bspsSebastian Huber2018-04-2410-98/+9
* bsps: Move arm-cp15-set-exception-handler.c to bspsSebastian Huber2018-04-249-64/+8
* bsps: Move arm-a9mpcore-smp.c to bspsSebastian Huber2018-04-245-74/+4
* bsps: Move arm-pl050.c to bspsSebastian Huber2018-04-242-117/+1
* bsps: Move arm-pl011.c to bspsSebastian Huber2018-04-242-92/+1
* bsps: Move arm-pl111-fb.c to bspsSebastian Huber2018-04-243-278/+2
* bsps: Move arm-generic-timer-clock-config.c to bspsSebastian Huber2018-04-242-203/+1
* bsps: Move arm-a9mpcore-clock-config.c to bspsSebastian Huber2018-04-244-215/+3
* bsps: Move armv7m-cpucounter.c to bspsSebastian Huber2018-04-242-54/+1
* bsps: Move bspreset.c to bspsSebastian Huber2018-04-245-42/+4
* bsps/i386: Move shared files to bspsSebastian Huber2018-04-2411-4283/+8
* bsps/m68k: Remove unused filesSebastian Huber2018-04-242-109/+0
* bsps: Move spansionFlash.c to bspsSebastian Huber2018-04-242-478/+1
* bsps: Move intelFlash.c to bspsSebastian Huber2018-04-242-465/+1
* bsps: Move flash.c to bspsSebastian Huber2018-04-243-911/+2
* bsps: Move vpd.c to bspsSebastian Huber2018-04-243-324/+2
* bsps: Move motorola.c to bspsSebastian Huber2018-04-242-433/+1
* bsps: Move residual.c to bspsSebastian Huber2018-04-242-105/+1
* bsps: Move showbats.c to bspsSebastian Huber2018-04-243-53/+2
* bsps: Move ppc-exc-handler-table.c to bspsSebastian Huber2018-04-244-70/+3
* bsps: Move memcpy.c to bspsSebastian Huber2018-04-245-130/+4
* bsps: Move tictac.c to bspsSebastian Huber2018-04-245-36/+4
* bsps: Move uboot_dump_bdinfo.c to bspsSebastian Huber2018-04-242-80/+1
* bsps: Move uboot_getenv.c to bspsSebastian Huber2018-04-243-76/+2
* bsps/powerpc: Move bootloader to bspsSebastian Huber2018-04-2419-12539/+16
| | | | | | | | This bootloader is only used by the motorola_powerpc BSP. This patch is a part of the BSP source reorganization. Update #3285.
* bsps/arm: Remove unused shared/comm/uart.cSebastian Huber2018-04-241-565/+0
* bsps/arm: Move bsp_memory_management_initialize()Sebastian Huber2018-04-242-30/+0
| | | | | | | | This function is only used by the raspberrypi BSP. This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Remove obsolete documentationSebastian Huber2018-04-242-111/+0
* bsps: Remove unmaintained times filesSebastian Huber2018-04-2424-4440/+0
* bsps/lm32: Move shared drivers to bspsSebastian Huber2018-04-2322-3345/+18
* bsps: Move ATA drivers to bspsSebastian Huber2018-04-239-1986/+6
* bsps: Move PCI drivers to bspsSebastian Huber2018-04-2321-4349/+19
* bsps/sh: Move console.c to bspsSebastian Huber2018-04-233-125/+2
* bsps/sh: Move setvec.c to bspsSebastian Huber2018-04-231-55/+0
* bsps/sh: Move bsphwinit.c to bspsSebastian Huber2018-04-235-22/+4
* bsps: Move GDB stubs to bspsSebastian Huber2018-04-2311-5381/+0
* bsps/v850: Move crt1.c to bspsSebastian Huber2018-04-232-26/+1
* bsps/sparc64: Move helenos to bspsSebastian Huber2018-04-2313-2316/+16
* bsps: Move RTC drivers to bspsSebastian Huber2018-04-2329-2341/+15
* bsps: Move legacy network drivers to bspsSebastian Huber2018-04-23116-83020/+51
* bsps: Move interrupt controller support to bspsSebastian Huber2018-04-23116-13267/+95
* bsps: Move SPI drivers to bspsSebastian Huber2018-04-2314-4224/+7
* bsps: Move I2C drivers to bspsSebastian Huber2018-04-2338-6469/+22
* bsps/arm: Remove unused stm32f* filesSebastian Huber2018-04-23311-416553/+0
* bsp/tms570: Move more start to bspsSebastian Huber2018-04-2316-3510/+15
* bsp/gen5200: Move bestcomm to bspsSebastian Huber2018-04-2323-3600/+22
* bsp/atsam: Move libraries to bspsSebastian Huber2018-04-2379-21900/+52
* bsp/altera-cyclone-v: Move hwlib to bspsSebastian Huber2018-04-2312-19191/+10
