* include/Makefile.am: Updated to reflect files merged into newlib.
This resulted in some definitions moving to other files and thus
some secondary effects in RTEMS source code.
* include/unistd.h: Removed. Now use newlib's.
* include/rtems/posix/mqueue.h: Add include of <signal.h>.
* include/rtems/posix/threadsup.h: Add include of <sys/signal.h>
* src/execv.c: Corrected prototype to agree with newlib.
* src/execve.c: Corrected prototype to agree with newlib.
* src/execvp.c: Corrected prototype to agree with newlib.
* src/psignal.c: Rewrote reference to <siginfo.h> in comment since
that file no longer exists.
* src/pthreadkill.c: Added include of <signal.h>.
* src/sigaction.c: Added include of <signal.h>.
* src/sigtimedwait.c: Rewrote reference to <siginfo.h> in comment since
* startup/sbrk.c: Removed. Redundant with shared version.
* configure.in: add lib/libbsp to the GNU canonicalized
subdirectories, remove cfg_subdirs, cfg_subdirs1, hst_subdirs1.
* Makefile.am: remove cfg_subdirs, cfg_subdirs1, hst_subdirs1.
* ChangeLog: Fix typos.
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* ChangeLog: Corrected previous entry to include configure.in.
* configure.in: add tests to the GNU canonicalized subdirectories,
* itrontests.am: Remove DEFS.
* libtests.am: Remove DEFS.
* mptests.am: Remove DEFS.
* psxtests.am: Remove DEFS.
* sample.am: Remove DEFS.
* sptests.am: Remove DEFS.
* tmitrontests.am: Remove DEFS.
* tmtests.am: Remove DEFS.
* configure.in: Replace AC_CONFIG_SUBDIRS with
RTEMS_CONFIG_BUILD_SUBDIRS.
* configure.in: add lib/libcpu to the GNU canonicalized subdirectories,
* configure.in: Remove bogus cfg_subdirs.
* configure.in: add lib to the GNU canonicalized subdirectories,
make the lib directory before configuring lib/.
* configure.in, Makefile.am: add exec to the GNU canonicalized
subdirectories.
* configure.in: add librtems++, libnetworking, librpc, librdb, libmisc,
and libchip to the GNU canonicalized subdirectories.
NOTE: Missed committing as each subdirectory was added (joel).
* configure.in: add librtems++ to the GNU canonicalized subdirectories.
* configure.in: add libnetworking, librpc and librdb to the GNU
* configure.in: add libmisc and libchip to the GNU canonicalized
subdirectories.
* libc/ioman.c: Moved to libfs.
* libc/Makefile.am: Removed ioman.c as part of moving it to libfs.
* libc/base_fs.c: Removed include of imfs.h and reworded comment
to avoid being IMFS specific.
* libc/libio.h: Removed prototype of IMFS_ops since it should
not be in this file.
* libc/mount.c: Removed IMFS specific configuration information.
* libc/unmount.c: Removed include of imfs.h and reworded comment
* psxmount/test.c, psxstat/test.c: Include <imfs.h> to get IMFS_ops.
It was formerly incorrectly prototyped in <libio.h>.
* src/imfs/imfs_config.c: New file containing IMFS configuration
information split from libc/base_fs.c.
* src/imfs/ioman.c: New file. Moved from lib/libc. Missed previously.
* src/imfs/Makefile.am: Added imfs_config.c and ioman.c.
* Makefile.am, acinclude.m4, configure.in: Introduce GNU
canonicalization to libfs/.
The approach is currently a bit of a hack as GNU canonicalization
does not support the per-BSP build some of the other directories
require. As more of the tree is converted, this will become less
of an issue.
* Makefile.am, configure.in: Introduce GNU canonicalization to libfs/.
of an issue.
Joel Sherrill <joel@OARcorp.com>
* This is a major reworking of the mips64orion port to use
gcc predefines as much as possible and a big push to multilib
the mips port. The mips64orion port was copied/renamed to mips
to be more like other GNU tools. Alan did most of the technical
work of determining how to map old macro names used by the mips64orion
port to standard compiler macro definitions. Joel did the merge
with CVS magic to keep individual file history and did the BSP
modifications. Details follow:
* Makefile.am: Made clock and timer subdirectories conditional.
* configure.in: Ditto.
* clock/clock.S: Switch from using <idtmon.h> to <asm.h>.
* clock/gettime.S: Switch from using <idtmon.h> to <asm.h>.
* console/led.S: Switch from using <idtmon.h> to <asm.h>.
* console/start.S: Switch from using <idtmon.h> to <asm.h>. Added
define of PMON stacksize.
* console/idtmem.S: Switch from using <idtmon.h> to <asm.h>. Also
reworked conditionals to use gcc predefines.
* console/idttlb.S: Ditto.
* Makefile.am: idtmon.h in mips64orion port not present.
* asm.h: MIPS64ORION replaced with MIPS. Frame setup macros added.
* cpu.c: Comments added.
* cpu_asm.S: Conditionals changed. MIPS ISA level 1 support added.
First attempt at exception/interrupt processing for ISA level 1
and minus any use of IDT/MON added.
* idtcpu.h: Conditionals changed to use gcc predefines.
* iregdef.h: Ditto.
* cpu_asm.h: No real change. Merger required commit.
* rtems/Makefile.am: Ditto.
* rtems/score/Makefile.am: Ditto.
* rtems/score/cpu.h: Change MIPS64ORION to MIPS.
* rtems/score/mips64orion.h: Change MIPS64ORION to MIPS. Convert
from using RTEMS_CPU_MODEL to gcc predefines to figre things out.
* console/serial_mouse.c: Fixed typos introduced by removal of CR/LF.
* console/serial_mouse.c: Added support for changing serial parameters.
* mpc8xx/console-generic/console-generic.c: Avoid use of
BSP definitions and rely on the new routine
mbx8xx_console_get_configuration() to get information. This
routine was formerly incorrectly called
mbx8xx_console_use_maximum_buffer_size().
binding to the exception code.
* configure.in, Makefile.am: Explicitly specify whether an
RTEMS_CPU_MODEL is using old or new exception processing. This
is important because when building multilib, you do not know
the RTEMS_CPU_MODEL. So everything built in a multilib'ed RTEMS
must be independent of the exception model and allow for late
* console/console.c: Add mbx8xx_console_get_configuration() which
returns either nvram configuration or a static equivalent.
* console/console.c: Invoke BSP_uart_init() with enough arguments
now that more communication parameters are settable.
* shared/ppc.h: For multilibs, derive PPC_HAS_FPU from _SOFT_FLOAT.
* network/dec21140.c: Corrected attach to include "int attach"
parameter.
* include/wd80x3.h: Added file header and logic to prevent multiple
inclusions of this file.
* wd8003/wd8003.c: Corrected attach to include "int attach" parameter.
* include/bsp.h: Cleaned up network driver name and attach defines.
* ne2000/ne2000.c: Fix some errors in the driver.
1. There was no sufficient check of data in ethernet header.
The code in ne_rx_daemon() was:
inport_word (dport, len);
len -= 4;
if (len > 0)
ne_read_data (sc, startaddr, len, p);
Unfortunately, sometimes my NIC gave me too big len value,
the result was memory override. To fix this, I added ethernet
header data checking.
2. The way overrides were serviced was not good. It was complex
but sometimes did not provide reliable continuing of NIC working.
I had the situation of an endless loop in ne_check_status()
after override processing.
3. There was conceptual error of porting. The old method of
overrides curing was ported from the OS-s, where override-processing
did start immediately. But RTEMS-version uses events, and cleaning
of the overrides can start later.
I selected the way of ne2000 programming that is used
in freebsd kernel (v4.0).
Because of both problems, incorrect data in header of raw packet
and receiver override, it went through ne_reset() and fully
reset the ne2000.
So, in summary
- added detecting of the incorrect data in ethernet header;
- replaced handling of receiver overrides with new scheme,
via resetting of NIC, this method is used also in case of
invalid header detecting.
