* preinstall.am: Install spacewire.h
* clock/ckinit.c, include/leon.h, timer/timer.c, amba/amba.c
fixed up merge from 4.6.6. Correct references to
LEON3_IrqCtrl_Regs_Map.mask[x] and LEON3_Timer_Regs_Map.timer[x].
-1 on failure, not just non-zero status. I found that
some driver(s) [e.g. dec21140] explicitely check for -1.
Checked inline assembly code; added 'm' operands and
paranoia 'memory' clobbers. Also, made sure that no
pure input operands are modified by the asm.
(gcc-4.1.1 warns that uint32_t and unsigned int are different).
assembly code; added 'memory' clobbers and made sure
any registers modified by the 'asm' appear in the output
operands.
* amba/amba.c, clock/ckinit.c, include/amba.h, timer/timer.c: Search
for the Timer Register when initializing the amba rather than before
each potential use.
* libchip/shmdr/shm_driver.h: Merge sparc shm driver mods from 4.6.
* Makefile.am, include/leon.h: Try to merge rest of 4.6 BSP changes.
* include/spacewire.h: New file.
* Makefile.am: Merge SHM support from 4.6 branch.
* shmsupp/README, shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c: New files.
* clock/ckinit.c: Actually call the routine to find the LEON3 time.
* leon_greth/.cvsignore, leon_greth/leon_greth.c: New files.
Missed adding in previous commit of merge.
* clock/ckinit.c, timer/timer.c: Make sure LEON3_Timer_Regs is
initialized for the timer driver.
* libchip/Makefile.am, libchip/preinstall.am: Merge SPARC updates from
4.6 branch. Original modifications by Gaisler Enterprises.
* libchip/network/greth.c, libchip/network/greth.h: New files.
* ChangeLog, Makefile.am, clock/ckinit.c, include/amba.h,
include/bsp.h: Merge SPARC updates from 4.6 branch. Original
* Makefile.am: Add ampolish3.
* ampolish3: New.
* aclocal/rtems-ampolish.m4: Reflect using in-sourcetree ampolish3.
* startup/linkcmds, startup/linkcmds-le, startup/linkcmds-le.coff: Add
.rela.dyn sections.
* startup/linkcmds: Add .rela.dyn sections.
* startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Add
.rela.dyn sections.
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add
.rela.dyn sections.
* Makefile.am, README, startup/init5235.c, startup/linkcmds,
startup/linkcmdsflash, startup/linkcmdsram: Modify to the mcf5235
eval boards to either load and run from ram using the dBug moniter as
the boot deviced (Board setup as shipped from the factory), or it
allows the user to Boot his code from flash he loads onto the eval
board. The code changes between the two are based on the selected
linker script using a variable in the script. The options to the
linker are used to override the default linker script and select
which options to configure at boot either from flash, or from ram:
-qnolinkcmds -T linkcmdsflash
If no options are given the standard linker sript assumes dBug was
used to set up the board and the user is going to load his program
to RAM.
PR 1100/bsps
* console/debugputs.c: Remove redundant return.
on-board memory from VME.
the caches against the book and updated 'dssall', 'sync'
and 'isync's accordingly.
the normal scheme of vector = exception # << 8. So we picked
an unused vector number (currently 0xa) where we map the special
vector 0xf20 (altivec).
define BSP_PCI_VME_DRIVER_DOES_EOI and BSP_PIC_DO_EOI.
assigned vector number alias.
constants to pointers). Enable L1 cache on mvme2100.
FPU available (ISR, int-only task) - switch FPU on
for the switch and restore MSR_FP after it's done.
(new gcc may use FP regs implicitely).
* README:
* shared/irq/irq_init.c: Changed interrupt handling
to use shared rtems_irq_connect_data struct.
* startup/linkcmds: Removed unnecessary global definition of
bsp_vector_table.
* times: Reran timing tests and updated 'times' file.
* startup/bspstart.c: Fixed PLL calculations.
* Makefile.am, console/uart.c, startup/exit.c: Changed UART
driver to be interrupt driven, added support for both UARTs.
* mc9328mxl/include/mc9328mxl.h: Added UART register definitions.
* at91rm9200/irq/bsp_irq_init.c, mc9328mxl/clock/clockdrv.c,
mc9328mxl/irq/bsp_irq_asm.S, mc9328mxl/irq/bsp_irq_init.c,
mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
s3c2400/irq/bsp_irq_init.c: Changed interrupt handling
