* configure.ac: Remove references to Templates.
Use local AC_CONFIG_LINKS.
* README: Relocated from make/
* directory.cfg: Ditto.
* lib.cfg: Ditto.
* compilers/gcc-target-default.cfg: Ditto.
* startup/bspstart.c: Add empty H8BD_Install_IRQ so the port will have
a routine to call.
* Makefile.am: Use "'"-quotes to pass args to bsp.mak.
* configure.ac: Use "'"-quotes for args to RTEMS_CONFIG_SUBDIRS.
Fix braino in comment on "exec".
Extend --enable-ada handling.
* startup/bspstart.c: Remove ramStart to eliminate warning.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* src/_servtgt.c: Removed warning by adding support for ITRON
tasks and rolling multiple loops into 1.
* src/m68k/rdbg_f.c: Removed warning.
* console/console.c, network/network.c: Removed warnings.
* irq/irq.c: Removed warnings.
* network/network.c: Removed warnings.
* pppd/auth.c, rtems_webserver/uemf.h: Removed warnings.
* mpc8260/console-generic/console-generic.c, mpc8260/cpm/dpram.c,
mpc8260/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.c: Removed warnings.
* console/i8042.c: Removed warnings.
* console/console.c, irq/irq.c, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, vectors/vectors_init.c:
Removed warnings.
* clock/clock.c: Removed warnings.
* console/console.c: Removed warnings.
* console/sci.c, spurious/spinit.c: Removed warnings.
* console/console.c, i2c/i2cdrv.c, nvram/nvram.c, startup/bspstart.c,
tod/ds1307.c: Removed warnings.
* console/console.c, console/m340uart.c: Removed warnings.
* console/console.c, network/ne2000.c: Removed warnings.
* mongoosev/Makefile.am: TMPINSTALL_FILES -> PREINSTALL_FILES.
* mongoosev/Makefile.am: Merge-in mongoosev/include/Makefile.am.
Install include/mongoose-v.h.
* mongoosev/include/Makefile.am: Remove.
* console/console.c, start/start.c: Removed warnings.
* console/console.c, start/start.c, startup/efi68k_wd.c:
* startup/m68k-stub.c: Removed typos.
* sh7045/score/ispsh7045.c: Fixed typos.
* irq/irq.c, irq/irq_asm.S, startup/bspstart.c: Fixed typos and
removed warnings.
* sh7045/score/cpu_asm.c: Fixed typo.
* delay/delay.c, score/ispsh7032.c: Removed warnings.
* score/cpu_asm.c, score/ispsh7750.c: Removed warnings.
* score/cpu_asm.c, score/ispsh7045.c: Removed warnings.
* mpc8xx/console-generic/console-generic.c, mpc8xx/cpm/dpram.c,
mpc8xx/exceptions/raw_exception.c, ppc403/clock/clock.c:
Removed warnings.
* shared/interrupts/installisrentries.c,
shared/interrupts/vectorexceptions.c: Removed warnings.
* gnatcommon.c: Removed warnings.
* gnatsupp/gnatsupp.c, startup/spurious.c: Removed warnings.
* clock/ckinit.c, console/console.c: Removed warnings.
* gdbsci/gdbsci.c: Removed warnings.
* start/start.S, startup/hw_init.c: Removed warnings.
* cpu.c: Currently only the mpc8260 BSP supports interrupt nesting.
NOTE: These needs to be generalized as the patch is applied to other
BSPs.
* clock/p_clock.c, console/console.c, startup/bspstart.c: Removed
warnings.
* canbus/canbus.c, clock/p_clock.c, console/console.c,
network/network.c, startup/bspstart.c: Removed warnings.
* startup/genpvec.c, tod/todcfg.c: Removed warnings.
* mips-stub.c: Removed warnings.
* startup/bspclean.c, startup/bspstart.c: Removed warnings.
* startup/gdb-support.c, startup/linkcmds: Removed warnings.
* console/conscfg.c, startup/bspstart.c: Removed warnings.
* startup/m68k-stub.c: Removed warnings.
* network/network.c, startup/bspclean.c: Removed warnings.
