path: root/c/src (follow)
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-273-3/+9
| | | | | | * include/Makefile.am: Use 'TMPINSTALL_FILES ='. * cache/Makefile.am: Use 'PREINSTALL_FILES ='. * cache/Makefile.am: Use 'CLEANFILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-2742-21/+105
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-2712-12/+25
| | | | | | | | | | | | | * new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='. * old_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='. * mpc6xx/mmu/Makefile.am: Use 'PREINSTALL_FILES ='. * mpc6xx/clock/Makefile.am: Use 'PREINSTALL_FILES ='. * mpc6xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='. * mpc8xx/include/Makefile.am: Use 'PREINSTALL_FILES ='. * mpc8xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/include/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/src/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/src/Makefile.am: Use 'CLEANFILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-275-5/+13
| | | | | | | | * tx39/include/Makefile.am: Use 'TMPINSTALL_FILES ='. * mongoosev/include/Makefile.am: Use 'TMPINSTALL_FILES ='. * mongoosev/duart/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/cache/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/cache/Makefile.am: Use 'CLEANFILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-2/+7
| | | | | * Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'CLEANFILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-1/+5
| | | | * include/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-273-2/+7
| | | | | * include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * shmdr/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-278-7/+17
| | | | | | | | | | * console/Makefile.am: Use 'PREINSTALL_FILES ='. * residual/Makefile.am: Use 'PREINSTALL_FILES ='. * irq/Makefile.am: Use 'PREINSTALL_FILES ='. * motorola/Makefile.am: Use 'PREINSTALL_FILES ='. * vectors/Makefile.am: Use 'PREINSTALL_FILES ='. * pci/Makefile.am: Use 'PREINSTALL_FILES ='. * openpic/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-277-6/+15
| | | | | | | | | * include/Makefile.am: Use 'PREINSTALL_FILES ='. * residual/Makefile.am: Use 'PREINSTALL_FILES ='. * vectors/Makefile.am: Use 'PREINSTALL_FILES ='. * pci/Makefile.am: Use 'PREINSTALL_FILES ='. * openpic/Makefile.am: Use 'PREINSTALL_FILES ='. * bootloader/Makefile.am: Use 'CLEANFILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-278-6/+18
| | | | | | * include/Makefile.am: Use 'PREINSTALL_FILES ='. * irq/Makefile.am: Use 'PREINSTALL_FILES ='. * vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-2736-35/+124
| | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'TMPINSTALL_FILES ='.
| | | | * Makefile.am: Use 'TMPINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-274-2/+10
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-274-3/+9
| | | | | | * irq/Makefile.am: Use 'PREINSTALL_FILES ='. * comm/Makefile.am: Use 'PREINSTALL_FILES ='. * pci/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-274-4/+11
| | | | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * console/Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'TMPINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-276-6/+18
| | | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'TMPINSTALL_FILES ='. * irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-275-3/+12
| | | | | * include/Makefile.am: Use 'PREINSTALL_FILES ='. * startup/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-278-4/+20
* 2001-09-27 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-09-271-2/+0
| | | | | | | * hared/bootcard.c: Now process C++ global constructors (_init) as part of the first task execution not in BSP space. This depends on the toolset defining USE_INIT_FINI so you have to have the right toolset version.
* 2001-09-27 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-09-272-0/+27
| | | | | | | * src/threadhandler.c: Now process C++ global constructors (_init) as part of the first task execution not in BSP space. This depends on the toolset defining USE_INIT_FINI so you have to have the right toolset version.
* 2001-09-27 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-09-274-48/+224
| | | | | * lib/tftpDriver.c: Add limited chdir() support to the TFTP filesystem.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-1/+5
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-1/+3
| | | | | * libtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy. * rtems++/Makefile.am: LD_FLAGS = -lrtems++.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-2722-20/+50
| | | | | | | | | | | | | | | * machine/Makefile.am: Use 'PREINSTALL_FILES ='. * net/Makefile.am: Use 'PREINSTALL_FILES ='. * netinet/Makefile.am: Use 'PREINSTALL_FILES ='. * vm/Makefile.am: Use 'PREINSTALL_FILES ='. * pppd/Makefile.am: Use 'PREINSTALL_FILES ='. * sys/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_servers/Makefile.am: Use 'PREINSTALL_FILES ='. * arpa/Makefile.am: Use 'PREINSTALL_FILES ='. * nfs/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_webserver/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-278-7/+17
| | | | | | | | | | | * include/rdbg/i386/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rdbg/m68k/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rdbg/powerpc/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rdbg/Makefile.am: Use 'PREINSTALL_FILES ='. * src/i386/any/Makefile.am: Use 'PREINSTALL_FILES ='. * src/m68k/any/Makefile.am: Use 'PREINSTALL_FILES ='. * src/powerpc/new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-2744-30/+105
| | | | | * rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'PREINSTALL_FILES ='.
| | | | * shared/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-276-5/+13
| | | | | | | | * include/itronsys/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
| | | | | | | | * include/sys/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-3/+9
| | | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'TMPINSTALL_FILES ='. * include/Makefile.am: fix path to shared/include/coverhd.h.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-244-6/+13
| | | | | | | * src/i386/any/Makefile.am: Move MAINTAINERCLEANFILES before the includes and use MAINTAINERCLEANFILES = to make automake-1.5 happy. * src/m68k/any/Makefile.am: Ditto. * src/powerpc/new_exception_processing/Makefile.am: Ditto.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-244-2/+10
| | | | * Makefile.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-244-2/+12
| | | | | * src/imfs/Makefile.am: Revamp INCLUDES handling to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-1/+5
| | | | * tmtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
| | | | * tmitrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
| | | | * sptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-241-2/+0
| | | | | | * minimum/Makefile.am: Fix comments to make automake-1.5 happy. * sample.am: Use TMPINSTALL_FILES = to make automake-1.5 happy. * cdtest/Makefile.am: Remove LD_LIBS.
| | | | * psxtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
| | | | * mptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-243-3/+6
| | | | | * libtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy. * rtems++/Makefile: Remove LD_LIBS.
| | | | * itrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-241-1/+1
| | | | | | | | * Makefile.am: Use SUBDIRS = instead of SUBDIRS += to make automake-1.5 happy. * include/rtems/score/Makefile.am: Use CLEANFILES = to make automake-1.5 happy. * bsp.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-248-4/+23
| | | | * wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-2/+7
| | | | | * include/sys/Makefile.am: Use = instead of += to setup NETWORKING_H_FILES and NEWLIB_H_FILES.
