* | bsps/sparc: Make local functions for amba plug&play static. | Daniel Cederman | 2014-03-24 | 5 | -12/+10 |
* | bsps/sparc: Add common gnat handler function prototype. | Daniel Cederman | 2014-03-24 | 12 | -6/+42 |
| | | | | Moved prototype for __gnat_install_handler and __gnat_install_handler_common to common header file. Placed header file in bsp namespace. | ||||
* | greth: Make local functions static, remove overflow and correct printf call. | Daniel Cederman | 2014-03-21 | 2 | -7/+9 |
* | bsps/sparc: Change asm to __asm__ to compile with -pedantic. | Daniel Cederman | 2014-03-21 | 3 | -6/+6 |
* | bsps/sparc: Make spurious trap handler function static. | Daniel Cederman | 2014-03-21 | 3 | -3/+3 |
* | bsps/sparc: Make local functions static. | Daniel Cederman | 2014-03-21 | 9 | -4/+32 |
| | | | | | | | The PCI and RASTA versions of the uart, spacewire and 1553 drivers directly includes the c-file of the standard versions of the drivers, but uses a macro to change the name of the driver register function. When the standard version is used this function should be global, when it is included as part of the PCI and RASTA versions it should be local and static. | ||||
* | smc91111: Move driver attach prototype to header file. | Daniel Cederman | 2014-03-21 | 5 | -16/+8 |
| | | | | Also signal to compiler that the start variable in lan91cxx_recv is only used when debugging. | ||||
* | no_bsp/shmsupp/lock.c: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -2/+4 |
* | no_bsp/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -10/+3 |
* | nios2_iss/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -10/+0 |
* | moxiesim/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -9/+0 |
* | sim68000/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -17/+0 |
* | ods68302/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -17/+3 |
* | mvme136/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -16/+0 |
* | mrm332/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -17/+3 |
* | gen68360/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -16/+0 |
* | gen68340/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -16/+0 |
* | gen68302/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -22/+1 |
* | m32rsim/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -17/+0 |
* | m32cbsp/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -17/+0 |
* | lm32_evr/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -15/+1 |
* | pc386/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -16/+0 |
* | h8sim/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -16/+0 |
* | gensh1/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -10/+2 |
* | gensh2/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -10/+2 |
* | gensh4/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -10/+2 |
* | shsim/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -12/+2 |
* | usiii/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -17/+0 |
* | niagara/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -17/+0 |
* | gba/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -12/+0 |
* | avrtest/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -17/+0 |
* | eZKit533/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -9/+0 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 1963 | -1982/+1982 |
* | libchip: Relax buffer counts and add fatal error | Ralf Kirchner | 2014-03-14 | 2 | -3/+17 |
* | bsps/arm: Add DP83848 PHY support to LPC Ethernet | Pavel Pisa | 2014-03-14 | 1 | -0/+8 |
* | bsps/arm: Add PHY detection to LPC Ethernet | Pavel Pisa | 2014-03-14 | 1 | -13/+45 |
* | bsps/arm: Reset MII management in LPC Ethernet | Pavel Pisa | 2014-03-14 | 1 | -1/+7 |
| | | | | Reduce MII clock to support LPC17XX. | ||||
* | bsp/lpc24xx: Add LPC24XX_PIN_ETHERNET_POWER_DOWN | Pavel Pisa | 2014-03-14 | 2 | -0/+15 |
* | bsp/lpc24xx: Add lpc24xx_pin_get_first_index() | Sebastian Huber | 2014-03-14 | 1 | -0/+10 |
* | bsps/powerpc: Add support for interrupt profiling | Sebastian Huber | 2014-03-14 | 1 | -2/+51 |
* | bsps/leon3: Add interrupt delay profiling support | Sebastian Huber | 2014-03-14 | 1 | -1/+38 |
* | sparc: Add support for interrupt profiling | Sebastian Huber | 2014-03-14 | 1 | -2/+23 |
* | score: Add SMP lock profiling support | Sebastian Huber | 2014-03-14 | 1 | -1/+2 |
* | libchip: Include <bsp.h> BSP options definition | Sebastian Huber | 2014-03-14 | 1 | -2/+2 |
* | libchip: Check interrupt extension availability | Sebastian Huber | 2014-03-13 | 1 | -0/+13 |
* | libchip: Avoid <bsp/utility.h> | Sebastian Huber | 2014-03-13 | 2 | -578/+612 |
* | bsp/altera-cyclone-v: Made hwlib compile clean | Ralf Kirchner | 2014-03-13 | 3 | -281/+6 |
| | | | | Made Alteras hwlib compile clean within the RTEMS build system | ||||
* | bsp/altera-cyclone-v: Add Alteras hwlib | Ralf Kirchner | 2014-03-13 | 23 | -0/+71250 |
| | | | | Add files from Alteras hwlib | ||||
* | bsp/altera-cyclone-v: New BSP | Ralf Kirchner | 2014-03-13 | 22 | -0/+2544 |
| | | | | | | | | | | | | | Implemented so far: - nocache heap for uncached RAM - basic timer - level 1 cache handling for arm cache controller in arm-cache-l1.h - level 2 L2C-310 cache controller - MMU - DWMAC 1000 ethernet controller - basic errata handling - smp startup for second core | ||||
* | libchip: Add dwmac 10/100/1000 network driver | Ralf Kirchner | 2014-03-13 | 16 | -1/+6540 |
