path: root/c/src (follow)
* bsp/xilinx-zynqmp: Stub out Xilinx MPSoC BSPJeff Kubascik2019-04-112-0/+228
| | | | | | Source files were copied from xilinx-zynq. Update #3682.
* bsp/zynq-uart: Move Zynq UART driver to shared directoryJeff Kubascik2019-04-111-1/+1
| | | | | | This driver will be shared with the xilinx-zynqmp BSP. Update #3682.
* bsp/lpc24xx: Convert I2C driver to Linux APISebastian Huber2019-03-151-1/+0
| | | | | | Change license to BSD-2-Clause. Close #3725.
* bsp/altera-cyclone-v: Move header fileSebastian Huber2019-02-271-2/+0
| | | | This gets rid of a special include path.
* arm/beagle: SPI driverPierre-Louis Garnier2019-02-271-0/+3
* bsp/altera-cyclone-v: Use FDT for clock frequencySebastian Huber2019-02-181-3/+2
* bsp/altera-cyclone-v: Make FDT support optionalSebastian Huber2019-02-181-0/+3
* riscv: add griscv bspJiri Gaisler2019-01-224-2/+114
| | | | Update #3678.
* grlib: Move source filesSebastian Huber2019-01-222-203/+3
| | | | Update #3678.
* bsps/arm: Add ARMv7-AR disable data cacheSebastian Huber2018-12-214-0/+4
| | | | Close #3667.
* build: Remove ampolish3Sebastian Huber2018-12-143-16/+0
| | | | Update #3254.
* Simplify _CPU_Counter_difference()Sebastian Huber2018-12-071-1/+0
| | | | | | | | | | | | | | In order to simplify the use of CPU counter values it is beneficial to have monotonic increasing values within the range of the CPU counter ticks data type, e.g. 32-bit unsigned integer. This eases the use of CPU counter timestamps in external tools which do not know the details of the CPU counter hardware. The CPU counter is the fastest way to get a time on an RTEMS system. Such a CPU counter may be also used as the timecounter. Use it on SPARC for this purpose to simplify the clock drivers. Update #3456.
* bsps/x86_64: Use interrupt stack for init stackSebastian Huber2018-11-191-2/+5
| | | | Update #3459.
* bsps/powerpc: Use interrupt stack for init stackSebastian Huber2018-11-195-16/+20
| | | | | | Move start.o to separate file. Update #3459.
* m32c: Remove this targetSebastian Huber2018-11-127-95/+1
| | | | Update #3599.
* bsp/realview-pbx-a9: Fix printk() supportSebastian Huber2018-11-071-0/+1
| | | | | Avoid dependencies on the Termios support in case only printk() is used by the application.
* bsp/imx: Adjust workspace according to device treeSebastian Huber2018-10-241-1/+0
* check-networking.m4: Disable legacy stack for x86_64 and epiphanyJoel Sherrill2018-10-181-1/+5
| | | | | x86_64 is 64-bits and too new for the legacy stack to support. epiphany is a small target and cannot compile the legacy (or new) stack.
* build: Remove specialized CPPFLAGSSebastian Huber2018-10-154-5/+0
| | | | Close #3375.
* build: Remove local.amSebastian Huber2018-10-10109-111/+0
* leon, spwtdp: Initial driver commitJavier Jalle2018-10-092-0/+9
* bsps/mips: Remove unused command line definesSebastian Huber2018-10-043-3/+0
| | | | Update #3375.
* bsp/imx: Add imx_ccm_sdhci_hz()Sebastian Huber2018-09-271-0/+2
| | | | Update #3525.
* clang: Keep -qrtems and -B for compilers without -specs supportJacob Hansen2018-09-201-2/+4
| | | | | | | | | This is needed for building rtems correctly with Clang. Note that this change does not mean rtems can build correctly with mainline clang. However the change allows building rtems with a Clang toolchain that has a rtems frontend similar that of GCC's builtin rtems specs.
* bsp/tqm8xx: Remove unused filesSebastian Huber2018-09-171-1/+0
| | | | Close #3513.
* bsp/tqm8xx: Convert console to new Termios APISebastian Huber2018-09-171-0/+1
| | | | Update #3513.
* bsps: BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGINSebastian Huber2018-09-033-9/+0
| | | | | | | Remove the BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN hack. The interrupt stacks are now allocated by the linker. Update #3459.
* Remove bsps/sparc64/shared/helenos/boot/generic/string.cJoel Sherrill2018-08-292-2/+0
* bsps/x86_64: Add APIC timer based clock driverAmaan Cheval2018-08-131-1/+3
| | | | | | | | | The APIC timer is calibrated by running the i8254 PIT for a fraction of a second (determined by PIT_CALIBRATE_DIVIDER) and counting how many times the APIC counter has ticked. The calibration can be run multiple times (determined by APIC_TIMER_NUM_CALIBRATIONS) and averaged out. Updates #2898.
* bsps/x86_64: Add support for RTEMS interruptsAmaan Cheval2018-08-131-0/+4
| | | | Updates #2898.
* bsps/x86_64: Add paging support with 1GiB super pagesAmaan Cheval2018-08-131-0/+1
| | | | Updates #2898.
* bsps/sparc: Move polled APBUART functionsSebastian Huber2018-08-101-3/+2
| | | | This reduces the link-time dependencies and avoids copy-and-paste.
* bsps: Fix the generic IRQ supportSebastian Huber2018-08-031-1/+5
| | | | | | | | | The genmcf548x partly uses is own implementation of the interrupt extension API for libbsd support. This patch is a part of the BSP source reorganization. Update #3285.
* bsp/riscv: Use CPU counter btimerSebastian Huber2018-07-251-1/+1
| | | | Update #3433.
* bsp/riscv: Add basic SMP startupSebastian Huber2018-07-251-1/+1
| | | | Update #3433.
* bsps/riscv: Update linker-symbols.hSebastian Huber2018-07-251-1/+0
| | | | Update #3433.
* bsp/riscv: Disable HTIF support by defaultSebastian Huber2018-07-251-2/+2
| | | | | | The HTIF is a legacy machinery. Update #3433.
* riscv: Rework exception handlingSebastian Huber2018-07-252-1/+4
| | | | | | | | | | | Remove _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector() functions. Applications can install an exception handler via the fatal error handler to handle synchronous exceptions. Handle interrupt exceptions via _RISCV_Interrupt_dispatch() which must be provided by the BSP. Update #3433.
* x86_64/console: Add NS16550 polled console driverAmaan Cheval2018-07-111-0/+2
| | | | | | This addition allows us to successfully run the sample hello.exe test. Updates #2898.
* bsp/x86_64: Minimal bootable BSPAmaan Cheval2018-07-116-0/+97
| | | | | | | | | | | | | | | | Current state: - Basic context initialization and switching code. - Stubbed console (empty functions). - Mostly functional linker script (may need tweaks if we ever want to move away from the large code model (see: CPU_CFLAGS). - Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for UEFI-awareness. In short, the current state with this commit lets us boot, go through the system initialization functions, and then call user application's Init task too. Updates #2898.
* bsp/riscv: Add console support for NS16550 devicesSebastian Huber2018-07-061-0/+6
| | | | Update #3433.
* bsp/riscv: Add device tree support for consoleSebastian Huber2018-06-282-5/+7
| | | | Update #3433.
* bsp/riscv: Add device tree supportSebastian Huber2018-06-282-0/+13
| | | | Update #3433.
* riscv: Add dummy SMP supportSebastian Huber2018-06-281-0/+3
| | | | Update #3433.
* build: Enable RISC-V SMP buildSebastian Huber2018-06-281-1/+1
| | | | Update #3433.
* bsp/riscv: Add BSP options to define RAM regionSebastian Huber2018-06-271-2/+24
| | | | Update #3433.
* bsp/riscv: Remove unused BSP optionsSebastian Huber2018-06-271-10/+0
| | | | Update #3433.
* bsp/riscv_generic: Rename to "riscv"Sebastian Huber2018-06-273-12/+12
| | | | Update #3433.
* bsp/riscv_generic: New linker command fileSebastian Huber2018-06-271-0/+1
| | | | | | | This linker command file is based on the "riscv64-rtems5-ld --verbose" output. Update #3433.
* Rework initialization and interrupt stack supportSebastian Huber2018-06-274-22/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Statically initialize the interrupt stack area (_Configuration_Interrupt_stack_area_begin, _Configuration_Interrupt_stack_area_end, and _Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the interrupt stack area in a special section ".rtemsstack.interrupt". Let BSPs define the optimal placement of this section in their linker command files (e.g. in a fast on-chip memory). This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the low level initialization code has all information available via global symbols. This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define superfluous, since the interrupt stacks are allocated by confdefs.h for all architectures. There is no need for BSP-specific linker command file magic (except the section placement), see previous ARM linker command file as a bad example. Remove _CPU_Install_interrupt_stack(). Initialize the hardware interrupt stack in _CPU_Initialize() if necessary (e.g. m68k_install_interrupt_stack()). The optional _CPU_Interrupt_stack_setup() is still useful to customize the registration of the interrupt stack area in the per-CPU information. The initialization stack can reuse the interrupt stack, since * interrupts are disabled during the sequential system initialization, and * the boot_card() function does not return. This stack resuse saves memory. Changes per architecture: arm: * Mostly replace the linker symbol based configuration of stacks with the standard <rtems/confdefs.h> configuration via CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND mode stack is still defined via linker symbols. These modes are rarely used in applications and the default values provided by the BSP should be sufficient in most cases. * Remove the bsp_processor_count linker symbol hack used for the SMP support. This is possible since the interrupt stack area is now allocated by the linker and not allocated from the heap. This makes some configure.ac stuff obsolete. Remove the now superfluous BSP variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp. bfin: * Remove unused magic linker command file allocation of initialization stack. Maybe a previous linker command file copy and paste problem? In the start.S the initialization stack is set to a hard coded value. lm32, m32c, mips, nios2, riscv, sh, v850: * Remove magic linker command file allocation of initialization stack. Reuse interrupt stack for initialization stack. m68k: * Remove magic linker command file allocation of initialization stack. Reuse interrupt stack for initialization stack. powerpc: * Remove magic linker command file allocation of initialization stack. Reuse interrupt stack for initialization stack. * Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt stack on BSPs using the shared linkcmds.base (replacement for REGION_RWEXTRA). sparc: * Remove the hard coded initialization stack. Use the interrupt stack for the initialization stack on the boot processor. This saves 16KiB of RAM. Update #3459.
