path: root/c/src (follow)
* 2011-02-21 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-02-212-1/+5
| | | | * timer/timer.c: Include <bsp.h> before <rtems/btimer.h>.
* 2011-02-21 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-02-214-0/+52
| | | | | | * misc/restart.c: New file. * Makefile.am: Reflect change from above. * include/bsp.h: Declare bsp_restart().
* Typo.Sebastian Huber2011-02-211-1/+1
* 2010-02-21 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-02-213-8/+16
| | | | | * include/bsp.h, lpc32xx/misc/restart.c: Renamed lpc32xx_restart() in bsp_restart().
* 2011-02-17 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2011-02-175-326/+442
| | | | | | | | | PR 1738/bsps * README, startup/bspstart.c, startup/linkcmds: Add support for dynamic clock speed determination. This algorithm is described in the README file. The output of the RTEMS Timing Tests was moved to TIMES to signicantly shrink the README. * TIMES: New file.
* 2011-02-17 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-02-172-70/+85
| | | | | | * new-exceptions/bspsupport/vectors.h: Added defines PPC_EXC_GPR_TYPE, PPC_EXC_GPR_SIZE, PPC_EXC_GPR_OFFSET, PPC_EXC_MINIMAL_FRAME_SIZE, and PPC_EXC_FRAME_SIZE. Changed layout of BSP_Exception_frame.
* 2011-02-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-172-0/+12
| | | | * new-exceptions/bspsupport/vectors.h: Add extern "C" {}.
* 2011-02-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-16228-2636/+2832
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ada-tests/mptests/mp01/mp01.adb, ada-tests/mptests/mp01/mptest.adb, ada-tests/mptests/mp01/mptest.ads, ada-tests/mptests/mp01/node1/mp01_node1.adb, ada-tests/mptests/mp01/node2/mp01_node2.adb, ada-tests/mptests/mp02/mptest.adb, ada-tests/mptests/mp02/mptest.ads, ada-tests/mptests/mp02/node1/mp02_node1.adb, ada-tests/mptests/mp02/node2/mp02_node2.adb, ada-tests/mptests/mp03/mptest.adb, ada-tests/mptests/mp03/mptest.ads, ada-tests/mptests/mp03/node1/mp03_node1.adb, ada-tests/mptests/mp03/node2/mp03_node2.adb, ada-tests/mptests/mp04/mptest.adb, ada-tests/mptests/mp04/mptest.ads, ada-tests/mptests/mp04/node1/mp04_node1.adb, ada-tests/mptests/mp04/node2/mp04_node2.adb, ada-tests/mptests/mp05/mptest.adb, ada-tests/mptests/mp05/mptest.ads, ada-tests/mptests/mp05/node1/mp05_node1.adb, ada-tests/mptests/mp05/node2/mp05_node2.adb, ada-tests/mptests/mp06/mptest.adb, ada-tests/mptests/mp06/mptest.ads, ada-tests/mptests/mp06/node1/mp06_node1.adb, ada-tests/mptests/mp06/node2/mp06_node2.adb, ada-tests/mptests/mp07/mptest.adb, ada-tests/mptests/mp07/mptest.ads, ada-tests/mptests/mp07/node1/mp07_node1.adb, ada-tests/mptests/mp07/node2/mp07_node2.adb, ada-tests/mptests/mp08/mptest.adb, ada-tests/mptests/mp08/mptest.ads, ada-tests/mptests/mp08/node1/mp08_node1.adb, ada-tests/mptests/mp08/node2/mp08_node2.adb, ada-tests/mptests/mp09/mptest.adb, ada-tests/mptests/mp09/mptest.ads, ada-tests/mptests/mp09/node1/mp09_node1.adb, ada-tests/mptests/mp09/node2/mp09_node2.adb, ada-tests/mptests/mp10/mptest.adb, ada-tests/mptests/mp10/mptest.ads, ada-tests/mptests/mp10/node1/mp10_node1.adb, ada-tests/mptests/mp10/node2/mp10_node2.adb, ada-tests/mptests/mp11/mptest.adb, ada-tests/mptests/mp11/mptest.ads, ada-tests/mptests/mp11/node1/mp11_node1.adb, ada-tests/mptests/mp11/node2/mp11_node2.adb, ada-tests/mptests/mp12/mptest.adb, ada-tests/mptests/mp12/mptest.ads, ada-tests/mptests/mp12/node1/mp12_node1.adb, ada-tests/mptests/mp12/node2/mp12_node2.adb, ada-tests/mptests/mp13/mptest.adb, ada-tests/mptests/mp13/mptest.ads, ada-tests/mptests/mp13/node1/mp13_node1.adb, ada-tests/mptests/mp13/node2/mp13_node2.adb, ada-tests/mptests/mp14/mptest.adb, ada-tests/mptests/mp14/mptest.ads, ada-tests/mptests/mp14/node1/mp14_node1.adb, ada-tests/mptests/mp14/node2/mp14_node2.adb, ada-tests/samples/base_mp/mptest.adb, ada-tests/samples/base_mp/mptest.ads, ada-tests/samples/base_sp/base_sp.adb, ada-tests/samples/base_sp/sptest.adb, ada-tests/samples/base_sp/sptest.ads, ada-tests/samples/hello/hello.adb, ada-tests/samples/hello/sptest.adb, ada-tests/samples/hello/sptest.ads, ada-tests/samples/nsecs/nsecs.adb, ada-tests/samples/nsecs/sptest.adb, ada-tests/samples/nsecs/sptest.ads, ada-tests/samples/ticker/sptest.adb, ada-tests/samples/ticker/sptest.ads, ada-tests/samples/ticker/ticker.adb, ada-tests/sptests/sp01/sp01.adb, ada-tests/sptests/sp01/sptest.adb, ada-tests/sptests/sp01/sptest.ads, ada-tests/sptests/sp02/sp02.adb, ada-tests/sptests/sp02/sptest.adb, ada-tests/sptests/sp02/sptest.ads, ada-tests/sptests/sp03/sp03.adb, ada-tests/sptests/sp03/sptest.adb, ada-tests/sptests/sp03/sptest.ads, ada-tests/sptests/sp04/sp04.adb, ada-tests/sptests/sp04/sptest.adb, ada-tests/sptests/sp04/sptest.ads, ada-tests/sptests/sp05/sp05.adb, ada-tests/sptests/sp05/sptest.adb, ada-tests/sptests/sp05/sptest.ads, ada-tests/sptests/sp06/sp06.adb, ada-tests/sptests/sp06/sptest.adb, ada-tests/sptests/sp06/sptest.ads, ada-tests/sptests/sp07/sp07.adb, ada-tests/sptests/sp07/sptest.adb, ada-tests/sptests/sp07/sptest.ads, ada-tests/sptests/sp08/sp08.adb, ada-tests/sptests/sp08/sptest.adb, ada-tests/sptests/sp08/sptest.ads, ada-tests/sptests/sp09/sp09.adb, ada-tests/sptests/sp09/sptest.adb, ada-tests/sptests/sp09/sptest.ads, ada-tests/sptests/sp11/sp11.adb, ada-tests/sptests/sp11/sptest.adb, ada-tests/sptests/sp11/sptest.ads, ada-tests/sptests/sp12/sp12.adb, ada-tests/sptests/sp12/sptest.adb, ada-tests/sptests/sp12/sptest.ads, ada-tests/sptests/sp13/sp13.adb, ada-tests/sptests/sp13/sptest.adb, ada-tests/sptests/sp13/sptest.ads, ada-tests/sptests/sp14/sp14.adb, ada-tests/sptests/sp14/sptest.adb, ada-tests/sptests/sp14/sptest.ads, ada-tests/sptests/sp15/sp15.adb, ada-tests/sptests/sp15/sptest.adb, ada-tests/sptests/sp15/sptest.ads, ada-tests/sptests/sp16/sp16.adb, ada-tests/sptests/sp16/sptest.adb, ada-tests/sptests/sp16/sptest.ads, ada-tests/sptests/sp17/sp17.adb, ada-tests/sptests/sp17/sptest.adb, ada-tests/sptests/sp17/sptest.ads, ada-tests/sptests/sp19/sp19.adb, ada-tests/sptests/sp19/sptest.adp, ada-tests/sptests/sp19/sptest.ads, ada-tests/sptests/sp20/sp20.adb, ada-tests/sptests/sp20/sptest.adb, ada-tests/sptests/sp20/sptest.ads, ada-tests/sptests/sp22/sp22.adb, ada-tests/sptests/sp22/sptest.adb, ada-tests/sptests/sp22/sptest.ads, ada-tests/sptests/sp23/sp23.adb, ada-tests/sptests/sp23/sptest.adb, ada-tests/sptests/sp23/sptest.ads, ada-tests/sptests/sp24/sp24.adb, ada-tests/sptests/sp24/sptest.adb, ada-tests/sptests/sp24/sptest.ads, ada-tests/sptests/sp25/sp25.adb, ada-tests/sptests/sp25/sptest.adb, ada-tests/sptests/sp25/sptest.ads, ada-tests/support/test_support.adb, ada-tests/tmtests/tm01/tm01.adb, ada-tests/tmtests/tm01/tmtest.adb, ada-tests/tmtests/tm01/tmtest.ads, ada-tests/tmtests/tm02/tm02.adb, ada-tests/tmtests/tm02/tmtest.adb, ada-tests/tmtests/tm02/tmtest.ads, ada-tests/tmtests/tm03/tm03.adb, ada-tests/tmtests/tm03/tmtest.adb, ada-tests/tmtests/tm03/tmtest.ads, ada-tests/tmtests/tm04/tm04.adb, ada-tests/tmtests/tm04/tmtest.adb, ada-tests/tmtests/tm04/tmtest.ads, ada-tests/tmtests/tm05/tm05.adb, ada-tests/tmtests/tm05/tmtest.adb, ada-tests/tmtests/tm05/tmtest.ads, ada-tests/tmtests/tm06/tm06.adb, ada-tests/tmtests/tm06/tmtest.adb, ada-tests/tmtests/tm06/tmtest.ads, ada-tests/tmtests/tm07/tm07.adb, ada-tests/tmtests/tm07/tmtest.adb, ada-tests/tmtests/tm07/tmtest.ads, ada-tests/tmtests/tm08/tm08.adb, ada-tests/tmtests/tm08/tmtest.adb, ada-tests/tmtests/tm08/tmtest.ads, ada-tests/tmtests/tm09/tm09.adb, ada-tests/tmtests/tm09/tmtest.adb, ada-tests/tmtests/tm09/tmtest.ads, ada-tests/tmtests/tm10/tm10.adb, ada-tests/tmtests/tm10/tmtest.adb, ada-tests/tmtests/tm10/tmtest.ads, ada-tests/tmtests/tm11/tm11.adb, ada-tests/tmtests/tm11/tmtest.adb, ada-tests/tmtests/tm11/tmtest.ads, ada-tests/tmtests/tm12/tm12.adb, ada-tests/tmtests/tm12/tmtest.adb, ada-tests/tmtests/tm12/tmtest.ads, ada-tests/tmtests/tm13/tm13.adb, ada-tests/tmtests/tm13/tmtest.adb, ada-tests/tmtests/tm13/tmtest.ads, ada-tests/tmtests/tm14/tm14.adb, ada-tests/tmtests/tm14/tmtest.adb, ada-tests/tmtests/tm14/tmtest.ads, ada-tests/tmtests/tm15/tm15.adb, ada-tests/tmtests/tm15/tmtest.adb, ada-tests/tmtests/tm15/tmtest.ads, ada-tests/tmtests/tm16/tm16.adb, ada-tests/tmtests/tm16/tmtest.adb, ada-tests/tmtests/tm16/tmtest.ads, ada-tests/tmtests/tm17/tm17.adb, ada-tests/tmtests/tm17/tmtest.adb, ada-tests/tmtests/tm17/tmtest.ads, ada-tests/tmtests/tm18/tm18.adb, ada-tests/tmtests/tm18/tmtest.adb, ada-tests/tmtests/tm18/tmtest.ads, ada-tests/tmtests/tm19/tm19.adb, ada-tests/tmtests/tm19/tmtest.adb, ada-tests/tmtests/tm19/tmtest.ads, ada-tests/tmtests/tm20/tm20.adb, ada-tests/tmtests/tm20/tmtest.adb, ada-tests/tmtests/tm20/tmtest.ads, ada-tests/tmtests/tm21/tm21.adb, ada-tests/tmtests/tm21/tmtest.adb, ada-tests/tmtests/tm21/tmtest.ads, ada-tests/tmtests/tm22/tm22.adb, ada-tests/tmtests/tm22/tmtest.adb, ada-tests/tmtests/tm22/tmtest.ads, ada-tests/tmtests/tm23/tm23.adb, ada-tests/tmtests/tm23/tmtest.adb, ada-tests/tmtests/tm23/tmtest.ads, ada-tests/tmtests/tm24/tm24.adb, ada-tests/tmtests/tm24/tmtest.adb, ada-tests/tmtests/tm24/tmtest.ads, ada-tests/tmtests/tm25/tm25.adb, ada-tests/tmtests/tm25/tmtest.adb, ada-tests/tmtests/tm25/tmtest.ads, ada-tests/tmtests/tm28/tm28.adb, ada-tests/tmtests/tm28/tmtest.adb, ada-tests/tmtests/tm28/tmtest.ads, ada-tests/tmtests/tm29/tm29.adb, ada-tests/tmtests/tm29/tmtest.adb, ada-tests/tmtests/tm29/tmtest.ads, ada-tests/tmtests/tmck/tmck.adb, ada-tests/tmtests/tmck/tmtest.adb, ada-tests/tmtests/tmck/tmtest.ads, ada-tests/tmtests/tmoverhd/dummy_rtems.adb, ada-tests/tmtests/tmoverhd/dummy_rtems.ads, ada-tests/tmtests/tmoverhd/tmoverhd.adb, ada-tests/tmtests/tmoverhd/tmtest.adb, ada-tests/tmtests/tmoverhd/tmtest.ads: Account for RTEMS binding child package rework. Eliminate all warnings.
* 2011-02-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-1642-3212/+4442
| | | | | | | | | | | | | | | | | | | | | * ada/Makefile.am, ada/preinstall.am, ada/rtems.adb, ada/rtems.ads: Split RTEMS Ada95 binding into a master package and a child package per Manager. This is better Ada style. * ada/rtems-barrier.adb, ada/rtems-barrier.ads, ada/rtems-clock.adb, ada/rtems-clock.ads, ada/rtems-cpu_usage.ads, ada/rtems-debug.adb, ada/rtems-debug.ads, ada/rtems-event.adb, ada/rtems-event.ads, ada/rtems-extension.adb, ada/rtems-extension.ads, ada/rtems-fatal.adb, ada/rtems-fatal.ads, ada/rtems-interrupt.ads, ada/rtems-io.adb, ada/rtems-io.ads, ada/rtems-message_queue.adb, ada/rtems-message_queue.ads, ada/rtems-object.adb, ada/rtems-object.ads, ada/rtems-partition.adb, ada/rtems-partition.ads, ada/rtems-port.adb, ada/rtems-port.ads, ada/rtems-rate_monotonic.adb, ada/rtems-rate_monotonic.ads, ada/rtems-region.adb, ada/rtems-region.ads, ada/rtems-semaphore.adb, ada/rtems-semaphore.ads, ada/rtems-signal.adb, ada/rtems-signal.ads, ada/rtems-stack_checker.ads, ada/rtems-tasks.adb, ada/rtems-tasks.ads, ada/rtems-timer.adb, ada/rtems-timer.ads: New files.
* 2011-02-16 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-02-162-2/+204
| | | | | | * shared/include/powerpc-utility.h: Fixed LINKER_SYMBOL() for assembler compatibilty. Added synchronization, cache, and alternate time base functions.
* 2011-02-16 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-02-162-27/+15
| | | | | * libchip/serial/ns16550.c: Revert previous commit and extend existing mechanic.
* 2011-02-15 Jennifer AverettJoel Sherrill2011-02-153-8/+30
| | | | | * libchip/serial/ns16550.c, libchip/serial/ns16550_p.h: Support i386 style IRQs.
* 2011-02-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-152-0/+10
| | | | * ChangeLog, shared/start/start.S: Add HLT instruction on exit.
* 2011-02-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-152-0/+9
| | | | * ChangeLog, start/start.S: Add HLT instruction on exit.
* 2011-02-14 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-02-142-1/+5
| | | | * shared/irq/irq_asm.S: Fix typo.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-112-1/+6
| | | | | * dswifi/common/source/spinlock.h: Use "__asm__" instead of "__asm" for improved c99-compliance.
| | | | | * mpc55xx/include/mpc55xx.h: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-115-5/+5
| | | | | | | | | | * sh7032/delay/delay.c, sh7032/score/cpu_asm.c, sh7032/score/ispsh7032.c, sh7045/sci/sci.c, sh7045/sci/sci_termios.c, sh7045/score/cpu_asm.c, sh7045/score/ispsh7045.c, sh7750/sci/sh4uart.c, sh7750/score/cpu_asm.c, sh7750/score/ispsh7750.c, shgdb/score/cpu_asm.c, shgdb/score/ispshgdb.c: Use "__asm__" instead of "asm" for improved c99-compliance.
| | | | | * libchip/network/smc91111config.h: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-114-2/+12
| | | | | * shmsupp/lock.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-116-9/+24
| | | | | * include/tm27.h: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-113-3/+8
| | | | | * startup/bspstart.c, timer/timer.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-113-8/+13
| | | | | * include/bsp.h, include/tm27.h: Use "__asm__" instead of "asm" for improved c99-compliance.
| | | | | * startup/bspstart.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-114-6/+11
| | | | | * include/bsp.h, include/tm27.h, startup/bspstart.c: Use "__asm__" instead of "asm" for improved c99-compliance.
| | | | | * network/tsec.c: Use "__asm__" instead of "asm" for improved c99-compliance.
| | | | | * include/tm27.h, irq/irq.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-117-12/+18
| | | | | | * PCI_bus/PCI.c, console/console.c, include/bsp.h, include/tm27.h, startup/Hwr_init.c, startup/bspstart.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-113-2/+7
| | | | | * network/smsc9218i.c, startup/bspstart.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-113-6/+11
| | | | | * console/console.c, irq/irq.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-112-2/+7
| | | | | * startup/cpuinit.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-117-22/+28
| | | | | | * console/console.c, console/ns16550cfg.c, console/polled_io.c, include/bsp.h, include/tm27.h, startup/bspstart.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-115-4/+10
| | | | | | * irq/discovery_pic.c, network/if_em/rtemscompat_defs.h, * network/if_gfe/rtemscompat_defs.h, startup/bspstart.c: Use "__asm__" instead of "asm" for improved c99-compliance.
| | | | | * hw_init/hw_init.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-114-29/+34
| | | | | * include/bsp.h, startup/m68k-stub.c, startup/trace.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-115-9/+15
| | | | | | * console/console.c, fatal/bspfatal.c, startup/bspclean.c, startup/page_table.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-113-11/+16
| | | | | * startup/bspclean.c, startup/page_table.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-112-3/+8
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-112-4/+9
| | | | | * startup/bspclean.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-112-8/+13
| | | | | * startup/cfinit.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-118-4/+24
| | | | | * include/bsp.h: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-114-8/+13
| | | | | * include/bsp.h, shmsupp/lock.c, startup/bspclean.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-114-11/+16
| | | | | * clock/clock.c, startup/bspstart.c, startup/init5282.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-114-3/+8
| | | | | * include/bsp.h, include/mrm332.h, spurious/spinit.c: Use "__asm__" instead of "asm" for improved c99-compliance.
| | | | | * startup/init5235.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-112-5/+10
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-113-4/+9
| | | | | * include/bsp.h startup/init5206e.c: Use "__asm__" instead of "asm" for improved c99-compliance.
| | | | | * console/mc68ec.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-112-14/+19
