path: root/c/src (follow)
* score: SMP initialization changesSebastian Huber2014-04-145-68/+94
| | | | | | | | | | | | | | | | | Add and use _CPU_SMP_Start_processor(). Add and use _CPU_SMP_Finalize_initialization(). This makes most _CPU_SMP_Initialize() functions a bit simpler since we can calculate the minimum value of the count of processors requested by the application configuration and the count of physically or virtually available processors in the high-level code. The CPU port has now the ability to signal a processor start failure. With the support for clustered/partitioned scheduling the presence of particular processors can be configured to be optional or mandatory. There will be a fatal error only in case mandatory processors are not present. The CPU port may use a timeout to monitor the start of a processor.
* sparc: Use __leon__ multilib defineSebastian Huber2014-04-141-1/+2
* sparc64/niagara: add bsp_fatal_handler to terminate executionGedare Bloom2014-04-125-2/+351
| | | | Terminates the execution of niagara BSP when running in gem5.
* rtems: Rename rtems_smp_get_current_processor()Sebastian Huber2014-04-112-2/+2
| | | | | | | Rename rtems_smp_get_current_processor() in rtems_get_current_processor(). Make rtems_get_current_processor() a function in uni-processor configurations to enable ABI compatibility with SMP configurations.
* rtems: Rename rtems_smp_get_processor_count()Sebastian Huber2014-04-111-1/+1
| | | | | | Rename rtems_smp_get_processor_count() in rtems_get_processor_count(). Make rtems_get_processor_count() a function in uni-processor configurations to enable ABI compatibility with SMP configurations.
* sparc/shared/.../linkcmds.base: Correct C++ supportJoel Sherrill2014-04-041-7/+6
| | | | Add KEEP() for .eh_frame*, .ctor*, and .dtor*.
* leon2 ckinit.c, console.c: Comment clean upJoel Sherrill2014-04-032-26/+5
* leon2/Makefile.am: Change to one file per lineJoel Sherrill2014-04-031-7/+16
* erc32/Makefile.am: Change to one file per lineJoel Sherrill2014-04-031-7/+17
* psim/console/console-io.c: Comment clean upJoel Sherrill2014-04-031-1/+3
* sim68000/console/conscfg.c: Comment clean upJoel Sherrill2014-04-031-2/+0
* h8sim/console/console-io.c: Comment clean upJoel Sherrill2014-04-031-1/+3
* bsps/powerpc: Fix linker command filesSebastian Huber2014-04-014-16/+8
* bsps/powerpc: PR757: Fix PPC_IRQ_TRACE for ppc601Sebastian Huber2014-04-011-0/+1
| | | | We could probably also remove the ppc601 support entirely.
* libchip: Avoid __DEVOLATILE()Sebastian Huber2014-03-311-11/+9
* LEON3: UT699 and GR712 sleep-mode d-cache fixDaniel Cederman2014-03-311-5/+3
| | | | See errata of respective chip. Some code-cleanup as well.
* SPI SD-Card: adapt common driver code to block devices core API changes.Pavel Pisa2014-03-311-3/+3
* m68k/mrm332: changes required to get the mrm332 bsp working again.James Fitzsimons2014-03-2612-890/+296
| | | | | | | | | | | | | | Changed console driver to use interrupts instead of polling. Change to avoid overwriting CPU32Bug interrupt vector when setting up the Sci interrupt handler. Fixed type for boolean flag in bsp.h. Changed mrm332.h to use 25Mhz clock. Fixes to mrm332.cfg to use correct mcpu32 value for RTEMS_CPU_MODEL instead of m68332 which is no longer supported. Added -mcpu=cpu32 to compiler options. Removed broken ROM linker script and replaced broken RAM linker script with working ROM linker script. Removed no longer required file except_vect_332_ROM.S. Enabled 0xbeefbeef magic string in start.S to allow MRM version of CPU32Bug to auto run RTEMS. Removed old code from start.S Changed compiler optimization flag to optimize for size.
* bsps/sparc: Make local functions for amba plug&play static.Daniel Cederman2014-03-245-12/+10
* bsps/sparc: Add common gnat handler function prototype.Daniel Cederman2014-03-2412-6/+42
| | | | Moved prototype for __gnat_install_handler and __gnat_install_handler_common to common header file. Placed header file in bsp namespace.
* greth: Make local functions static, remove overflow and correct printf call.Daniel Cederman2014-03-212-7/+9
* bsps/sparc: Change asm to __asm__ to compile with -pedantic.Daniel Cederman2014-03-213-6/+6
* bsps/sparc: Make spurious trap handler function static.Daniel Cederman2014-03-213-3/+3
* bsps/sparc: Make local functions static.Daniel Cederman2014-03-219-4/+32
| | | | | | | The PCI and RASTA versions of the uart, spacewire and 1553 drivers directly includes the c-file of the standard versions of the drivers, but uses a macro to change the name of the driver register function. When the standard version is used this function should be global, when it is included as part of the PCI and RASTA versions it should be local and static.
* smc91111: Move driver attach prototype to header file.Daniel Cederman2014-03-215-16/+8
| | | | Also signal to compiler that the start variable in lan91cxx_recv is only used when debugging.
* no_bsp/shmsupp/lock.c: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-2/+4
* no_bsp/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-10/+3
* nios2_iss/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-10/+0
* moxiesim/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-9/+0
* sim68000/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-17/+0
* ods68302/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-17/+3
* mvme136/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-16/+0
* mrm332/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-17/+3
* gen68360/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-16/+0
* gen68340/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-16/+0
* gen68302/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-22/+1
* m32rsim/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-17/+0
* m32cbsp/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-17/+0
* lm32_evr/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-15/+1
* pc386/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-16/+0
* h8sim/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-16/+0
* gensh1/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-10/+2
* gensh2/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-10/+2
* gensh4/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-10/+2
* shsim/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-12/+2
* usiii/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-17/+0
* niagara/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-17/+0
* gba/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-12/+0
* avrtest/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-17/+0
* eZKit533/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-9/+0
