path: root/c/src (follow)
* gensh1/include/bsp.h: Add needed prototypeJoel Sherrill2015-03-091-0/+7
* gensh4/include/bsp.h: Remove unused prototype and includeJoel Sherrill2015-03-091-6/+0
* powerpc/shared/bootloader/pci.c: Remove warningsJoel Sherrill2015-03-091-2/+2
* shared/include/grcan.h: Add prototypes to fix warningsJoel Sherrill2015-03-091-1/+2
* Add fsscandir01 variants as needed to more BSPs testsuite configurationJoel Sherrill2015-03-0621-0/+25
* Temporarily ignore dl* tests on some PowerPC BSPsJoel Sherrill2015-03-069-0/+45
| | | | | | | | Some BSPs have issues linking the dl* tests. These issues have not been investigated. This is a temporary workaround until we have an explanation and permanent solution. updates 2258.
* Always disable networking for h8300Joel Sherrill2015-03-069-1/+10
* Temporarily disable libdl tests on some MIPS BSPSsJoel Sherrill2015-03-063-0/+15
| | | | | | | These BSPs are little endian while most are big endian. The dl tool does not support the -EL option yet. updates 2279.
* raspberrypi: Do not include default IRQ handler and BSP specific oneJoel Sherrill2015-03-061-1/+0
| | | | | | This was tripping a linker error in the dl0[12] tests. closes 2247.
* lpc1768_mbed_ahb_ram-testsuite.tcfg: Add ftp01Joel Sherrill2015-03-061-0/+1
* lpc1768_mbed_ahb_ram.tcfg: Remove as it is a junk fileJoel Sherrill2015-03-061-7/+0
| | | | | This file does not have "-testsuite" in the name and is ignored by the build system.
* Fix a number of minor Doxygen formatting issuesJoel Sherrill2015-03-061-1/+1
* bsps: Use interrupt lock for interrupt serverSebastian Huber2015-03-051-10/+23
* bsp/qoriq: Fix warningSebastian Huber2015-03-051-2/+1
* libmd: Disable SHA modules for m32cSebastian Huber2015-03-051-0/+3
| | | | Close #2219.
* libchip/serial: Fix warningSebastian Huber2015-03-051-2/+1
* bsps: Fix warningSebastian Huber2015-03-051-2/+1
* mips BSPs: Remove .global for unprovided symbolJoel Sherrill2015-03-034-4/+0
| | | | closes 2253
* ARM: Add BSP_START_NEEDS_REGISTER_INITIALIZATIONMartin Galvan2015-02-274-0/+139
| | | | | | | | | | | | | This patch adds the macro BSP_START_NEEDS_REGISTER_INITIALIZATION and three hooks for BSP-specific register init code to arm/shared/start.S. Said hooks are bsp_start_init_registers_core (intended for initializing the ARM core registers), bsp_start_init_registers_banked_fiq (for the FIQ mode banked registers) and bsp_start_init_registers_vfp (for the FPU registers). BSP_START_NEEDS_REGISTER_INITIALIZATION would be defined in a BSP's configure.ac (so that it appears in its bspopts.h). This patch also adds the register init code required by the TMS570. We've tested it with the tms570ls3137_hdk.cfg config and it works fine.
* sparc64: fix copyright notices.Gedare Bloom2015-02-238-34/+14
| | | | | The sparc64 port had some incorrect copyright notices affixed to source code files.
* ARM: Support VFP-D16Martin Galvan2015-02-201-3/+5
| | | | | | | | | This patch allows the existing FPU code to support both VFP-D16 and VFP-D32. According to ARM, writes to D32DIS are ignored for D16 so there's no need to enclose the bic instruction with an #ifdef. We tested it on a TMS570LS3137 using TI initialization code and it works fine. Signed-off by: Martin Galvan <martin.galvan@tallertechnologies.com>
* score: Add _CPU_SMP_Prepare_start_multitasking()Sebastian Huber2015-02-174-8/+19
| | | | Update #2268.
* lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add ftp01Joel Sherrill2015-02-131-0/+1
* lpc1768_mbed-testsuite.tcfg: Add ftp01Joel Sherrill2015-02-131-0/+1
* IMFS: Add fine grained configurationSebastian Huber2015-02-121-1/+0
| | | | | | | | | | | | | | | | | | Remove miniIMFS. Statically initialize the root IMFS. Add configuration options to disable individual features of the root IMFS, e.g. o CONFIGURE_IMFS_DISABLE_CHOWN, o CONFIGURE_IMFS_DISABLE_FCHMOD, o CONFIGURE_IMFS_DISABLE_LINK, o CONFIGURE_IMFS_DISABLE_MKNOD, o CONFIGURE_IMFS_DISABLE_MOUNT, o CONFIGURE_IMFS_DISABLE_READLINK, o CONFIGURE_IMFS_DISABLE_RENAME, o CONFIGURE_IMFS_DISABLE_RMNOD, o CONFIGURE_IMFS_DISABLE_SYMLINK, o CONFIGURE_IMFS_DISABLE_UNMOUNT, and o CONFIGURE_IMFS_DISABLE_UTIME.
* grspw: Fix typosDaniel Cederman2015-02-111-3/+3
* bsp/sparc: Move BSP_ISR_handler to a separate file and rename itDaniel Cederman2015-02-119-23/+59
| | | | | | | This allows it to be wrapped by another function at link-time and can be used to trace interrupts. If not placed in a separate file, the function pointer address used in BSP_shared_interrupt_init will be resolved at compile-time, and the function will not be wrappable.
* Filesystem: Delete unused fsmountme_h handlerSebastian Huber2015-02-091-1/+0
* arm/tms570: sci context has to be writable because it holds state variable.Pavel Pisa2015-02-042-4/+4
| | | | | | | | | | | | | | The structure tms570_sci_context holds state variable tx_chars_in_hw which holds if and how many characters (in the optional FIFO support for some Ti SCIs) are submitted into hardware. When field is not writable then code breaks when RTEMS is build for Flash area. The problem found and analyzed by Martin Galvan from tallertechnologies. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
* bsps/powerpc: Fix a clock driverNick Withers2015-01-301-9/+57
| | | | | | | PowerPC Book E: Account for an extra tick period if a tick increment's pending. Close #2230.
* mcf5206elite/include/i2c.h: Fix spelling errorJoel Sherrill2015-01-231-1/+1
* stm32f4/.../stm32f105rc-testsuite.tcfg: Add more testsJoel Sherrill2015-01-231-0/+1
* lpc24xx/.../lpc23xx_tli800-testsuite.tcfg: Add more testsJoel Sherrill2015-01-231-0/+7
* lpc24xx/.../lpc2362-testsuite.tcfg: Add more testsJoel Sherrill2015-01-231-0/+2
* lm3s69xx/.../lm3s6965-testsuite.tcfg: Add more testsJoel Sherrill2015-01-231-0/+1
* lm3s69xx/.../lm3s3749-testsuite.tcfg: Add more testsJoel Sherrill2015-01-231-0/+2
* bsp/altera-cyclone-v: Use proper free functionSebastian Huber2015-01-231-1/+1
* bsps/sparc: Use calloc()Sebastian Huber2015-01-231-3/+1
| | | | Close #2242.
* bsps/powerpc: Fix switch statement in CPU identSebastian Huber2015-01-231-0/+2
| | | | Close #2237.
* libchip: Fix high capacity detection for MMCSebastian Huber2015-01-231-1/+1
| | | | Close #2239.
* grspw: descriptor tables no longer statically allocatedjavamonn2015-01-221-7/+7
* Filesystem: Delete node type operationSebastian Huber2015-01-221-7/+8
| | | | Use the fstat handler instead.
* powerpc: Fix AltiVec VSCR save/restoreSebastian Huber2015-01-201-4/+6
* bsps/powerpc: Fix conditional compilationSebastian Huber2015-01-141-3/+1
* bsp/mcf5206elite: Remove <i2c.h> inlude in <bsp.h>Sebastian Huber2015-01-142-3/+1
| | | | This prevents a compile-time error in libtests/i2c01.
* libcpu/powerpc/mpc6xx/mmu/bat.c: Now compiles with gcc 5.xJoel Sherrill2015-01-131-12/+12
* bsp/qoriq: Add T2080RDB and T4240RDB variantsSebastian Huber2015-01-1324-318/+714
* powerpc: AltiVec and FPU context supportSebastian Huber2015-01-137-12/+821
| | | | | | | | | | | Add AltiVec and FPU support to the Context_Control in case we use the e6500 multilib. Add PPC_MULTILIB_ALTIVEC and PPC_MULTILIB_FPU multilib defines. Add non-volatile AltiVec and FPU context to Context_Control. Add save/restore of non-volatile AltiVec and FPU to _CPU_Context_switch(). Add save/restore of volatile AltiVec and FPU context to the exception code. Adjust data cache optimizations for the new context and cache line size.
* bsps/powerpc: Use e500 exc categories for e6500Sebastian Huber2015-01-131-0/+1
| | | | This is not correct, but works for now.
* moxiesim: Add conditional logic to handle old and new gas syntaxAnthony Green2015-01-102-2/+21
