path: root/c/src (follow)
* Reordered specs.Joel Sherrill1997-07-101-4/+4
* fixed milliseconds and microseconds to tick conversion routines.Joel Sherrill1997-07-101-11/+10
* Added information on different MVME162 models.Joel Sherrill1997-07-101-0/+11
* Strip the trace bit from the SR register when dispatching a thread whenJoel Sherrill1997-07-101-3/+5
| | | | | exiting from an ISR. This allows the trace bit to be set on a per task basis and tracing to be limited to that task.
* Repository damaged -- file re-addedJoel Sherrill1997-07-093-0/+555
* Repository damaged -- files readded.Joel Sherrill1997-07-092-0/+411
* Changed name from entry to thread_entry to be more compatible withJoel Sherrill1997-07-093-3/+3
| | | | Ada interface where entry is a keyword.
* Used macro instead of hard coded number.Joel Sherrill1997-07-091-1/+1
* Added postswitch extension.Joel Sherrill1997-07-092-0/+4
* Added post switch extension.Joel Sherrill1997-07-092-0/+10
* Corrected typos and spacing.Joel Sherrill1997-07-092-6/+6
* This code was in the tree but not actually being compiled. ThereJoel Sherrill1997-07-0934-140/+140
| | | | | | | were a number of minor problems which had to be fixed to get it to compile including modifying the compile rule to handle C++ comments, changing the syntax of the include statement, and getting rid of "%" as part of register names.
* Added sp, sfc, and fpcsr register defines.Joel Sherrill1997-07-091-0/+4
* new fileJoel Sherrill1997-06-042-0/+90
* corrected name of test suiteJoel Sherrill1997-06-0330-30/+30
* fixed commentJoel Sherrill1997-06-031-1/+1
* Removed configuration information.Joel Sherrill1997-06-031-54/+0
* new fileJoel Sherrill1997-06-034-0/+181
* Removed Configuration Information.Joel Sherrill1997-06-031-54/+0
* new files.Joel Sherrill1997-06-032-0/+89
* Removed configuration information.Joel Sherrill1997-06-031-42/+0
* new filesJoel Sherrill1997-06-035-0/+362
* new file.Joel Sherrill1997-06-031-0/+9
* corrected to compile with the new binding.Joel Sherrill1997-06-035-35/+119
* Corrected for this test.Joel Sherrill1997-06-031-0/+1
* Added correct contentsJoel Sherrill1997-06-031-0/+57
* new fileJoel Sherrill1997-06-034-0/+700
* Corrected maximum number of messages to be non-zeroJoel Sherrill1997-06-031-1/+1
* removed reference to Stub Device DriverJoel Sherrill1997-06-031-1/+0
* Replaced prototype for Last_Task which was accidentally removed whenJoel Sherrill1997-06-031-0/+14
| | | | the Configuration Tables were deleted from the Ada specification.
* Changed RTEMS.Boolean to Standard.Boolean to avoid typing problems.Joel Sherrill1997-06-031-1/+1
* Fixed incorrect invocation of Message_Queue_CreateJoel Sherrill1997-06-031-1/+0
* fixed typo which resulted in Message_Queue_Create being invoked incorrectly.Joel Sherrill1997-06-031-1/+0
* Fixed calls to Message_Queue_Create to include maximum message sizeJoel Sherrill1997-06-039-5/+14
| | | | parameter.
* Changed to variable length messages.Joel Sherrill1997-06-0317-66/+219
* Changed Task_Entry_Point to Task_Entry to be correct per 4.0.0.Joel Sherrill1997-06-0311-11/+11
* Changed type Task_Entry_Point to Task_Entry to be correct per 4.0.0.Joel Sherrill1997-06-031-1/+1
* Fixed all references to Semaphore_Create to have the correctJoel Sherrill1997-06-037-5/+12
| | | | argument sequence.
* New file.Joel Sherrill1997-06-0328-0/+1045
* new fileJoel Sherrill1997-06-0328-0/+1596
* Removed Configuration Table information.Joel Sherrill1997-06-0330-1170/+0
* Corrected call to Semaphore_Create to have the proper calling sequenceJoel Sherrill1997-06-031-0/+2
* Removed Configuration Table informationJoel Sherrill1997-06-031-38/+0
* new fileJoel Sherrill1997-06-032-0/+94
* Removed unnecessary dependency on RTEMS_Test_Support which existedJoel Sherrill1997-06-031-1/+0
| | | | in the RTEMS Ada implementation but does not exist in this binding.
* new fileJoel Sherrill1997-06-036-0/+209
* removed reference to the Stub Device DriverJoel Sherrill1997-06-031-1/+0
* Changed mode and priority of initialization task.Joel Sherrill1997-06-032-5/+2
* Changed attribute of Initialization Task to Floating_PointJoel Sherrill1997-06-031-1/+1
* new filesJoel Sherrill1997-06-032-0/+56
