* | Pass in PROJECT_HOME so rtems-glom can run if the make is invoked | Joel Sherrill | 1997-12-16 | 2 | -4/+8 | |
| | | | | just in this directory. | |||||
* | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 1997-12-10 | 454 | -461/+1823 | |
| | | | | | any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | |||||
* | Added missing dependency for libmisc.a based on a bug report by Phil Wilshire. | Joel Sherrill | 1997-12-07 | 2 | -0/+2 | |
* | Fixed indexing bug reported by Phil Wilshire. | Joel Sherrill | 1997-12-07 | 2 | -2/+2 | |
* | Changed the uuencode line to work better with VPATH setups. | Joel Sherrill | 1997-12-06 | 1 | -2/+2 | |
* | Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were defined. | Joel Sherrill | 1997-12-06 | 2 | -4/+4 | |
| | | | | | This simple error resulted in the wrong FP context structure being used for hardware contexts on the m68k. This was a difficult problem to find. | |||||
* | Inclusion of PC386 BSP submitted by Pedro Miguel Da Cruz Neto Romano | Joel Sherrill | 1997-12-01 | 32 | -0/+4896 | |
| | | | | | <pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt> of NavIST (http://pandora.ist.utl.pt/). | |||||
* | Since test suite Makefiles are not always generated, use wildcard | Joel Sherrill | 1997-11-30 | 1 | -4/+3 | |
| | | | | to determine which directories to descend into. | |||||
* | Corrected call to rtems_termios_open. | Joel Sherrill | 1997-11-30 | 1 | -1/+2 | |
* | Corrected comment. | Joel Sherrill | 1997-11-30 | 2 | -6/+1 | |
* | Removed warnings. | Joel Sherrill | 1997-11-29 | 4 | -2/+12 | |
* | Patch from Chris Johns to filter out the trace bit on CPU models | Joel Sherrill | 1997-11-29 | 1 | -2/+5 | |
| | | | | which have hardware support for a separate interrupt stack. | |||||
* | Removed warning. | Joel Sherrill | 1997-11-18 | 1 | -1/+1 | |
* | New file. | Joel Sherrill | 1997-11-18 | 1 | -0/+45 | |
* | Removed warning under linux port. | Joel Sherrill | 1997-11-18 | 2 | -0/+10 | |
* | Removed warnings. | Joel Sherrill | 1997-11-18 | 2 | -1/+6 | |
* | Added argument as required by new version of termios_open. | Joel Sherrill | 1997-11-18 | 1 | -2/+4 | |
* | Fixed assignment to dereference ch. | Joel Sherrill | 1997-11-18 | 1 | -1/+1 | |
* | Changed from DOS style CR/LF to Unix style. | Joel Sherrill | 1997-11-18 | 1 | -534/+534 | |
* | Added CONFIGURE_MEMORY_USER_OVERHEAD constant per Chris Johns request. | Joel Sherrill | 1997-11-18 | 2 | -2/+12 | |
* | interrupt driven change from Eric Norum | Joel Sherrill | 1997-11-15 | 6 | -178/+427 | |
* | Fixed prototype | Joel Sherrill | 1997-11-10 | 3 | -3/+3 | |
* | Set return code to avoid spurious errors. | Joel Sherrill | 1997-11-10 | 2 | -0/+2 | |
* | added katsutoshi Shibuya | Joel Sherrill | 1997-10-24 | 2 | -2/+16 | |
* | Changed prototype of read routine. | Joel Sherrill | 1997-10-23 | 5 | -29/+15 | |
* | Switched to new style for read support routine. | Joel Sherrill | 1997-10-23 | 1 | -10/+6 | |
* | Added TOD driver from Katsutoshi Shibuya. | Joel Sherrill | 1997-10-23 | 6 | -3/+190 | |
* | Removed GEN68360_INIT. | Joel Sherrill | 1997-10-23 | 1 | -8/+0 | |
* | Update from Eric Norum. | Joel Sherrill | 1997-10-23 | 1 | -161/+153 | |
* | Updated console driver to use new read routine conventions. | Joel Sherrill | 1997-10-23 | 1 | -6/+3 | |
* | Added new test for termios style consoles from Eric Norum. | Joel Sherrill | 1997-10-23 | 3 | -1/+205 | |
* | Added console_reserve_resources. | Joel Sherrill | 1997-10-23 | 2 | -6/+15 | |
* | Overhauled console driver to use termios and to simultaneously support | Joel Sherrill | 1997-10-23 | 3 | -149/+170 | |
| | | | | both ports. | |||||
* | Added prototype for console_reserve_resources. | Joel Sherrill | 1997-10-23 | 2 | -0/+8 | |
* | fixed comment | Joel Sherrill | 1997-10-23 | 2 | -4/+2 | |
* | New termios.c from Eric Norum. | Joel Sherrill | 1997-10-23 | 5 | -1202/+1296 | |
| | | | | Added new entry point to add in per physical port resource requirements. | |||||
* | Added test case for rtems_interrupt_catch checking that the pointer | Joel Sherrill | 1997-10-21 | 2 | -1/+11 | |
| | | | | for the returned old_isr_handler was non-NULL. | |||||
* | Fixed a number of warnings regarding comparisons between signed and | Joel Sherrill | 1997-10-21 | 8 | -18/+18 | |
| | | | | unsigned numbers. | |||||
* | Fixed endian problem in printing object names. | Joel Sherrill | 1997-10-21 | 2 | -0/+10 | |
* | Converted to termios style device driver. | Joel Sherrill | 1997-10-21 | 1 | -265/+144 | |
* | Added check that return argument pointer for old_isr_handler was valid. | Joel Sherrill | 1997-10-21 | 1 | -0/+3 | |
* | Converted from using a message queue for the raw input queue to using a | Joel Sherrill | 1997-10-21 | 2 | -98/+70 | |
| | | | | ring buffer in conjunction with a counting semaphore. | |||||
* | Added termios submission from Eric Norum and Katsutoshi Shibuya. | Joel Sherrill | 1997-10-21 | 3 | -1/+1521 | |
* | Added termios submission from Eric Norum and Katsutoshi Shibuya. | Joel Sherrill | 1997-10-21 | 3 | -6/+66 | |
* | Added casts and fixed line break. | Joel Sherrill | 1997-10-21 | 2 | -4/+6 | |
* | Control and Data addresses were swapped for port A. | Joel Sherrill | 1997-10-16 | 1 | -2/+2 | |
* | Moved selection of console port to custom file. | Joel Sherrill | 1997-10-15 | 1 | -3/+0 | |
* | New version of this file from Eric Norum. | Joel Sherrill | 1997-10-13 | 1 | -536/+534 | |
* | Fixed some spacing. | Joel Sherrill | 1997-10-09 | 2 | -4/+4 | |
* | Fixed incorrect reference to RTEMS_BSP instead of RTEMS_BSP_FAMILY. | Joel Sherrill | 1997-10-09 | 1 | -1/+1 | |
