* Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* bootloader/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* motorola/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* openpic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* pci/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* residual/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* nvram/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* universe/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* PCI_bus/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Remove SORDID_HACK. Eliminate *_O_FILES.
* canbus/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dlentry/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* scv64/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* sonic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* flashentry/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* include/Makefile.am: Fix broken preinstall-deps.
* configure.ac: RTEMS_CHECK_CUSTOM_BSP.
* milli/Makefile.am: Ditto.
* semaphore/Makefile.am: Ditto.
* timer/Makefile.am: Ditto.
* milli/milli.S: Per PR329, use GNU binutils assembler directives.
* Makefile.am: Remove CPU_MODEL_SUBDIR.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP).
* i960ca/Makefile.am: Eliminate *_O_FILES.
* i960ka/Makefile.am: Ditto.
* i960rp/Makefile.am: Ditto.
* cache/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* reg_win/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* syscall/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* erc32sonic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* gnatsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* clock/Makefile.am: Eliminate *_O_FILES.
* sci/Makefile.am: Ditto.
* score/Makefile.am: Ditto.
* configure.ac: Apply 2002-11-07 patch (Apparently dropped by CVS).
* delay/Makefile.am: Ditto.
* scitab/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* bsp.mak: Use ac_cv_env instead of ac_cv for cached vars.
* wrapup/Makefile.am: Use install-data-local to install librtemsbsp.a.
Let all-local: depend on $(LIB).
* Makefile.am: Apply install-data-local to install *.rels.
* .cvsignore: Moved to rtems/cpukit/libmisc.
* ChangeLog: Moved to rtems/cpukit/libmisc.
* Makefile.am: Moved to rtems/cpukit/libmisc.
* README: Moved to rtems/cpukit/libmisc.
* configure.ac: Moved to rtems/cpukit/libmisc.
* capture/Makefile.am: Moved to rtems/cpukit/libmisc.
* capture/README: Moved to rtems/cpukit/libmisc.
* capture/capture-cli.c: Moved to rtems/cpukit/libmisc.
* capture/capture-cli.h: Moved to rtems/cpukit/libmisc.
* capture/capture.c: Moved to rtems/cpukit/libmisc.
* capture/capture.h: Moved to rtems/cpukit/libmisc.
* cpuuse/Makefile.am: Moved to rtems/cpukit/libmisc.
* cpuuse/README: Moved to rtems/cpukit/libmisc.
* cpuuse/cpuuse.c: Moved to rtems/cpukit/libmisc.
* cpuuse/cpuuse.h: Moved to rtems/cpukit/libmisc.
* devnull/.cvsignore: Moved to rtems/cpukit/libmisc.
* devnull/Makefile.am: Moved to rtems/cpukit/libmisc.
* devnull/devnull.c: Moved to rtems/cpukit/libmisc.
* devnull/devnull.h: Moved to rtems/cpukit/libmisc.
* dummy/.cvsignore: Moved to rtems/cpukit/libmisc.
* dummy/Makefile.am: Moved to rtems/cpukit/libmisc.
* dummy/README: Moved to rtems/cpukit/libmisc.
* dummy/dummy.c: Moved to rtems/cpukit/libmisc.
* dumpbuf/.cvsignore: Moved to rtems/cpukit/libmisc.
* dumpbuf/Makefile.am: Moved to rtems/cpukit/libmisc.
* dumpbuf/dumpbuf.c: Moved to rtems/cpukit/libmisc.
* dumpbuf/dumpbuf.h: Moved to rtems/cpukit/libmisc.
* monitor/.cvsignore: Moved to rtems/cpukit/libmisc.
* monitor/Makefile.am: Moved to rtems/cpukit/libmisc.
* monitor/README: Moved to rtems/cpukit/libmisc.
* monitor/mon-command.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-config.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-dname.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-driver.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-extension.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-itask.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-manager.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-monitor.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-mpci.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-object.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-prmisc.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-queue.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-server.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-symbols.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-task.c: Moved to rtems/cpukit/libmisc.
* monitor/monitor.h: Moved to rtems/cpukit/libmisc.
* monitor/symbols.h: Moved to rtems/cpukit/libmisc.
* mw-fb/.cvsignore: Moved to rtems/cpukit/libmisc.
* mw-fb/Makefile.am: Moved to rtems/cpukit/libmisc.
* mw-fb/mw_fb.c: Moved to rtems/cpukit/libmisc.
* mw-fb/mw_fb.h: Moved to rtems/cpukit/libmisc.
* mw-fb/mw_uid.c: Moved to rtems/cpukit/libmisc.
* mw-fb/mw_uid.h: Moved to rtems/cpukit/libmisc.
* rtmonuse/.cvsignore: Moved to rtems/cpukit/libmisc.
* rtmonuse/Makefile.am: Moved to rtems/cpukit/libmisc.
* rtmonuse/rtmonuse.c: Moved to rtems/cpukit/libmisc.
* rtmonuse/rtmonuse.h: Moved to rtems/cpukit/libmisc.
* serdbg/.cvsignore: Moved to rtems/cpukit/libmisc.
* serdbg/Makefile.am: Moved to rtems/cpukit/libmisc.
* serdbg/README: Moved to rtems/cpukit/libmisc.
* serdbg/serdbg.c: Moved to rtems/cpukit/libmisc.
* serdbg/serdbg.h: Moved to rtems/cpukit/libmisc.
* serdbg/serdbgcnf.h: Moved to rtems/cpukit/libmisc.
* serdbg/serdbgio.c: Moved to rtems/cpukit/libmisc.
* serdbg/termios_printk.c: Moved to rtems/cpukit/libmisc.
* serdbg/termios_printk.h: Moved to rtems/cpukit/libmisc.
* serdbg/termios_printk_cnf.h: Moved to rtems/cpukit/libmisc.
* shell/.cvsignore: Moved to rtems/cpukit/libmisc.
* shell/Makefile.am: Moved to rtems/cpukit/libmisc.
* shell/README: Moved to rtems/cpukit/libmisc.
* shell/cmds.c: Moved to rtems/cpukit/libmisc.
* shell/shell.c: Moved to rtems/cpukit/libmisc.
* shell/shell.h: Moved to rtems/cpukit/libmisc.
* stackchk/.cvsignore: Moved to rtems/cpukit/libmisc.
* stackchk/Makefile.am: Moved to rtems/cpukit/libmisc.
* stackchk/README: Moved to rtems/cpukit/libmisc.
* stackchk/check.c: Moved to rtems/cpukit/libmisc.
* stackchk/internal.h: Moved to rtems/cpukit/libmisc.
* stackchk/stackchk.h: Moved to rtems/cpukit/libmisc.
* untar/.cvsignore: Moved to rtems/cpukit/libmisc.
* untar/Makefile.am: Moved to rtems/cpukit/libmisc.
* untar/README: Moved to rtems/cpukit/libmisc.
* untar/untar.c: Moved to rtems/cpukit/libmisc.
* untar/untar.h: Moved to rtems/cpukit/libmisc.
* wrapup/.cvsignore: Moved to rtems/cpukit/libmisc.
* wrapup/Makefile.am: Moved to rtems/cpukit/libmisc.
* wrapup/Makefile.am: Remove libmisc.
* configure.ac: Remove libmisc.
* Makefile.am: Eliminate *_O_FILES.
Don't create $ARCH in %.o: %.c rules.
* network/Makefile.am: Eliminate C_O_FILES.
* rtc/Makefile.am: Ditto.
* serial/Makefile.am: Ditto,
* Makefile.am: Use .$(OBJEXT) instead of .o.
* capture/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* cpuuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* devnull/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dummy/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dumpbuf/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* monitor/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mw-fb/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* rtmonuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* serdbg/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shell/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* stackchk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* untar/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* serial/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Don't use LIBC_DEFINES.
* rtc/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in src/Makefile.am, include/Makefile.am.
Unconditionally check for CXX.
* Makefile.am: Introduce sapi_C_FILES, rtems_C_FILES.
