* base_mp/apptask.c: Removed warning.
* src/rdbg.c, src/servtsp.c, src/m68k/rdbg_f.c,
src/m68k/any/remdeb_xdr.c,
src/powerpc/new_exception_processing/remdeb_xdr.c: Removed warnings.
* rtems_webserver/socket.c, rtems_webserver/uemf.h: Removed
warnings.
* stackchk/check.c: Removed warning.
* network/dec21140.c: Removed warnings.
* mpc6xx/clock/c_clock.c, mpc6xx/exceptions/raw_exception.c,
mpc6xx/mmu/bat.c: Removed warnings.
* bootloader/em86.c, console/inch.c, console/polled_io.c, irq/irq.c,
motorola/motorola.c, pci/detect_raven_bridge.c,
vectors/vectors_init.c: Removed warnings.
* m68k-stub.c: Fixed warnings about multi-line strings in asm.
* configure.ac: Remove AC_ENABLE_MULTILIB.
* Makefile.am: Add CVS-Id.
* ide_ctrl.c: New file.
* base_mp/apptask.c: Add include of <unistd.h> to eliminate warning.
* New files: New directory ide/, ide/Makefile.am, ide/ide_ctrl_cfg.h,
ide/ide_ctrl_io.h, ide/ide_ctrl.h:
* configure.ac, Makefile.am: Modified to reflect changes above.
* monitor/mon-command.c: Don't build rtems_monitor_line_editor for
RTEMS_UNIX to avoid gcc warning.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* samples/hello/config.h: Change CONFIGURE_SPTEST to
CONFIGURE_APPLICATION to reflect current usage.
* support/init.c: Include stdlib.h not unistd.h to remove warning.
* capture/capture.c, monitor/mon-manager.c, stackchk/check.c:
Patch to remove problems introduced by object name rework.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
Add autom4te*cache.
Add autom4te*cache.
Add autom4te*cache.
* wrapup/.cvsignore: Remove autom4te.cache.
* acinclude.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* .cvsignore: Add autom4te.cache.
* irq/irq_asm.S: Add FIQ support.
* rtems-stub-glue.c: Removed should only be common copy.
* support/init.c: Included <unistd.h> for exit(2).
* support/test_support.adb: Eliminated warnings by commenting out
unused variables.
* serial/z85c30.c: Eliminated warning by clarifying statement.
* cpu.c: Include declaration of variable i in ifdef USE_SPRG to
eliminate warning.
* clock/clock.c: Per PR257, remove reference to c3x_set_ie.
c4x variant should use c4x_set_iie().
* startup/bspstart.c: As part of fixing PR281 on gensh4, a review
of all calls to bsp_libc_init() resulted in some cleanup here.
* sp32/.cvsignore: New file.
* PR271 was not applicable against the current source but included
a nice test that Joel decided to add to the tree as sp32.
* sp32/Makefile.am, sp32/init.c, sp32/sp32.scn: New file.
* Makefile.am, configure.ac: Modified to reflect addition.
* include/bsp.h, startup/Makefile.am, startup/bspclean.c:
Cleanup so the BSP works.
* start/start16.S: Remove unwanted + at beginning of relative
numeric label.
numeric label.
* samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am:
Now appear to mostly compile.
* samples/hello/Makefile.am: Make sure init.c is compiled and
included. This test now runs.
* Part of addressing PR281.
* main.cfg: Added recognition of VARIANT=DEBUG on command line.
* compilers/gcc-target-default.cfg: Removed remaining support for
RTEMS_USE_GCC272 and RTEMS_LIBC_DIR as well as added -qrtems_debug
as one of the LDFLAGS when the debug variant is specified.
* configure.ac: Remove duplicate timer/Makefile in AC_CONFIG_FILES.
* Makefile.am: Don't use RTEMS_TOPdir in ACLOCAL_AMFLAGS.
* Makefile.am: ACLOCAL_AMFLAGS = -I ../../../../../../aclocal.
* configure.ac: Remove duplicate mpc6xx/timer/Makefile from CONFIG_FILES.
* configure.ac: Remove duplicate timer/Makefile from CONFIG_FILES.
* clock/clock.c: Disabled use of fast idle since it seems broken
with gcc 3.2.
* samples/base_mp/config.h: New file previously missed.
* network/Makefile.am, network/README.cs8900, network/cs8900.c,
network/cs8900.h: Significant update which corrects the problem
where the cs8900.c file was actually the BSP glue. Joel did
some hacking so this file will compile. Previously it required
providing a target.h file to compile.
* network/cs8900.c.bsp: New file.
* pppd/ipcp.c, rtems_servers/ftpd.c: Add include files to resolve
warnings.
* Makefile.inc.in: Comment out RTEMS_USE_GCC272.
Comment out RTEMS_LIBC_DIR.
* base_mp now builds and can be considered a bit of an example for
the other mptests.
* mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am,
samples/base_mp/mptest.adb, samples/base_mp/mptest.ads,
Modified to make compile.
* mptests/mp01/node1/mptest-per_node_configuration.adb,
mptests/mp01/node2/mptest-per_node_configuration.adb,
mptests/mp02/node1/mptest-per_node_configuration.adb,
mptests/mp02/node2/mptest-per_node_configuration.adb,
mptests/mp03/node1/mptest-per_node_configuration.adb,
mptests/mp03/node2/mptest-per_node_configuration.adb,
mptests/mp04/node1/mptest-per_node_configuration.adb,
mptests/mp04/node2/mptest-per_node_configuration.adb,
mptests/mp05/node1/mptest-per_node_configuration.adb,
mptests/mp05/node2/mptest-per_node_configuration.adb,
mptests/mp06/node1/mptest-per_node_configuration.adb,
mptests/mp06/node2/mptest-per_node_configuration.adb,
mptests/mp07/node1/mptest-per_node_configuration.adb,
mptests/mp07/node2/mptest-per_node_configuration.adb,
mptests/mp08/node1/mptest-per_node_configuration.adb,
mptests/mp08/node2/mptest-per_node_configuration.adb,
mptests/mp09/node1/mptest-per_node_configuration.adb,
mptests/mp09/node2/mptest-per_node_configuration.adb,
mptests/mp10/node1/mptest-per_node_configuration.adb,
mptests/mp10/node2/mptest-per_node_configuration.adb,
mptests/mp11/node1/mptest-per_node_configuration.adb,
mptests/mp11/node2/mptest-per_node_configuration.adb,
mptests/mp12/node1/mptest-per_node_configuration.adb,
mptests/mp12/node2/mptest-per_node_configuration.adb,
mptests/mp13/node1/mptest-per_node_configuration.adb,
mptests/mp13/node2/mptest-per_node_configuration.adb,
mptests/mp14/node1/mptest-per_node_configuration.adb,
mptests/mp14/node2/mptest-per_node_configuration.adb,
samples/base_mp/node1/mptest-per_node_configuration.adb,
samples/base_mp/node2/mptest-per_node_configuration.adb: Removed
as this information should come from config.h.
