* clock/clock.c, console/console.c, ide/pcmcia_ide.c,
ide/pcmcia_ide.h, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, nvram/m93cxx.h, nvram/nvram.c, nvram/nvram.h,
slicetimer/slicetimer.c, start/start.S, startup/bspstart.c,
startup/cpuinit.c, vectors/vectors.S, vectors/vectors_init.c:
Convert to utf-8.
* include/m68349.inc, start/start.S, startup/dumpanic.c:
Convert to utf-8.
* configure.ac: Require automake-1.9.
* bootloader/Makefile.am: Remove DEFAULT_INCLUDES.
* console/defaultfont.c: Convert to utf-8.
* network_ada/adasockets/AUTHORS,
network_ada/adasockets/sockets-link.ads,
network_ada/adasockets/sockets-multicast.adb,
network_ada/adasockets/sockets-multicast.ads,
network_ada/adasockets/sockets-utils.adb,
network_ada/adasockets/sockets-utils.ads,
network_ada/adasockets/sockets.adb,
network_ada/adasockets/sockets.ads,
network_ada/listener/listener.adb,
network_ada/tcprelay/tcprelay.adb: Convert to utf-8.
* mongoosev/duart/mg5uart.c: Removed warnings.
* shared/gdbstub/mips-stub.c: Removed warnings.
* sh7750/include/rtems/score/sh7750_regs.h: Fix spelling of IPRC
(Probably a cyrillic 'C' instead of an ASCI 'C').
* configure.ac: Use RTEMS_AMPOLISH3.
* mongoosev/vectorisrs/vectorisrs.c: Convert C++ style comments to C
style.
* librdbg/src/_servtgt.c: Convert C++ style comments to C style.
* include/mpc5200.h, network_5200/network.c: Convert C++ style comments
to C style.
* startup/bspstart.c: Convert C++ style comments to C style.
* console/console.c, console/sci.c, console/sci.h, spurious/spinit.c,
startup/bspclean.c, startup/start_c.c: Convert C++ style comments to
C style.
* console/console.c, startup/init5235.c: Convert C++ style comments to
C style.
* startup/init5282.c: Convert C++ style comments to C style.
* console/fb_vga.c, console/kd.h: Convert C++ style comments to C
style.
* include/arm_mode_bits.h: Convert C++ style comments to C style.
* at91rm9200/include/at91rm9200.h,
at91rm9200/include/at91rm9200_dbgu.h,
at91rm9200/include/at91rm9200_emac.h,
at91rm9200/include/at91rm9200_gpio.h,
at91rm9200/include/at91rm9200_mem.h,
at91rm9200/include/at91rm9200_pmc.h, s3c2400/include/s3c2400.h:
memory autodetection code can easily fail (boards with
'reserved' regions - I experienced a hard lockup on a
dell precision 490 when writing past the bios-reported
memory size) I added code that a) tries to save
and use multiboot info, if present b) allows applications
to override/set memory size via a weak alias.
* libchip/network/greth.c, libchip/network/open_eth.c,
libchip/network/smc91111.c, libchip/network/sonic.c: Fix error
introduced by warning removal.
libchip/network/smc91111.c: Remove warnings and correct prototype
added earlier today.
* libchip/network/cs8900.c, libchip/network/greth.c,
libchip/network/i82586.c, libchip/network/open_eth.c,
libchip/network/sonic.c: Remove warnings -- use uintptr_t, properly
sized integers, and inttypes.h printf helpers.
* startup/bspstart.c: Revert patch adding new exception support code to
an old exception BSP.
* startup/bspstart.c: Add basic _BSP_Fatal_error.
to VME CSR space if the BSP defines _VME_CSR_ON_PCI
* Makefile.am, preinstall.am, startup/linkcmds, startup/linkcmds.brs5l,
startup/linkcmds.pm520: Add support for missing .rela sections.
Install linkcmds.
fixed bug in mscan
'frame' argument to C_dispatch_irq_handler(). It's
really a BSP_Exception_frame*, not a CPU_Interrupt_frame*.
* ChangeLog: New file.
* .cvsignore: New file.
* startup/linkcmds: Clean up a bit after adding missing .rela sections.
* clock/clock.c: New file.
* aclocal/rtems-cpu-subdirs.m4: New port to Altera NIOS II.
* nios2/Makefile.am, nios2/configure.ac, nios2/preinstall.am,
nios2/shared/cache/cache.c, nios2/shared/cache/cache_.h,
nios2/shared/misc/memcpy.c: New files.
* ChangeLog, Makefile.am, README, acinclude.m4, configure.ac,
nios2_iss/ChangeLog, nios2_iss/Makefile.am, nios2_iss/bsp_specs,
nios2_iss/configure.ac, nios2_iss/nios2_iss.ptf,
nios2_iss/nios2_iss.sh, nios2_iss/times, nios2_iss/console/console.c,
nios2_iss/include/bsp.h, nios2_iss/include/bspopts.h.in,
nios2_iss/include/coverhd.h, nios2_iss/include/tm27.h,
nios2_iss/shmsupp/addrconv.c, nios2_iss/shmsupp/getcfg.c,
nios2_iss/shmsupp/lock.c, nios2_iss/shmsupp/mpisr.c,
nios2_iss/start/crtnn.s, nios2_iss/start/start.S,
nios2_iss/startup/bspclean.c, nios2_iss/startup/bspstart.c,
nios2_iss/startup/linkcmds, nios2_iss/startup/main.c,
nios2_iss/startup/setvec.c, nios2_iss/timer/timer.c: New files.
* preinstall.am: Install spacewire.h
