Fixed bug where only the mbuf associated with the first TX fragment was
being freed.
to be a problem with overwriting the TX descriptors during an RX.
object code that has to be loaded just for initializing the signal
manager.
NULL pointer.
rtems_bsdnet_makeFdForSocket().
and eliminate a link error.
so that the libc code did not have to know about (struct socket).
split into multiple files.
Comments follow:
Here is the contents of the network directory of the i386ex BSP. The
reset function has been recently added, and tested through a command
line interface. A reset event to the reset thread to reset the NIC.
This is done when the ISR detects that the NIC is in an invalid state.
It has not been tested "in real life" since the board has not seen an
invalid state since the reset function was implemented.
outside RTEMS. Comment:
I found a couple of places other than RTEMS where I'd like to use
the declarations supplied in m68360.h. To make this easier to do,
I've redone the declarations in m68360.h to use standard C types.
<ian@airs.com> to fix this problem:
There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It
does not check whether the file descriptor it is passed is open. This
can cause it to make a null dereference if it is passed a file
descriptor which is in the valid range but which was not opened, or
which was already closed.
used in gcc.
with the --disable-posix option, stubs for some routines (_getpid_r and
_kill_r) that are normally defined with POSIX were added.
getting the spurious trap handling to work required a couple more
fixes - I have attached a patch against rtems-4.0.0 with the
necessary changes. I also added functionality so that the
address of the trapped instruction is reported and in case of
a data access error, the data address is also reported.
> > I think I have found a bug in src/exec/scor/sparc/cpu/erc32.h in:
> > #define ERC32_Disable_interrupt( _source, _previous ) \
> > do { \
> > unsigned32 _level; \
> > unsigned32 _mask = 1 << (_source); \
> > sparc_disable_interrupts( _level ); \
> > (_previous) = ERC32_MEC.Interrupt_Mask; \
> > ERC32_MEC.Interrupt_Mask = _previous | _mask; \
> > sparc_enable_interrupts( _level ); \
> > (_previous) &= ~_mask; \ <- IS THIS CORRECT...?
> > } while (0)
> > The previous interrupt mask is returned after first clearing the
> > bit to be disabled, regardless whether the bit was set before or
> > not. If the bit was set (interrupt masked), subsequent call to
> > ERC32_Restore_interrupt() will enable the interrupt even though
> > it was supposed to be masked. This is indeed what happens in
> > DEBUG_puts when polled console I/O is used. In my opinion, the
> > last statement in the macro should be removed - what is your opinion?
> I think the "~" shouldn't be there. I recall that the intent of that line
> is to only return the state of the interrupts you were concerned with.
> Removing the line returns entire state. Given that the value returned
> shuold only be used in conjunction with the map, I suppose either removing
> the ~ or the entire line is correct? I can go either way. Just let me
> know which you think is more correct and the source will change. :)
Hmmm, just removing the '~' should be OK. DEBUG_puts() seems to be the
only user of ERC32_Restore_interrupt() anyway ...
This problem should and likely was occurring with other BSPs. This is from
Chris' email:
I had a look in the psim bsp for the older snapshot I have and it looks
like you are using the `libbsp/shared/main.c' and this is known to work.
I have just built the powerpc tools, and compiled the bsp. I have not
added the linker command file patch so got the list of linker warnings.
It looks to me like a compiler bug. The `main' call is being inlined and
when that happens the special code to call `__eabi' is not being added
to the inlined version. I have attached a patch which places `main'
after `boot_card' and a call to main is now generated. I have not tested
it but it should work. I also include a dump of `boot_card' and `main'
showing the bug.
prototype.
properly in conditionals
compiler dependent flag in a Makefile.
automake:
* I didn't yet touch the cpu subdirectory. I still need some time to
think on how to handle them.
* I probably will wait for the next snapshot before mailing more patches
(I still have some pending), giving you a chance to apply them and me a
chance to become target of the bullets which will probably be aimed at
me after these modifications.
<corsepiu@faw.uni-ulm.de>.
