path: root/c/src (unfollow)
2001-09-212001-09-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+5
* scitab/Makefile.am: Remove stray blank from SCITAB rule.
2001-09-212001-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-2/+18
* configure.in, rootfs/Makefile.am: Added conditional to make sure rootfs does not get built with networking is disabled. Also added include of compile.am to rootfs/Makefile.am. * wrapup/Makefile.am: Added rootfs conditionally if networking enabled.
2001-09-212001-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-4/+13
* network/Makefile.am: Fixed typo on file name. * network/i82586.c: Commented out line 318 which is referencing a member of a structure that is not currently there. This needs to be worked out with Chris Johns <ccj@acm.org>. Switched C++ style comments to C style.
2001-09-212001-09-14 Fernando Ruiz <fernando.ruiz@ctv.es>Joel Sherrill2-1/+5
* src/tasks.c: Dereference pointer passed to destructor.
2001-09-192001-09-19 Eric Norum <eric.norum@usask.ca>Joel Sherrill2-26/+9
* README: Bring it more in line with reality.
2001-09-192001-09-19 Eric Norum <eric.norum@usask.ca>Joel Sherrill4-0/+78
* lib/tftpDriver.c: Add some debugging capability.
2001-09-192001-09-19 Chris Johns <ccj@acm.org>Joel Sherrill6-4/+2965
* network/README.i82586, network/i82586.c, network/i82586reg.h, network/i82586var.h: New files. Network driver for Intel i82586.
2001-09-192001-09-19 Chris Johns <ccj@acm.org>Joel Sherrill10-10/+208
* nfs/bootp_subr.c, rtems/rtems_bootp.c, rtems/rtems_bsdnet.h, rtems/rtems_bsdnet_internal.h Added support for populating the initial "root" filesystem with information obtained via the DHCP response.
2001-09-192001-09-19 Chris Johns <ccj@acm.org>Joel Sherrill11-1/+1299
* Added support for populating the initial "root" filesystem with information obtained via the DHCP response. * rootfs: New directory. * rootfs/.cvsignore, rootfs/Makefile.am, rootfs/mkrootfs.c, rootfs/mkrootfs.h: New files. * configure.in, Makefile.am: Modified to reflect addition.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill32-31/+65
* tm27/Makefile.am: include leaf.am instead of leaf.cfg. * tm26/Makefile.am: include leaf.am instead of leaf.cfg. * tm24/Makefile.am: include leaf.am instead of leaf.cfg. * tm16/Makefile.am: include leaf.am instead of leaf.cfg. * tm18/Makefile.am: include leaf.am instead of leaf.cfg. * tm02/Makefile.am: include leaf.am instead of leaf.cfg. * tm10/Makefile.am: include leaf.am instead of leaf.cfg. * tm11/Makefile.am: include leaf.am instead of leaf.cfg. * tm15/Makefile.am: include leaf.am instead of leaf.cfg. * tm19/Makefile.am: include leaf.am instead of leaf.cfg. * tm04/Makefile.am: include leaf.am instead of leaf.cfg. * tm17/Makefile.am: include leaf.am instead of leaf.cfg. * tm28/Makefile.am: include leaf.am instead of leaf.cfg. * tmck/Makefile.am: include leaf.am instead of leaf.cfg. * tm08/Makefile.am: include leaf.am instead of leaf.cfg. * tm12/Makefile.am: include leaf.am instead of leaf.cfg. * tm03/Makefile.am: include leaf.am instead of leaf.cfg. * tm13/Makefile.am: include leaf.am instead of leaf.cfg. * tm29/Makefile.am: include leaf.am instead of leaf.cfg. * tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg. * tm20/Makefile.am: include leaf.am instead of leaf.cfg. * tm09/Makefile.am: include leaf.am instead of leaf.cfg. * tm01/Makefile.am: include leaf.am instead of leaf.cfg. * tm21/Makefile.am: include leaf.am instead of leaf.cfg. * tm07/Makefile.am: include leaf.am instead of leaf.cfg. * tm25/Makefile.am: include leaf.am instead of leaf.cfg. * tm22/Makefile.am: include leaf.am instead of leaf.cfg. * tm06/Makefile.am: include leaf.am instead of leaf.cfg. * tm05/Makefile.am: include leaf.am instead of leaf.cfg. * tm14/Makefile.am: include leaf.am instead of leaf.cfg. * tm23/Makefile.am: include leaf.am instead of leaf.cfg.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+5
* tmitronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill30-29/+61
* sp20/Makefile.am: include leaf.am instead of leaf.cfg. * sp02/Makefile.am: include leaf.am instead of leaf.cfg. * sp19/Makefile.am: include leaf.am instead of leaf.cfg. * sp11/Makefile.am: include leaf.am instead of leaf.cfg. * sp25/Makefile.am: include leaf.am instead of leaf.cfg. * sp04/Makefile.am: include leaf.am instead of leaf.cfg. * spsize/Makefile.am: include leaf.am instead of leaf.cfg. * sp01/Makefile.am: include leaf.am instead of leaf.cfg. * sp16/Makefile.am: include leaf.am instead of leaf.cfg. * sp05/Makefile.am: include leaf.am instead of leaf.cfg. * sp09/Makefile.am: include leaf.am instead of leaf.cfg. * spfatal/Makefile.am: include leaf.am instead of leaf.cfg. * sp06/Makefile.am: include leaf.am instead of leaf.cfg. * sp23/Makefile.am: include leaf.am instead of leaf.cfg. * sp28/Makefile.am: include leaf.am instead of leaf.cfg. * sp03/Makefile.am: include leaf.am instead of leaf.cfg. * sp29/Makefile.am: include leaf.am instead of leaf.cfg. * sp13/Makefile.am: include leaf.am instead of leaf.cfg. * sp27/Makefile.am: include leaf.am instead of leaf.cfg. * sp14/Makefile.am: include leaf.am instead of leaf.cfg. * sp07/Makefile.am: include leaf.am instead of leaf.cfg. * sp15/Makefile.am: include leaf.am instead of leaf.cfg. * sp17/Makefile.am: include leaf.am instead of leaf.cfg. * sp22/Makefile.am: include leaf.am instead of leaf.cfg. * sp12/Makefile.am: include leaf.am instead of leaf.cfg. * sp26/Makefile.am: include leaf.am instead of leaf.cfg. * sp21/Makefile.am: include leaf.am instead of leaf.cfg. * sp24/Makefile.am: include leaf.am instead of leaf.cfg. * sp08/Makefile.am: include leaf.am instead of leaf.cfg.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill10-10/+23
* unlimited/Makefile.am: include leaf.am instead of leaf.cfg. * base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg. * base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg. * hello/Makefile.am: include leaf.am instead of leaf.cfg. * base_sp/Makefile.am: include leaf.am instead of leaf.cfg. * paranoia/Makefile.am: include leaf.am instead of leaf.cfg. * cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use make-cxx-exe. * ticker/Makefile.am: include leaf.am instead of leaf.cfg. * minimum/Makefile.am: include leaf.am instead of leaf.cfg.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill25-24/+51
* psx01/Makefile.am: include leaf.am instead of leaf.cfg. * psx11/Makefile.am: include leaf.am instead of leaf.cfg. * psxcancel/Makefile.am: include leaf.am instead of leaf.cfg. * psx02/Makefile.am: include leaf.am instead of leaf.cfg. * psx13/Makefile.am: include leaf.am instead of leaf.cfg. * psxtime/Makefile.am: include leaf.am instead of leaf.cfg. * psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg. * psx07/Makefile.am: include leaf.am instead of leaf.cfg. * psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg. * psxtimer/Makefile.am: include leaf.am instead of leaf.cfg. * psx10/Makefile.am: include leaf.am instead of leaf.cfg. * psx08/Makefile.am: include leaf.am instead of leaf.cfg. * psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg. * psxfile01/Makefile.am: include leaf.am instead of leaf.cfg. * psx05/Makefile.am: include leaf.am instead of leaf.cfg. * psx09/Makefile.am: include leaf.am instead of leaf.cfg. * psxmount/Makefile.am: include leaf.am instead of leaf.cfg. * psxstat/Makefile.am: include leaf.am instead of leaf.cfg. * psx12/Makefile.am: include leaf.am instead of leaf.cfg. * psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg. * psxsem01/Makefile.am: include leaf.am instead of leaf.cfg. * psx03/Makefile.am: include leaf.am instead of leaf.cfg. * psx04/Makefile.am: include leaf.am instead of leaf.cfg. * psx06/Makefile.am: include leaf.am instead of leaf.cfg.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill29-28/+59
* mp02/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp02/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp04/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp04/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp14/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp14/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp06/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp06/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp08/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp08/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp03/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp03/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp10/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp10/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp05/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp05/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp13/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp13/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp01/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp01/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp07/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp07/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp11/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp11/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp12/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp12/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp09/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp09/node1/Makefile.am: include leaf.am instead of leaf.cfg.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill9-9/+21
* malloctest/Makefile.am: include leaf.am instead of leaf.cfg. * monitor/Makefile.am: include leaf.am instead of leaf.cfg. * termios/Makefile.am: include leaf.am instead of leaf.cfg. * putenvtest/Makefile.am: include leaf.am instead of leaf.cfg. * rtems++/Makefile.am: include leaf.am instead of leaf.cfg, use make-cxx-exe. * stackchk/Makefile.am: include leaf.am instead of leaf.cfg. * rtmonuse/Makefile.am: include leaf.am instead of leaf.cfg. * cpuuse/Makefile.am: include leaf.am instead of leaf.cfg.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill10-9/+21
* itrontask03/Makefile.am: include leaf.am instead of leaf.cfg. * itrontask04/Makefile.am: include leaf.am instead of leaf.cfg. * itronmbf01/Makefile.am: include leaf.am instead of leaf.cfg. * itronsem01/Makefile.am: include leaf.am instead of leaf.cfg. * itronhello/Makefile.am: include leaf.am instead of leaf.cfg. * itrontime01/Makefile.am: include leaf.am instead of leaf.cfg. * itrontask01/Makefile.am: include leaf.am instead of leaf.cfg. * itrontask02/Makefile.am: include leaf.am instead of leaf.cfg. * itronmbox01/Makefile.am: include leaf.am instead of leaf.cfg.
2001-09-142001-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+41
* ChangeLog: Fixed some mistakes.
2001-09-142001-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
* ChangeLog: New file.
2001-09-132001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+5
* devnull/devnull.c: Eliminate warning.
* src/sysconf.c: Fix typo syntax error accidentally committed.
2001-09-132001-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-16/+21
* configure.in: autoupdate to autoconf-2.52, new CONFIG_SUBDIRS handling.
2001-09-132001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill5-5/+67
* src/mprotect.c: New file. Stub required by some gcc's to pass tests. In particular, about 350 ACATS tests fail if this is not present. * src/getpagesize.c: Ditto. * src/sysconf.c: Addition of Solaris value for _SC_STACK_PROT required to pass about 350 ACATS test cases. * src/Makefile.am: Added new files.
2001-08-312001-08-31 Eric Valette <valette@crf.canon.fr>Joel Sherrill4-16/+18
* network/network.c: Fix to account for return value when installing interrupts handler.
2001-08-302001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-2/+7
* startup/linkcmds: Modified to work better with gcc 2.8.1 and gnat 3.13p.
2001-08-302001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill5-52/+76
* src/coremutex.c, src/coremutexseize.c, src/coremutexsurrender.c, inline/rtems/score/coremutex.inl: The per thread field resource_count should only be manipulated when a mutex is priority ceiling or priority inherit. This was reported by Chris Johns <ccj@acm.org> who also noticed that the use of switches for all disciplines generated less efficient code than using explicit tests for the one or two cases we were really interested in. Further review of his modifications made it apparent that the "isa" methods to test mutex discipline were not being used so this modification was swept into the code as well.
2001-08-302001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+6
* inline/rtems/rtems/attr.inl: Correct typo and use correct attribute RTEMS_SYSTEM_TASK. Reported by Chris Johns <ccj@acm.org>.
2001-08-302001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+7
* src/coremutexseize.c: Add missing code for proper handling of nesting acquisitions. This only impacts building with inlines disabled on the source with the "fast mutex" optimizations. This was post the 4.5 branch and did not impact released versions.
2001-08-302001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+7
* macros/rtems/posix/mqueue.inl: Add cast so negation works.
2001-08-172001-08-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+5
* include/Makefile.am: Include coverhd.h so tmtests will compile.
2001-08-172001-08-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill6-0/+66
* include/rtems/libio_.h: Added ifdef to ensure that LOGIN_NAME_MAX is defined on GNU/Linux (RedHat 6.2 distribution). * libc/unixlibc.c: Added stubs for rtems_io_register_name() and rtems_io_lookup_name() so UNIX port would compile the IO manager sptest that registers /dev/null.
2001-08-172001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill5-2/+48
* pppd/STATUS: Updated by Joel based upon email from Mike. * pppd/cbcp.c, pppd/cbcp.h: Readded files. These support callback functionality that has not even been compiled under RTEMS yet.
2001-08-172001-08-10 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill1-0/+15
* score/cpu_asm.c (sh_set_irq_priority): Changed interrupt vector number range check and handling of interrupt priority regs to conform SH2 specs. * sci/sci_termios.c: New file. * include/sci_termios.h: New file. * include/Makefile.am (EXTRA_DIST): Added sci_termios.h. (include_sh_HEADERS): Added sci_termios.h. * score/ispsh7045.c (isp): Calling an ISR with immediate argument casued negative sign extension for vector numbers of 128 and above. This was fixed. * sci/sci.c: Cleaned initialization of SCI registers; added necessary setup for new TERMIOS console cooperation
2001-08-172001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-6/+4
* libc/lseek.c: Modified after discussion with Eugeny S. Mints <jack@oktet.ru> to correct the behavior. There were two mistakes. First, iop->offset was incorrectly set for SEEK_END. Second, iop->offset should be left unmodified if there are errors. This modification attempts to fix both situations.
2001-08-162001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-12/+60
2001-08-162001-08-10 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill2-0/+531
2001-08-162001-08-01 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill1-0/+137
* include/bsp.h: Disabled redefinition of CONSOLE_DRIVER_TABLE_ENTRY. Some "FIXME:" comments added. * console/config.c: New file. Definitions of externs referenced from libbsp/shared/console.c. * console/Makefile.am: Changed VPATH to point to libbsp/shared. Added config.c to C_FILES and EXTRA_DIST.
2001-08-162001-08-26 Brett Swimley <brett.swimley@aedinc.net>Joel Sherrill1-4/+6
* mw-fb\Makefile.am: Corrected problem.
2001-08-162001-07-25 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill2-1/+10
* cpu.c (_CPU_ISR_install_vector): Corrected interrupt range checking which was SH1 specific. It didn't work for SH2 (has more interrupt sources).
2001-08-162001-08-10 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill7-24/+161
2001-08-162001-08-01 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill5-11/+35
2001-08-162001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-1/+15
* pppd/example/Makefile: Removed. * pppd/example/Makefile-user: Added was Makefile. Renamed to avoid bootstrap -c clobbering it.
2001-08-162001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill2-0/+84
* libc/termios.c: Fix a bug in the termios implementation in the following scenario: The General Terminal Interface document that me states that if VMIN = 0 and VTIME = 0, then read() should return the minimum of two values: a) number of bytes available b) number of bytes requested (I assume from the read call) The current implementation of the fillBufferQueue() in termios.c is always return 1 character with these setting values. I know the termios buffer has more than one character available and my read() call is requesting 1024 bytes.
2001-08-162001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill3-4/+20
* comm/tty_drv.c, comm/uart.c: Correct some minor cut and paste bugs.
2001-08-162001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill5-0/+37
* include/rtems/termiostypes.h, include/sys/ioccom.h: Update of PPPD to 2.3.11 from 2.3.5 touched these files.
2001-08-162001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill49-6042/+7465
* Update of PPPD to 2.3.11 from 2.3.5 and addition of an example application. Mike's notes on the modifications: - renamed error() function because of namespace problems - removed calls to the exit() funciton - removed extra files from the pppd source directory - defined pppd task constant values in rtemspppd.h - modifyied example code to get actual tick per second value - placed the pppd 2.3.11 man page file (pppd.8) into the pppd directory * pppd/cbcp.c, pppd/cbcp.h, pppd/main.c, pppd/ppp_tty.c, pppd/pppmain.c, pppd/rtems-ppp.c, pppd/rtems-ppp.c: Deleted. * pppd/pppd.8, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/utils.c, pppd/example/Makefile, pppd/example/README, pppd/example/init.c, pppd/example/netconfig.h, pppd/example/ppp.conf, pppd/example/pppdapp.c, pppd/example/system.h: New files. * modem/ppp_tty.c, net/if_ppp.h, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.h, pppd/upap.c, pppd/upap.h: Modified.
2001-08-162001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill3-16/+37
2001-08-162001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+8
* clock/clock.c: Ensure that clock ticks are long enough to make forward progress. This was modified to improve results on the RTEMS tests and the ACATS. * startup/linkcmds: Modified to work better with gcc 2.8.1 and gnat 3.13p.
2001-08-162001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+6
* src/msgqsubmit.c: Add a comment indicating that we do not have to account for possibly blocking during the core send operation because Classic API message queue send is always non-blocking.
2001-08-162001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+5
* src/mqueuesendsupp.c: Account for possibly blocking during the core send operation.
