* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 1 | -15/+10 |
| | | | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. + Set correct error code when dormant state. + Fixed comment. | ||||
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 1 | -5/+2 |
| | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. | ||||
* | Corrected so now actually indexes into the allocation block. | Joel Sherrill | 1999-11-12 | 1 | -10/+6 |
* | Corrected remaining references to struct rtems_task_variable_t since | Joel Sherrill | 1999-11-12 | 2 | -7/+11 |
| | | | | it is now typedef'ed. | ||||
* | Removed unnecessary 3rd parameter. | Joel Sherrill | 1999-11-12 | 1 | -1/+1 |
* | New file. | Joel Sherrill | 1999-11-12 | 1 | -0/+13 |
* | Used typedef so all "struct rtems_task_variable_t" uses are now | Joel Sherrill | 1999-11-12 | 4 | -19/+19 |
| | | | | just "rtems_task_variable_t". | ||||
* | Added per-task variable data stucture (rtems_task_variable_t), | Joel Sherrill | 1999-11-12 | 1 | -4/+36 |
| | | | | | task_variables field to API extension, and two directives (rtems_task_variable_add and rtems_task_variable_delete). | ||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 6 | -8/+9 |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 2 | -6/+11 |
| | | | | Changed output to reflect what was actually being tested. | ||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 4 | -5/+9 |
| | | | | Increased stack space. | ||||
* | Added per task variables based on patch from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-12 | 4 | -4/+224 |
| | | | | | After being submitted, this support was rewritten to be inside the executive rather than layered on top of it using an extension. | ||||
* | Cleaned up style. | Joel Sherrill | 1999-11-12 | 1 | -243/+239 |
* | Removed redundant line. | Joel Sherrill | 1999-11-12 | 1 | -1/+0 |
* | Enabled after merging message buffer code. | Joel Sherrill | 1999-11-12 | 1 | -6/+2 |
* | Added comment block and removed include of deleted file. | Joel Sherrill | 1999-11-12 | 1 | -1/+4 |
* | Updated. | Joel Sherrill | 1999-11-11 | 1 | -4/+15 |
* | Screen updated. | Joel Sherrill | 1999-11-11 | 1 | -0/+2 |
* | Added new test sp28 to test the task variable directives. | Joel Sherrill | 1999-11-11 | 6 | -1/+180 |
* | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 1999-11-10 | 15 | -22/+81 |
| | | | | | prints a message instead of actually testing since the message buffer implementation is not in yet. | ||||
* | Corrected to account for the way memory is divided up in | Joel Sherrill | 1999-11-10 | 1 | -7/+9 |
| | | | | | _Object_Extend_information. This change is a side-effect of the change made to that file to fix an alignment problem. | ||||
* | Added line to make sure HAS_ITRON_API is defined in Makefile. | Joel Sherrill | 1999-11-10 | 1 | -2/+1 |
* | Added call to _Thread_Enable_dispatch() and did some cleanup. | Joel Sherrill | 1999-11-10 | 1 | -2/+9 |
* | rtems_semaphore_flush test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-10 | 7 | -28/+186 |
* | Patch from Eric Norum <eric@cls.usask.ca> which includes: | Joel Sherrill | 1999-11-10 | 7 | -17/+327 |
| | | | | | Patches against 1105 snapshot to add NTP server support to network configuration/BOOTP. | ||||
* | Combination of committing some new files which had been overlooked | Joel Sherrill | 1999-11-10 | 13 | -1/+463 |
| | | | | and adding code which installed screens for itron tests. | ||||
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-10 | 35 | -289/+696 |
| | | | | Working Group. Included are tests. | ||||
* | Added support for ITRON tests. | Joel Sherrill | 1999-11-10 | 1 | -0/+2 |
* | Added more tasking tests. | Joel Sherrill | 1999-11-09 | 2 | -1/+5 |
* | Merged tests from Task group. | Joel Sherrill | 1999-11-09 | 36 | -38/+2031 |
* | Added nesting count for suspend/resume. | Joel Sherrill | 1999-11-09 | 1 | -1/+1 |
* | Changed B, H, and W variables to BVar, HVar, and WVar to avoid conflicts | Joel Sherrill | 1999-11-09 | 1 | -35/+35 |
| | | | | | with ITRON 3.0 data types regardless of how dumb it is to name types with a simple letter. | ||||
* | Commented out single letter type names since they conflict with | Joel Sherrill | 1999-11-09 | 1 | -0/+6 |
| | | | | numerous other uses of the same variable. | ||||
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 7 | -14/+12 |
| | | | | for RTEMS. | ||||
* | Removed. | Joel Sherrill | 1999-11-09 | 5 | -298/+0 |
* | Renamed classes to avoid single letter class names. | Joel Sherrill | 1999-11-09 | 1 | -10/+10 |
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 126 | -41/+9601 |
| | | | | for RTEMS. | ||||
* | Fixed warning where initialized default POSIX API structure did | Joel Sherrill | 1999-11-09 | 1 | -0/+2 |
| | | | | have have semaphores and message queue fields. | ||||
* | Removed unused variable warning. | Joel Sherrill | 1999-11-09 | 1 | -1/+0 |
* | Now using libchip instead of local precursor to libchip. Untested. | Joel Sherrill | 1999-11-09 | 10 | -2274/+86 |
* | Removed reaching "up and over" to install BSP header files. | Joel Sherrill | 1999-11-09 | 3 | -6/+3 |
* | Added imfs_unixstub.c to satisfy linker problems on UNIX port. | Joel Sherrill | 1999-11-09 | 4 | -1/+215 |
* | sem_close was accidentally lost in the split. | Joel Sherrill | 1999-11-09 | 2 | -1/+48 |
* | New test for POSIX Message Queues added. | Joel Sherrill | 1999-11-09 | 6 | -1/+171 |
* | New files. | Joel Sherrill | 1999-11-09 | 4 | -0/+303 |
* | Patch from Eric Norum <eric@cls.usask.ca> to add NTP BOOTP support because | Joel Sherrill | 1999-11-09 | 6 | -2/+96 |
| | | | | | | | | EPICS needs a synchronized time-of-day clock. This patch is the changes needed to get NTP server information from a BOOTP server. This patch also adds NTP server information to the network configuration structure, too. | ||||
* | Added #define to make this file exactly like its siblings in mpc821 | Joel Sherrill | 1999-11-09 | 1 | -1/+2 |
| | | | | and mpc860 directories. | ||||
* | Removed "up and over" into libbsp/.../include. | Joel Sherrill | 1999-11-09 | 2 | -3/+1 |
* | Moved include files to hppa1.1 subdirectory and put their sources | Joel Sherrill | 1999-11-09 | 6 | -10/+65 |
| | | | | in the include directory. | ||||
* | Removed runway directory and moved contents to include. | Joel Sherrill | 1999-11-09 | 2 | -77/+0 |
