path: root/c/src (unfollow)
2002-04-032001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-58/+9
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/no_cputypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
2002-04-032001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill8-133/+18
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/mipstypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
2002-04-032001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+7
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/m68ktypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
2002-04-032001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-59/+9
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/i960types.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/i386types.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
2002-04-032001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-48/+9
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/hppa1.1types.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/h8300types.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/c4xtypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
2002-04-032001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill8-115/+18
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/a29ktypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
2002-04-032002-04-03 Alexander Kukuta <kam@oktet.ru>Joel Sherrill4-4/+14
* include/rtems/bdbuf.h: Address PR168 by changing bdbuf_buffer.avl.bal and bdbuf_buffer.avl.cache to signed char instead of char.
2002-04-022001-03-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-13/+18
* Per PR126, configuration structures now match docs. * include/rtems/config.h: Use public data types.
2002-04-022001-04-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+5
* bootloader/Makefile.am: Use AM_CCASFLAGS instead of AM_ASFLAGS.
2002-04-022001-03-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-9/+14
* Per PR126, configuration structures now match docs. * include/rtems/rtems/config.h: Use public data types.
2002-04-012002-03-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-15/+4
* configure.ac: Update, remove code rott.
2002-04-012002-03-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill4-18/+26
* libc/rcmd.c: Replace __rtems w/ __rtems__.
2002-03-292001-03-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill6-77/+73
* Per PR147 addressed problems when reseting and inserting a timer into a timer chain that did not honor time passage since the last time the timer server was scheduled and the new insertion. * include/rtems/rtems/timer.h, src/timerreset.c, src/timerserver.c, src/timerserverfireafter.c, src/timerserverfirewhen.c: Broke up the "reset server" routine into a set of very specific routines that allowed the server to be unscheduled, timer chains to be "synchronized" with the current time before inserting a new timer.
2002-03-292001-03-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-5/+78
* Per PR147 addressed problems when reseting and inserting a timer into a timer chain that did not honor time passage since the last time the timer server was scheduled and the new insertion. * sp31/sp31.scn, sp31/task1.c: Added test code to detect this case.
2002-03-292002-03-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill7-2/+135
* tbr/Makefile.am: New file. * tbr/.cvsignore: New file. * tbr/tbr.c: New file. * tbr/tbr.h: New file. * configure.ac: Add tbr subdir. * Makefile.am: Add tbr subdir.
2002-03-292002-03-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill6-2/+30
* configure.ac: Add BSPOPTS_*(NO_TABLE_MOVE). Add BSPOPTS_*(FPU_REVB). * wrapup/Makefile.am: Add tbr.
2002-03-292002-03-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-32/+10
* cpu.c: Replace NO_TABLE_MOVE-support by external function (code moved to libcpu/sparc/tbr/tbr.c). * cpu.h: Replace NO_TABLE_MOVE-support by external function (code moved to libcpu/sparc/tbr/tbr.h). * sparc.h: Add sparc_init_tbr (implemented in libcpu/sparc/tbr/tbr.c).
2002-03-282001-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-6/+29
* PR132 requested some tinkering ot lower memory. * include/confdefs.h: Lowered footprint of device driver table and statically configure user extensions. Now if no static extensions are configured, then the table is not instantiated.
2002-03-282001-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-5/+6
* Side-effect of PR132. * sp21/system.h: Now must explicitly request NULL driver.
2002-03-282001-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+7
* cpu.c: Define fix_syscall_errno() to nothing so MP links.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill6-8/+18
* src/dosfs/fat_file.c: Remove bsp.h. fat_file_write(.. const char*buf ..). * src/dosfs/fat_file.h: fat_file_write(.. const char*buf ..).
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-0/+5
* include/bsp.h: include <libcpu/cpu.h>.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-2/+6
* include/bsp.h: include <libcpu/cpu.h>. * console/console.c: Remove unused variable console_open_count.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill209-210/+488
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill5-5/+11
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * sapi/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * compilers/Makefile.am: Remove AUTOMAKE_OPTIONS. * custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill15-15/+33
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill20-20/+32
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill15-15/+21
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/rdbg/i386/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rdbg/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rdbg/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rdbg/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/i386/any/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/i386/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/m68k/any/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/powerpc/new_exception_processing/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill34-34/+50
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * arpa/Makefile.am: Remove AUTOMAKE_OPTIONS. * kern/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * lib/Makefile.am: Remove AUTOMAKE_OPTIONS. * libc/Makefile.am: Remove AUTOMAKE_OPTIONS. * machine/Makefile.am: Remove AUTOMAKE_OPTIONS. * net/Makefile.am: Remove AUTOMAKE_OPTIONS. * netinet/Makefile.am: Remove AUTOMAKE_OPTIONS. * nfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * pppd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS. * sys/Makefile.am: Remove AUTOMAKE_OPTIONS. * vm/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * cpuuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * devnull/Makefile.am: Remove AUTOMAKE_OPTIONS. * dummy/Makefile.am: Remove AUTOMAKE_OPTIONS. * dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS. * monitor/Makefile.am: Remove AUTOMAKE_OPTIONS. * mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS. * rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtmonuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * shell/Makefile.am: Remove AUTOMAKE_OPTIONS. * stackchk/Makefile.am: Remove AUTOMAKE_OPTIONS. * untar/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill14-14/+26
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * src/dosfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/imfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill6-6/+12
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * network/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * rtc/Makefile.am: Remove AUTOMAKE_OPTIONS. * serial/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill8-9/+13
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill7-7/+13
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * cache/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * reg_win/Makefile.am: Remove AUTOMAKE_OPTIONS. * syscall/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill16-16/+28
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * sci/Makefile.am: Remove AUTOMAKE_OPTIONS. * score/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill9-9/+15
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * delay/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * sci/Makefile.am: Remove AUTOMAKE_OPTIONS. * score/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill40-40/+46
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * mpc505/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc505/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc505/timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc505/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc6xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc6xx/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc6xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc6xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc6xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc6xx/wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8260/clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8260/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8260/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8260/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8260/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8260/include/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8260/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8260/timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8xx/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8xx/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8xx/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8xx/include/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS. * mpc8xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * ppc403/clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * ppc403/Makefile.am: Remove AUTOMAKE_OPTIONS. * ppc403/console/Makefile.am: Remove AUTOMAKE_OPTIONS. * ppc403/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS. * ppc403/timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * ppc403/tty_drv/Makefile.am: Remove AUTOMAKE_OPTIONS. * ppc403/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS. * shared/include/Makefile.am: Remove AUTOMAKE_OPTIONS. * shared/Makefile.am: Remove AUTOMAKE_OPTIONS. * shared/src/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill10-10/+22
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill17-17/+23
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * mongoosev/duart/Makefile.am: Remove AUTOMAKE_OPTIONS. * mongoosev/Makefile.am: Remove AUTOMAKE_OPTIONS. * mongoosev/include/Makefile.am: Remove AUTOMAKE_OPTIONS. * mongoosev/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS. * r46xx/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS. * r46xx/Makefile.am: Remove AUTOMAKE_OPTIONS. * shared/cache/Makefile.am: Remove AUTOMAKE_OPTIONS. * shared/Makefile.am: Remove AUTOMAKE_OPTIONS. * shared/interrupts/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * tx39/include/Makefile.am: Remove AUTOMAKE_OPTIONS. * tx39/Makefile.am: Remove AUTOMAKE_OPTIONS. * tx39/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * m68040/fpsp/Makefile.am: Remove AUTOMAKE_OPTIONS. * m68040/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * shared/cache/Makefile.am: Remove AUTOMAKE_OPTIONS. * shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill8-8/+14
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * mbus/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * i960ca/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * i960ka/Makefile.am: Remove AUTOMAKE_OPTIONS. * i960rp/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * milli/Makefile.am: Remove AUTOMAKE_OPTIONS. * semaphore/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill7-6/+9
* cpu/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill12-10/+16
* Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
