path: root/c/src (follow)
* 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-071-0/+6
| | | | | | * console/console.c: Eliminate unsigned32, unsigned8. * include/bsp.h: Eliminate unsigned32. * startup/bspstart.c: Eliminate unsigned32.
* Eliminate unsigned32.Ralf Corsepius2005-11-074-10/+10
* Eliminate unsigned32, unsigned8.Ralf Corsepius2005-11-071-3/+3
| | | | | | * include/bsp.h: Eliminate unsigned32. * network/network.c: Several minor bug fixes. * startup/bspstart.c: Eliminate unsigned32.
* Several minor bug fixes.Ralf Corsepius2005-11-071-1/+6
* 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-071-2/+7
| | | | | * mpc6xx/mmu/pte121.c: Eliminate unsigned32. * mpc8xx/clock/clock.c: Eliminate rtems_unsigned32.
* Eliminate rtems_unsigned32.Ralf Corsepius2005-11-071-2/+2
* Eliminate unsigned32.Ralf Corsepius2005-11-071-4/+4
* 2005-11-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-061-4/+9
| | | | | * libchip/i2c/i2c-2b-eeprom.c: Eliminate obsolete types. * libchip/rtc/mc146818a.h: Eliminate obsolete types.
* Eliminate obsolete types.Ralf Corsepius2005-11-062-3/+3
* 2005-11-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-061-0/+4
| | | | * shared/irq/idt.c: Reflect API changes.
* Reflect API changes.Ralf Corsepius2005-11-061-3/+3
* 2005-11-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-061-3/+8
| | | | * timer/timer.c: Remove C++-style comments.
* Remove C++-style comments.Ralf Corsepius2005-11-061-2/+2
* 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-041-1/+6
| | | | | * libchip/network/dec21140.c, libchip/network/elnk.c: Use libcpu/byteorder.h for i386.
* Use libcpu/byteorder.h for i386.Ralf Corsepius2005-11-042-21/+8
* 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-041-0/+2
| | | | | * Makefile.am: Add preinstall.am * preinstall.am: New.
* Add preinstall.amRalf Corsepius2005-11-041-23/+6
* NewRalf Corsepius2005-11-041-0/+34
* 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-042-0/+5
| | | | * configure.ac: Add AMPOLISH3.
* 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-041-0/+4
| | | | * byteorder.h: New.
* New.Ralf Corsepius2005-11-041-0/+22
* 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-041-0/+1
| | | | * shared/include/byteorder.h: Remove __arch_swap (Unused).
* Remove __arch_swap (Unused).Ralf Corsepius2005-11-041-43/+0
* 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-043-4/+7
| | | | | * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. * Makefile.am: Distibute mongoosev's READMEs
* 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-046-6/+12
* Cleanup.Ralf Corsepius2005-11-041-27/+8
* Merge new-exceptions/ChangeLogRalf Corsepius2005-11-041-82/+132
* Remove (Merged into ../ChangeLog)Ralf Corsepius2005-11-041-169/+0
* CleanupRalf Corsepius2005-11-041-19/+4
* Merge old-exceptions/ChangeLogRalf Corsepius2005-11-041-817/+609
* Remove (Merged into ../ChangeLog)Ralf Corsepius2005-11-041-192/+0
* 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-042-6/+13
| | | | * Makefile.am: Partially cleanup EXTRA_DIST.
* 2005-11-04 Till Straumann <strauman@slac.stanford.edu>Till Straumann2005-11-048-213/+3524
| | | | | | | | | | | | | | | | | | | | | | | * shared/vmeUniverse/vmeTsi148.c, shared/vmeUniverse/vmeTsi148.h, shared/vmeUniverse/vme_am_defs.h: New files. * Makefile.am, shared/vmeUniverse/README.universe, shared/vmeUniverse/vmeUniverse.c, shared/vmeUniverse/vmeUniverse.h: Several VME related upgrades and fixes, hopefully addressing PR#835: vmeUniverse driver now supports shared interrupts. vmeUniverse now supports up to four wires between universe and PIC. A new irq mgr installation routine has been added allowing to use the new features. (old version is still present for bwd compatibility). Calls have been added to change interrupt routing (e.g., if wires have different priorities at the PIC this feature can be used to configure priorites). Routine for testing VME interrupts has been added (useful during BSP development). A new header defining standard VME address modes has been added so that the VME API doesn't have to #include a particular bridge driver header. For all driver entry points, a 'XX' variant has been added which allows to pass the chip's base address [in case a second universe is sitting on a VME card :-)]. Driver now uses interrupt line as read from PCI config. space (without offset) BSP needs to use PCI fixup if necessary. Added a driver for the tundra tsi148 VME bridge.
* 2005-11-03 Till Straumann <strauman@slac.stanford.edu>Till Straumann2005-11-048-117/+275
| | | | | | | | | | | * shared/vme/README, shared/vme/vme_universe.c: New files. * Makefile.am, motorola_powerpc/Makefile.am, mvme5500/vme/vmeconfig.c, shared/vme/VME.h, shared/vme/VMEConfig.h, shared/vme/vmeconfig.c: Several VME related upgrades and fixes, hopefully addressing PR#835: Separated API, API-implementation by a specific VME bridge driver and BSP-specific configuration of the driver into different files, describing their purpose in a README. All of these changes use the upgraded vmeUniverse.c driver.
* CosmeticsRalf Corsepius2005-11-041-1/+2
* Regenerate.Ralf Corsepius2005-11-041-8/+9
* 2005-11-03 Till Straumann <strauman@slac.stanford.edu>Till Straumann2005-11-042-1/+7
| | | | | | * include/bsp.h, vme/vmeconfig.c: Reverted redefinition of _IO_BASE; this normally points to ISA space but is misused by this BSP (inb/outb & friends are all over the place).
* 2005-11-03 Till Straumann <strauman@slac.stanford.edu>Till Straumann2005-11-043-2/+5
| | | | | * irq/irq.c, irq/irq.h: removed BSP_SHARED_HANDLER_SUPPORT definition; this BSP does not implement sharing interrupts.
* Added reference to PR#832Till Straumann2005-11-041-2/+2
* corrected redundant PR numberTill Straumann2005-11-041-1/+1
* 2005-11-03 Till Straumann <strauman@slac.stanford.edu>Till Straumann2005-11-045-202/+489
| | | | | | | | | | | | | | * shared/motorola/motorola.c, shared/pci/detect_raven_bridge.c, shared/pci/pci.c, shared/pci/pci.h, shared/pci/pcifinddevice.c: Several PCI enhancements and fixes: all BSP flavors now use the generic clear_hostbridge_errors() routine (this means that only polling memory probing is possible [see detect_raven_bridge.c for details]). Interrupt fixup routine now supports multi-function devices. Interrupt fixup routine now honours a flag/option so that wrong firmware values can be overridden. Fixed irq routing table for mvme2100 [PMC]. Added irq routing table for mvme2300. Added a BSP_pciScan() routine that executes a user callback on each non-empty slot/fun. Added BSP_pciConfigDump() to display basic config headers.
* 2005-11-03 Till Straumann <strauman@slac.stanford.edu>Till Straumann2005-11-042-1/+5
| | | | * include/bsp.h: fixed misuse of _IO_BASE
* Added reference to PR#838Till Straumann2005-11-041-4/+4
* 2005-11-03 <strauman@slac.stanford.edu>Till Straumann2005-11-042-14/+3
| | | | | | | | * shared/console/reboot.c, shared/start/start.S: Fixed PR#845; !!enable MMU!! on mvme2100 - this is very important. Otherwise, all accesses are write-back cached [incl. memory-mapped devices]. (Prerequisite were the changes to shared/startup/bspstart.c just below.) Implemented rtemsReboot() for mvme2100.
* 2005-11-03 <strauman@slac.stanford.edu>Till Straumann2005-11-048-340/+394
| | | | | | | | | | * shared/irq/openpic_i8259_irq.c: New file. * ChangeLog, Makefile.am, motorola_powerpc/ChangeLog, motorola_powerpc/Makefile.am, shared/irq/irq.c, shared/irq/irq.h, shared/irq/irq_asm.S, shared/irq/irq_init.c: Separated openpic/i8259 specifica from generic irq handling into openpic_i8259_irq.c; added some compilation conditionals to help BSPs without ISA to omit ISA interrupts and calling i8259 code.
* 2005-11-03 <strauman@slac.stanford.edu>Till Straumann2005-11-043-9/+68
| | | | | | * Makefile.am, include/bsp.h: Added new shared pretaskinghook.c and zerobss.c files to list to be made. Added some explanations about CPU <-> PCI <-> VME address mapping issues.
* 2005-11-03 <strauman@slac.stanford.edu>Till Straumann2005-11-044-100/+153
| | | | | | | | | | | * shared/startup/pretaskinghook.c, shared/startup/zerobss.c: New files. * Makefile.am, shared/startup/bspstart.c: Split pretaskinghook and zerobss into separate, reusable files; Fixed #PR837 (set exception in ram flag before initializing exceptions); Setup DBATs early, they are needed to access peripherals (Allows mvme2100 to use MMU); moved VME initialization into pretasking hook so that shared interrupts can be used for VME [shared IRQ facility needs functional workspace].
* 2005-11-03 <strauman@slac.stanford.edu>Till Straumann2005-11-044-15/+29
| | | | | | | | | * mvme5500/irq/irq.h, psim/irq/irq.h, shared/console/uart.c, shared/irq/irq.h: Renamed BSP_ISA_UART_COMx_IRQ -> BSP_UART_COMx_IRQ (uart driver is ISA independent). Removed ugly #ifdef mvme2100. Added test for BSP_UART_USE_SHARED_IRQS symbol which a BSP can define to request that the serial interrupt be shared.
* 2005-11-03 straumanatslacdotstanforddoteduTill Straumann2005-11-031-4/+2
| | | | * ChangeLog: corrected list of affected files
