* | It is now not an error to have 0 RTEMS initialization tasks since you could | Joel Sherrill | 1996-05-29 | 1 | -0/+6 |
| | | | | create POSIX initialization threads. | ||||
* | renamed signal.c to psignal.c to avoid naming problems. | Joel Sherrill | 1996-05-29 | 5 | -7/+119 |
| | | | | | | added mp stubs to cond.c and mutex.c to eliminate link errors. added pthread_exit to pthread.c | ||||
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 93 | -226/+372 |
| | | | | score, rtems api, or posix api related. | ||||
* | added maximum keys | Joel Sherrill | 1996-05-28 | 2 | -2/+2 |
* | added enumerated constant for the POSIX API as an error source | Joel Sherrill | 1996-05-28 | 2 | -2/+4 |
* | added initial set of api extension callouts | Joel Sherrill | 1996-05-28 | 5 | -6/+166 |
* | new file | Joel Sherrill | 1996-05-28 | 1 | -0/+72 |
* | commented out interrupt support | Joel Sherrill | 1996-05-28 | 2 | -0/+4 |
* | added ifndef's for the POSIX maximum field in the POSIX api configuration table | Joel Sherrill | 1996-05-28 | 2 | -2/+12 |
* | added posix api initialization call to init.c | Joel Sherrill | 1996-05-28 | 2 | -1/+5 |
| | | | | deleted a blank line in rtemsapi.c | ||||
* | comment cleanup | Joel Sherrill | 1996-05-28 | 2 | -4/+2 |
* | added maximum keys | Joel Sherrill | 1996-05-28 | 2 | -0/+2 |
* | made posix configuration information conditional so configurations wanting | Joel Sherrill | 1996-05-28 | 4 | -2/+98 |
| | | | | only the rtems api don't have to include it. | ||||
* | fixed typo | Joel Sherrill | 1996-05-28 | 1 | -1/+1 |
* | changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler. | Joel Sherrill | 1996-05-28 | 1 | -1/+1 |
| | | | | | _ISR_Enable() takes the magic cookie expected by the cpu's status register instead of a simple isr level. | ||||
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 34 | -107/+326 |
* | new file | Joel Sherrill | 1996-05-24 | 14 | -0/+337 |
* | changed version to 3.5.17 | Joel Sherrill | 1996-05-24 | 2 | -2/+2 |
* | added Motorola MVME147 BSP submitted by Dominique le Campion | Joel Sherrill | 1996-05-24 | 11 | -0/+1427 |
| | | | | | (Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and T.N.I. (Brest, France) | ||||
* | new file | Joel Sherrill | 1996-05-24 | 1 | -0/+50 |
* | updates from Tony Bennett to correct calling sequences. | Joel Sherrill | 1996-05-24 | 2 | -0/+2 |
* | new files | Joel Sherrill | 1996-05-24 | 3 | -4/+111 |
* | updates to fix typos | Joel Sherrill | 1996-05-24 | 3 | -35/+35 |
* | new file | Mark Johannes | 1996-05-24 | 1 | -0/+22 |
* | added use of sporadic server scheduling parameters | Joel Sherrill | 1996-05-24 | 7 | -0/+58 |
* | new files | Joel Sherrill | 1996-05-24 | 3 | -0/+96 |
* | clean up on DELAYTIMER_MAX | Joel Sherrill | 1996-05-23 | 3 | -12/+0 |
* | new files | Joel Sherrill | 1996-05-23 | 6 | -0/+204 |
* | unused variable | Joel Sherrill | 1996-05-23 | 1 | -1/+0 |
* | new files | Joel Sherrill | 1996-05-23 | 8 | -0/+208 |
* | new files | Joel Sherrill | 1996-05-23 | 7 | -0/+184 |
* | new files | Joel Sherrill | 1996-05-23 | 3 | -0/+75 |
* | new files | Joel Sherrill | 1996-05-23 | 5 | -0/+144 |
* | new files | Joel Sherrill | 1996-05-23 | 4 | -0/+110 |
* | cleanup | Joel Sherrill | 1996-05-23 | 8 | -12/+12 |
* | new files | Joel Sherrill | 1996-05-23 | 8 | -0/+254 |
* | cleanup status vs. result | Joel Sherrill | 1996-05-23 | 29 | -48/+48 |
* | new files | Joel Sherrill | 1996-05-23 | 5 | -0/+152 |
* | new files | Joel Sherrill | 1996-05-23 | 4 | -0/+134 |
* | new files | Joel Sherrill | 1996-05-23 | 2 | -0/+60 |
* | new files | Joel Sherrill | 1996-05-23 | 6 | -0/+200 |
* | new files | Joel Sherrill | 1996-05-23 | 9 | -0/+288 |
* | updated to reflect more constants and feature macros | Joel Sherrill | 1996-05-23 | 34 | -5/+160 |
* | updates from Tony Bennett | Joel Sherrill | 1996-05-23 | 12 | -102/+139 |
* | added code to insure that delay is always non-zero | Joel Sherrill | 1996-05-23 | 2 | -0/+4 |
* | updates from tony bennett | Joel Sherrill | 1996-05-23 | 1 | -2/+2 |
* | added as example of how to do a bsp which is not in this tree. | Joel Sherrill | 1996-05-23 | 2 | -0/+19 |
* | *** empty log message *** | Joel Sherrill | 1996-05-23 | 1 | -2/+2 |
* | invoke thread stack free routine instead of Workspace free. | Joel Sherrill | 1996-05-23 | 1 | -2/+26 |
* | updates from Tony Bennett. | Joel Sherrill | 1996-05-23 | 2 | -60/+78 |
| | | | | | Broke the setjmp/longjmp pair in the context switch into a separate routine so no code depended on local variables surviving the jump. |
