* | Regenerate. | Ralf Corsepius | 2006-01-12 | 66 | -0/+234 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 64 | -128/+0 |
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 |
| | | | | * wrapup/Makefile.am: Add preinstall.am. | ||||
* | Add preinstall.am | Ralf Corsepius | 2006-01-12 | 1 | -15/+1 |
* | New. | Ralf Corsepius | 2006-01-12 | 1 | -0/+26 |
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 4 | -37/+31 |
| | | | | | | * libchip/Makefile.am: Build libchip/network/smc91111. * libchip/network/smc91111.c, libchip/network/smc91111config.h: Eliminate cyg_int* crap. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -3/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 58 | -116/+99 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 3 | -9/+1 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 56 | -109/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 2 | -2/+2 |
* | Remove unnecessary CLEANFILES. | Ralf Corsepius | 2006-01-12 | 5 | -12/+3 |
* | * vmeUniverse/vmeTsi148.c, vmeUniverse/vmeTsi148.h, | Till Straumann | 2006-01-12 | 5 | -20/+81 |
| | | | | | | | | | vmeUniverse/vmeUniverse.c, vmeUniverse/vmeUniverse.h, vmeUniverse/vme_amd_defs.h: No longer enable posted-writes on master windows (creates race-condition on memory-mapped devices). A new flag allows for signalling that a window maps 'ordinary memory'. Disable VME IRQ level if no handler is registered with interrupting vector. | ||||
* | * vmeUniverse/vmeTsi148.c, vmeUniverse/vmeTsi148.h: | Till Straumann | 2006-01-12 | 3 | -8/+17 |
| | | | | Eliminate obsolete types. | ||||
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 2 | -69/+3 |
| | | | | * librdbg/Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2006-01-11 | 1 | -0/+72 |
* | New. | Ralf Corsepius | 2006-01-11 | 4 | -0/+216 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 18 | -538/+73 |
| | | | | * Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2006-01-11 | 5 | -0/+310 |
* | Remove leftovers of consolex. | Ralf Corsepius | 2006-01-11 | 1 | -2/+0 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 10 | -283/+30 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 27 | -683/+82 |
* | New. | Ralf Corsepius | 2006-01-11 | 22 | -0/+1306 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 20 | -545/+72 |
* | New. | Ralf Corsepius | 2006-01-11 | 6 | -0/+364 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 34 | -68/+85 |
| | | | | | * configure.ac: Remove explicit ampolish3 support (now in RTEMS_BSP_CONFIGURE). | ||||
* | Cosmetics. | Ralf Corsepius | 2006-01-11 | 3 | -4/+1 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 2 | -4/+16 |
| | | | | | * aclocal/bsp-configure.m4: Add ampolish3. New header guards. | ||||
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@freenet.de> | Ralf Corsepius | 2006-01-11 | 2 | -7/+4 |
| | | | | * bspstart.am: Remove. | ||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 33 | -900/+139 |
| | | | | | * configure.ac: Add ampolish3 support. * Makefile.am: Add preinstall.am. | ||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 9 | -246/+33 |
* | New. | Ralf Corsepius | 2006-01-10 | 14 | -0/+1240 |
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 9 | -151/+33 |
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 2 | -0/+5 |
| | | | | * shared/start.S: Add include of bspopts.h so SIS quirks will trigger. | ||||
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 2 | -9/+14 |
| | | | | | * startup/linkcmds: Merge from 4.6 branch. Now the copy_data loop works. | ||||
* | New. | Ralf Corsepius | 2006-01-10 | 3 | -0/+178 |
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 2 | -0/+11 |
| | | | | * configure.ac: Add configuration for ENABLE_SIS_QUIRKS. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-10 | 1 | -5/+6 |
* | 2006-01-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-09 | 3 | -1/+14 |
| | | | | | | PR 858/bsps * Makefile.am: Added vme_am_defs.h; * vme/vmeconfig.c: Added appropriate include files. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-09 | 1 | -5/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-09 | 1 | -34/+39 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 2 | -6/+5 |
| | | | | * Makefile.am: Don't include subdirs.am. Cleanup. | ||||
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 16 | -8/+32 |
| | | | | * Makefile.am: Don't include subdirs.am. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-09 | 1 | -0/+8 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 3 | -17/+18 |
| | | | | | * libchip/network/open_eth.c, libchip/network/open_eth.h: Merger from rtems-4-6-branch. | ||||
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 6 | -4/+2305 |
| | | | | | | | | * libchip/network/smc91111.c libchip/network/smc91111config.h libchip/network/smc91111exp.h libchip/network/smc91111.h: New. Merger from rtems-4-6-branch. * libchip/Makefile.am: Reflect adding smc91111*. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-09 | 1 | -2/+0 |
