In another attempt to get C++ exceptions working on the gen68360 target
I tried building for the m68k-elf target. All the tools built and
installed properly as did all of RTEMS. No applications would run,
though -- not even hello.exe!
It turns out the problem was in the linker script. The alignment was in
the wrong place.
Here's a patch. Exceptions still don't work, but at least I can get
some things working with the ELF format now.
errors.
to added the bin2boot_SOURCES warning.
and reported by Ralf Corsepius <corsepiu@faw.uni-ulm.de> on the mpc505.
<valette@crf.canon.fr> and Jay Kulpinski <jskulpin@eng01.gdds.com>.
+ Added checks for valid attribute maxmsg and msgsize
+ Added check for ENAMETOOLONG
old_exception_processing tree.
which fixes a couple of bugs in RTEMS's old style Makefile.ins, which
apparently were introduced by moving the start directories and not
having adapted the Makefile.ins.
patch -p1 < rtems-rc-19991203-10.diff
which ontains all what was left over from the other patches (Primarily
minor configuration cleanups).
patch -p1 < rtems-rc-19991203-9.diff
./bootstrap
which does minor cleanup for Makefile.ams below mptests, which only
removes some bogus comments from the Makefile.ams.
patch -p1 < rtems-rc-19991203-8.diff
./bootstrap
esp. some powerpc cpu-models
them to $(PROJECT_INCLUDE)/
./bootstrap
./bootstrap
which fixes a nasty dependency bug in optman/Makefile.am. Those
directories have been build twice before, i.e. re-running make after
having built rtems before, was rebuilding the files in optman/
directories.
patch -p1 < rtems-rc-19991203-6.diff
./bootstrap
John Mills <jmills@tga.com>.
too small when OPERATION_COUNT is less than 10.
