Gauthier <charles.gauthier@nrc.ca>. The power supply in their
VMEbus cage died so it was submitted at this point. It passes ttcp
which is a really good sign but they would like to do more testing
and cleanup once their hardware is functional again. Please
contact them if you are interested in using or fixing this driver.
As their comments indicate, the performance is actually quite good
even at this point as indicated by the ttcp results.
Please note that this is by no means a final version. The code is still
fairly ugly, and will require some further fixing. On the bright side, what
is attached works. I finally ran the test programs successfully with
optimized code and data cache enabled:
netdemos worked, but failed on the UDP transfer (runs out of buffers).
ttcp worked, with something like 1036 KB/sec Rx, 952 KB/sec Tx.
tftp worked
rtems-rc-4.5.0-7.diff. This file is being added to the main branch
in hopes that it will be easier to deal with the full merge later.
compiled and there is no comparable code for the C4x.
linkcmds updated, simio references removed, and switch to libchip for
serial ports from simio.
Added a MEMORY_MAP file to capture information about the various
addresses on this board.
In addition, many of the beta patches are now included.
Java folks including Oscar Martinez de la Torre <omt@wm.estec.esa.nl>.
Bob Wisdon <bobwis@ascweb.co.uk> and Chris Johns <ccj@acm.org>
to resolve a random network lockup problem.
ckinit.c:
Occasional network lockups have been noted when the PIT has a higher
interrupt request level than the CPM. The SCC1 bit in the CISR is set
even though the SCC1 interrupt handler is not active. This blocks
interrupts from SCC1 (and all other CPM sources) and locks up the
system. It has not been determined whether the error is within the
68360 or in the RTEMS interrupt support assembler code. The solution,
for now, is to set both PIT and CPM interrupt request levels to the same
value (4).
network.c:
Set CPM transmitter buffer pointer (_tbptr) to beginning of frame
before restarting transmitter. Don't retire transmitter buffer
descriptors belonging to the restarted frame.
that contains:
* Removes MKLIB
handling)
when setting up receive buffer descriptors and when unmasking interrupts.
<andrew@pogo.wv.tek.com>.
Eric Norum <eric@cls.usask.ca>.
./bootstrap
that contains:
The workarounds related to the issues with
ppc/helas403 (triggers a nasty bug in automake-2.14) and mcp750.cfg
(Which is basically broken)
patch -p1 < rtems-rc-20000118-6.diff
./bootstrap
Note:
* Though this patch is small, ./bootstrap is absolutely necessary.
* Now your CVS source tree is identical to my local CVS.
that contains:
* The fix for the gen68360/network/Makefile.am
* automatically set permissions to 755 to scripts/buildall and
scripts-ada/buildall (I remembered a trick to achieve this :).
* automake support for libbsp/* and libcpu/* (Attn: This part will
finally break old-style configuration for all non-public cpus)
NOTES:
* This patch has only been tested for a random selection of BSPs (I
haven't rebuilt all toolchains yet).
* This patch is against rtem-cvs as of this morning (MET).
patch -p1 <rtems-rc-20000118-5.diff
cvs rm -f ./c/src/lib/libbsp/Makefile.in
cvs rm -f ./c/src/lib/libbsp/shmdr/Makefile.in
cvs rm -f ./c/src/lib/libcpu/Makefile.in
cvs add ./c/src/lib/libbsp/Makefile.am
cvs add ./c/src/lib/libbsp/shmdr/Makefile.am
cvs add ./c/src/lib/libcpu/Makefile.am
./bootstrap
converted to automake.
that should not have been.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
to make the BSP boot on netboot.
BSP alias on the tools.
information on hardware settings.
pc686.cfg was not present.
that converts the a29k to automake.
This patch contains
* An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS,
most code inside them seems to be empty stubs. One file even contains a
function called mips_*** which might indicate that this part might
contain mips code or the code the initial porter used as template for
porting. Unfortunately, I don't know anything about the a29k so I can't
comment on the details.
* A dummy bsp_specs to libbsp/29k/portsw
* An update to the automake files related to the a29k.
Note:
* This patch is completely untested, because I don't have a toolchain
for it.
* The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue
hits again.
Janovetz <janovetz@tempest.ece.uiuc.edu> to return a status from
network initialization rather than panic'ing. It changes a bunch
of rtems_panics to printfs and returns a status from
rtems_bsdnet_initialize_network().
I'd like to propose a change to RTEMS task variables that I think would
make them more useful. I think that it is early enough in their
existence to still make changes to their API.
1) Change type from `int' to `void *'.
2) Add extra argument to task_variable_add -- if non-NULL, a pointer to
a `destructor' function to be called when the task exits. This function
would be called with that task's value of the task variable as its
argument. In many cases, the `dtor' function could be `free'.
rtems_status_code rtems_task_variable_add (
rtems_id tid, void **ptr, void (*dtor)(void *));
rtems_status_code rtems_task_variable_delete (rtems_id tid, void **ptr);
This would be all we'd need to cleanly and efficiently support C++
per-thread exception information without dragging in all that POSIX API
stuff.
Some excellent sleuthing by Bob Wisdom <bobwis@ascweb.co.uk> revealed
that an empty mbuf at the end of a packet chain would cause the `retire'
function to blow up. Moving the line of code which bumps the transmit
buffer descriptor pointer fixes the problem. Some additional cleanup of
the sendpacket function was also completed.
is not strict ANSI.
