2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* irq/irq.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 4 | -1/+11 | |
* network/network.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -2/+12 | |
* pppd/auth.c, rtems_webserver/uemf.h: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 5 | -12/+26 | |
* mpc8260/console-generic/console-generic.c, mpc8260/cpm/dpram.c, mpc8260/exceptions/raw_exception.c, mpc8xx/exceptions/raw_exception.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+7 | |
* console/i8042.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 7 | -7/+24 | |
* console/console.c, irq/irq.c, network/if_hdlcsubr.c, network/if_hdlcsubr.h, network/network.c, vectors/vectors_init.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 6 | -27/+39 | |
* console/console.c, network/network.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+4 | |
* clock/clock.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+5 | |
* console/console.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -24/+32 | |
* console/sci.c, spurious/spinit.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 6 | -23/+8 | |
* console/console.c, i2c/i2cdrv.c, nvram/nvram.c, startup/bspstart.c, tod/ds1307.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -3/+11 | |
* console/console.c, console/m340uart.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -1/+6 | |
* console/console.c, network/ne2000.c: Removed warnings. | |||||
2002-11-03 | 2002-11-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+6 | |
* mongoosev/Makefile.am: TMPINSTALL_FILES -> PREINSTALL_FILES. | |||||
2002-11-02 | 2002-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 4 | -23/+22 | |
* mongoosev/Makefile.am: Merge-in mongoosev/include/Makefile.am. Install include/mongoose-v.h. * mongoosev/include/Makefile.am: Remove. * configure.ac: Reflect changes above. | |||||
2002-11-02 | 2002-11-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -2/+7 | |
* console/console.c, start/start.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -31/+31 | |
* console/console.c, start/start.c, startup/efi68k_wd.c: | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -38/+42 | |
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -4/+8 | |
* startup/m68k-stub.c: Removed typos. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -38/+42 | |
* sh7045/score/ispsh7045.c: Fixed typos. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 4 | -7/+13 | |
* irq/irq.c, irq/irq_asm.S, startup/bspstart.c: Fixed typos and removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* sh7045/score/cpu_asm.c: Fixed typo. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -12/+16 | |
* delay/delay.c, score/ispsh7032.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -109/+113 | |
* score/cpu_asm.c, score/ispsh7750.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -99/+103 | |
* score/cpu_asm.c, score/ispsh7045.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 5 | -0/+16 | |
* mpc8xx/console-generic/console-generic.c, mpc8xx/cpm/dpram.c, mpc8xx/exceptions/raw_exception.c, ppc403/clock/clock.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -0/+7 | |
* shared/interrupts/installisrentries.c, shared/interrupts/vectorexceptions.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+5 | |
* gnatcommon.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -1/+11 | |
* gnatsupp/gnatsupp.c, startup/spurious.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -5/+8 | |
* clock/ckinit.c, console/console.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+8 | |
* gdbsci/gdbsci.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -3/+5 | |
* start/start.S, startup/hw_init.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 4 | -0/+28 | |
* cpu.c: Currently only the mpc8260 BSP supports interrupt nesting. NOTE: These needs to be generalized as the patch is applied to other BSPs. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 4 | -12/+19 | |
* clock/p_clock.c, console/console.c, startup/bspstart.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 6 | -12/+20 | |
* canbus/canbus.c, clock/p_clock.c, console/console.c, network/network.c, startup/bspstart.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -2/+6 | |
* startup/genpvec.c, tod/todcfg.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -5/+10 | |
* mips-stub.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -2/+8 | |
* startup/bspclean.c, startup/bspstart.c: Removed warnings. | |||||
* startup/gdb-support.c, startup/linkcmds: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -3/+6 | |
* console/conscfg.c, startup/bspstart.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -199/+203 | |
* startup/m68k-stub.c: Removed warnings. | |||||
* network/network.c, startup/bspclean.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -10/+15 | |
* startup/page_table.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 4 | -2/+15 | |
* startup/bspstart.c: Removed warnings. | |||||
* stackchk/check.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -5/+9 | |
* m68k-stub.c: Corrected typos. | |||||
2002-11-01 | 2002-11-01 Andy Dachs <a.dachs@sstl.co.uk> | Joel Sherrill | 4 | -377/+484 | |
* irq/irq.c, irq/irq_asm.S, irq/irq_init.c: Per PR288, add support for _ISR_Nest_level. | |||||
2002-10-31 | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+7 | |
* comm/i386-stub.c: Fixed places where debug_error() was not called with enough arguments. | |||||
2002-10-31 | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -3/+8 | |
* comm/i386-stub.c: Removed warnings. |
