* startup/linkcmds: Stack was overlapping work area.
* Makefile.am, console/console.c, startup/linkcmds: Now links but
clearly the starting stack overlaps regular memory and needs to be
moved.
* startup/linkcmds: Start of RTEMS Work Area must be on 16 byte
boundary on the SPARC.
correct some init values for HSC_CM01 boards
PR 1392/bsps
* libchip/i2c/spi-memdrv.c: SPI Memory driver. Fix but where writes
over multiple pages results in extra data being written.
PR 1385/cpukit
* mpc5xx/irq/irq_asm.S: When the type rtems_boolean was switched to the
C99 bool, the size changed from 4 bytes to 1 byte. The interrupt
dispatching code accesses two boolean variables for scheduling
purposes and the assembly implementations of this code did not get
updated.
PR 1385/cpukit
* shared/irq/irq_asm.S: When the type rtems_boolean was switched to the
updated.
PR 1385/cpukit
updated.
PR 1385/cpukit
* irq/irq_asm.S: When the type rtems_boolean was switched to the C99
updated.
PR 1385/cpukit
* startup/exception.S: When the type rtems_boolean was switched to the
updated.
* bootcard.c: Swap order of RTEMS Workspace and Malloc Heap. This
allows the potential for sbrk() to extend the heap area. This
actually is done on PowerPC BSPs with more than 32MB which use
dynamic loading.
* include/bsp.h: Added missing include.
PR 1391/bsps
* startup/spurious.c: Format was %d but had leading 0x.
to have been mangled. I believe that the this version fixes things.
* include/bsp.h, start/start.S, startup/bspstart.c:
removed BSP_INIT_STACK_SIZE -- this BSP now also uses
__stack defined by the linker script for the initial
stack.
Removed legacy code (inherited from old mvme2307 BSP
but not relevant to this one) that tested trapping
into PPCBug.
* startup/misc.c, flash/flashcfg.c, irq/irq_init.c,
pci/detect_host_bridge.c: changed function arguments
to silence compiler warnings.
* bootcard.c: use aligned heap_start (instead of
original heap_start) when calculating default heap
size (to take into account loss due to alignment).
* vmeUniverse/vmeTsi148.h, vmeUniverse/vmeTsi148.c:
fixed function declarations to silence compiler
warnings.
robust against erroneous external exception disable times.
* Makefile.am, console/console.c: Use shared polled console framework.
* Makefile.am, preinstall.am, include/bsp.h, startup/setvec.c: Now
compiles again but applications do not link.
PR 1375/bsps
* clock/clock.c: Correct implementation of nanoseconds since last tick
handler.
PR 1390/bsps
* startup/linkcmds: Fix sections so C++ global constructors and
destructors work with late model (>= 4.3) gcc versions.
* shared/irq/irq_asm.S: Newer compilers handle alignment better.
PR 1380/bsps
* include/bsp.h: Switch to English comments.
* Makefile.am: Remove unnecessary copy of cpu_asm.S
* console/Modif_cpu_asm.S: Removed.
PR 1386/bsps
* shared/start.S: Stack space not correctly initialized. Causes
failures on unoptimized applications.
* bspgetworkarea.c: Add check to determine if current stack pointer is
in work area.
* shared/startup/bspgetworkarea.c: Add check to determine if current
stack pointer is in work area.
* Makefile.am, configure.ac, preinstall.am: Added BSP variants.
* console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed
register settings. Cleanup.
* include/bsp.h: Added network defines and functions.
* include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status
sizes.
* include/system-clocks.h, misc/system-clocks.c: Added micro seconds
delay function that uses Timer 1. Changed PLL setup.
* network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New
files.
* startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
constructors and destructors.
* libchip/i2c/spi-sd-card.c: Added support for high capacity and MMC
cards.
* startup/cpu.c: Now compiles. Does not run.
* shared/clock/ckinit.c, shared/start/start.S, shared/timer/timer.c:
Run better on simulator. Timer is probably not right yet but
* configure.ac, include/bsp.h: Run better on simulator. Timer is
* shared/startup/bspgetworkarea.c: Make debug messages same as
standard.
* irq/irq.c: Add bsp_interrupt_handler_default() so this BSP will link.
* clock/clock.c, include/bsp.h: Make bsp idle thread names match.
* shared/clock/ckinit.c: Use shared Clock Driver Template and support
fast idle on simulator.
* README: Add fast idle information.
* Makefile.am, configure.ac: Add SIMULATOR_FAST_IDLE,
BSP_PRESS_KEY_FOR_RESET, and BSP_RESET_BOARD_AT_EXIT. Use the standard
bsp_cleanup code.
* README: New file. Include instructions on gdb simulator.
* Makefile.am: Rework.
* include/bsp.h: Conditionally include rtems/rtems_bsdnet.h.
* configure.ac: Add RTEMS_CHECK_NETWORKING.
