path: root/c/src (unfollow)
2002-02-012002-02-01 Eric Valette <valette@crf.canon.fr>Joel Sherrill10-3420/+2644
* So many patches have been posted recently on the mailing list and because we were unable to find correct solution to compile on various linux distros (due to rpcgen incompatibilities), and because the coding style of rdbg was rather inconsistant among various pieces of code, I decided to: 1) make some cleaning regarding global coding style (using indent + manual edits), 2) incorporate/review the paches send by various people (S. Holford, T. Strauman), 3) Fix the bug due to varying rpcgen code generation in remdeb_svc.c, 4) Remove some dead code, 5) Apply a patches enabling to call enterRdbg imediately after rdbg initialization is done, NB : the paches is huge but it is mainly due to coding styke chnages. Only few lines of codes have been really changed and they do not impact rdbg functionnality (AFAIKT). * include/rdbg/servrpc.h, include/rdbg/i386/rdbg_f.h, include/rdbg/m68k/rdbg_f.h, include/rdbg/powerpc/rdbg_f.h, src/_servtgt.c, src/awk.svc, src/excep.c, src/ptrace.c, src/rdbg.c, src/remdeb.x, src/servbkpt.c, src/servcon.c, src/servrpc.c, src/servtgt.c, src/servtsp.c, src/servutil.c, src/i386/excep_f.c, src/i386/rdbg_f.c, src/i386/any/Makefile.am, src/i386/any/remdeb.h, src/i386/any/remdeb_svc.c, src/i386/any/remdeb_xdr.c, src/m68k/excep_f.c, src/m68k/rdbg_f.c, src/m68k/any/Makefile.am, src/m68k/any/remdeb.h, src/m68k/any/remdeb_svc.c, src/m68k/any/remdeb_xdr.c, src/powerpc/excep_f.c, src/powerpc/rdbg_f.c, src/powerpc/new_exception_processing/Makefile.am, src/powerpc/new_exception_processing/remdeb.h, src/powerpc/new_exception_processing/remdeb_svc.c, src/powerpc/new_exception_processing/remdeb_xdr.c: Modified.
2002-02-01Fixed ChangeLogJoel Sherrill1-0/+1
2002-02-012001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill3-2/+8
* mongoosev/vectorisrs/vectorisrs.c, shared/interrupts/vectorexceptions.c: Use rtems/bspIo.h, not just bspIo.h.
2002-02-012001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2-1/+7
* include/lr33000.h, include/lr330x0.h, include/r3000.h, start/mg5.h: New files missed in previous commit. * timer/timer.c: Use rtems/bspIo.h not just bspIo.h.
2002-02-012001-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill5-294/+274
* rtems.ads, rtems.adb: Formatting cleaned up. Task based timer directives added. This is Timer_Initiate_Server, Timer_Server_Fire_After, and Timer_Server_Fire_When.
2002-02-012001-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
* ChangeLog: New file.
2002-02-01 * So many patches have been posted recently on the mailing list andJoel Sherrill35-5885/+6155
2002-02-012001-02-01 Mike Siers <mikes@poliac.com>Joel Sherrill3-1/+20
* pppd/rtemspppd.c (rtems_pppd_disconnect): Modified to avoid bringing the link down too fast. NOTE: Mike reports successfully running at 56K baud on a direct link.
2002-02-012001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill8-425/+1071
* Update of BSP to address problems restarting, provide more information during boot, and better handle ROM vs RAM images. * README, include/bsp.h, start/regs.S, start/start.S, startup/bspstart.c, startup/linkcmds, timer/timer.c: Updated
2002-02-012001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill5-109/+315
* Lots of tinkering and tuning as part of improving interrupt latency and improving the per-task interrupt level control and FP mask handling. With these modifications interrupt latency was measured at a worst-case of 100us, average below 60 us on a 12 Mhz R3000 class CPU with 50 RTEMS tasks in the application. * mongoosev/README: Updated. * mongoosev/include/mongoose-v.h: Masks modified. * mongoosev/vectorisrs/vectorisrs.c: Significant overhaul to address software prioritization of interrupts. If a higher priority interrupt occurs while we are looking for new interrupts, we will reinitiate the scan of all interrupts. * shared/interrupts/vectorexceptions.c: Removed warning and deleted blank lines.
2002-02-012001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill4-148/+244
* cpu.c: Enhancements and fixes for modifying the SR when changing the interrupt level. * cpu_asm.S: Fixed handling of FP enable bit so it is properly managed on a per-task basis, improved handling of interrupt levels, and made deferred FP contexts work on the MIPS. * rtems/score/cpu.h: Modified to support above changes.
2002-02-012002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-11/+26
* Makefile.am: Reflect 2002-01-23 changes.
2002-02-012001-01-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+26
* include/rtems/rtems/timer.h: Missed merging these modifications in previous merge of new timer functionality.
2002-02-012001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill3-0/+32
* pppd/rtemsdialer.h: New file missed in previous commit.
2002-01-312001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill3-0/+29
* Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * libc/termios.c: Added PPCDISC.
2002-01-312001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill54-1459/+21277
* Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * Makefile.am, configure.ac, net/Makefile.am, net/bpf.h, net/ethernet.h, net/if.c, net/if.h, net/if_arp.h, net/if_dl.h, net/if_ethersubr.c, net/if_llc.h, net/if_loop.c, net/if_ppp.h, net/if_pppvar.h, net/if_types.h, net/netisr.h, net/ppp-comp.h, net/ppp_defs.h, net/pppcompress.h, net/radix.c, net/radix.h, net/raw_cb.c, net/raw_cb.h, net/raw_usrreq.c, net/route.c, net/route.h, net/rtsock.c, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/cbcp.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.8, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/upap.c, pppd/upap.h, pppd/utils.c, pppd/example/README, pppd/example/netconfig.h, wrapup/Makefile.am: Modified. * net/bsd-comp.c, net/if_ppp.c, net/ppp-deflate.c, net/ppp.h, net/ppp_tty.c, net/pppcompress.c, net/zlib.c, net/zlib.h: New file. * modem/, modem/.cvsignore, modem/Makefile.am, modem/ppp.c, modem/ppp.h, modem/ppp_tty.c, modem/pppcompress.c: Subdirectory removed.
2002-01-312002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-26/+31
2002-01-312002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-29/+31
* rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. * Makefile.am: Reflect changes above.
2002-01-302001-01-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-3/+20
* Makefile.am: Corrected so .h files from rtems/score/ are installed.
2002-01-302002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill29-226/+146
2002-01-302002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill25-273/+184
2002-01-302002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+4
* shell/shell.c: Remove #undef __STRICT_ANSI__.
2002-01-302002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-2/+6
* Makefile.am: Adapt to automake-1.5.
2002-01-302002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-7/+11
* include/Makefile.am: Adapt to automake-1.5.
2002-01-302002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill15-161/+103
2002-01-302002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-8/+21
* Makefile.am: Reflect changes from 2002-01-23.
2002-01-292002-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-4/+0
* ChangeLog: Deleted bad entry.
2002-01-292001-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
* src/powerpc/new_exception_processing/remdeb.h: Regenerated.
2002-01-292001-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-6/+88
* Fixed bug where resetting a timer that was not at the head of one of the task timer chains resulted in the Timer Server task waking up too far in the future. * Added rtems_timer_get_information() directive to support testing. * sp31/init.c, sp31/system.h, sp31/task1.c: Modified to test for above condition.
2002-01-292002-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+6
* include/rtems/score/watchdog.h: Added WATCHDOG_MAXIMUM_INTERVAL.
2002-01-292001-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-50/+184
* Fixed bug where resetting a timer that was not at the head of one of the task timer chains resulted in the Timer Server task waking up too far in the future. * Added rtems_timer_get_information() directive to support testing. * src/timerserver.c, include/rtems/rtems/timer.h, * src/timergetinfo.c: New file. * src/Makefile.am: Modified to reflect above.
2002-01-242002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill4-39/+9
* rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. AC_CONFIG_SRCDIR(asm.h).
2002-01-242002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill8-78/+14
2002-01-242002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill7-57/+63
* Makefile.am: Merge in rtems/Makefile.am and rtems/score/Makefile.am. Remove gensize. Require automake-1.5. * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * rtems/score/.cvsignore: Add unixsize.h*. Add stamp-h*. * configure.ac: Add AM_CONFIG_HEADER(rtems/score/unixsize.h). * rtems/score/cpu.h: Replace CPU_CONTEXT_SIZE_IN_BYTES with SIZEOF_CPU_CONTEXT.
2002-01-222001-01-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill5-1/+19
* sp09/screen14.c, sp09/sp09.scn, sp30/init.c, sp31/init.c: Modified because priority added as argument to rtems_timer_initiate_server().
2002-01-222001-01-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-19/+41
* include/rtems/rtems/timer.h, src/timerserver.c: Add priority argument to rtems_timer_initiate_server().
2002-01-222002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill10-1159/+60
* rtems/Makefile.am: New. * rtems/.cvsignore: New. * rtems/score/Makefile.am: New. * rtems/score/.cvsignore: New. * rtems/score/ppc.h: Relocated from shared/. * rtems/score/ppctypes.h: Relocated from shared/. * asm.h: Relocated from shared/. * shared/Makefile.am: Removed. * shared/asm.h: Removed. * shared/ppc.h: Removed. * shared/ppctypes.h: Removed. * shared/.cvsignore: Removed. * Makefile.am: Reflect changes above. * configure.ac: Reflect changes above.
2002-01-222002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-6/+17
* rtems_telnetd/pty.c: Move config.h to were it belongs. Remove printf (Reported by Till Straumann <strauman@SLAC.Stanford.EDU>).
2002-01-222002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* compilers/gcc-target-default.cfg: Add missing \. Reported by Ilya Alexeev <ilya@continuum.ru>.
2002-01-202002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+6
* include/rtems/system.h: Fix typo in yesterday's change: RTEMS_MULTILIBS.
2002-01-182001-01-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-13/+18
* include/rtems/system.h: Only include cpuopts.h when building a multilib configuration. Some ports still need targopts.h but this small modification lets those ports work non-multilib while fixing being fixed for multilib.
2002-01-182001-01-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+9
2002-01-182002-01-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2-1/+29
* src/powerpc/excep_f.c: This patch addresses the following issues: - exception handler needs to enable MSR_FP if the interrupted thread is FP enabled. - printk message for MSR fixed and added stacktrace NOTE: this requires the stacktrace patch to lib/libbsp/powerpc/shared/vectors/vector_init.c (#ifdef DDEBUG only, however)
2002-01-182001-01-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-17/+22
* src/powerpc/new_exception_processing/remdeb_svc.c: Corrected macro using variable arguments.
2002-01-182001-01-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-93/+100
* src/powerpc/new_exception_processing/remdeb.h, src/powerpc/new_exception_processing/remdeb_xdr.c: Regenerated since I updated the main RTEMS development machine to RedHat 7.2 and apparently got a new version of rpcgen.
2002-01-182001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+4
* ChangeLog: Deleted duplicate blank line.
2002-01-162002-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill5-152/+26
* include/rtems/libio.h: Add #include <rtems/fs.h>. Reflect changes due to using rtems/fs.h. * include/rtems/libio_.h: Reworked.
2002-01-162001-01-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-0/+454
* Added task-based timers to the Timer Manager. This added three new directives: - rtems_timer_initiate_server - rtems_timer_server_fire_after - rtems_timer_server_fire_when In the process of doing this, a number of cleanups were made. * src/timerserver.c, src/timerserverfireafter.c, src/timerserverfirewhen.c: New files. * include/timer/timer.h: Added new prototypes and supporting types. * inline/rtems/rtems/timer.h, macros/rtems/rtems/timer.h: Enhanced _Timer_Is_interval_class() to cover the class TIMER_INTERVAL_ON_TASK. * src/Makefile.am: Accounted for new files. * src/rtemstimer.c: Added initialization of _Timer_Server variable. * src/timercancel.c, src/timerreset.c: Account for addition of timer classes. Also corrected the headers. * src/timercreate.c, src/timerdelete.c, src/timerfireafter.c, src/timerfireafter.c, src/timerident.c: Corrected header.
2002-01-162002-01-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill4-16/+25
* Makefile.am: Apply @subdirs. Remove POSIX_SUBDIRS. Remove ITRON_SUBDIRS. * configure.ac: Rework enable_unixlib handling. Add RTEMS_MULTILIBS to cpuopts.h. * include/Makefile.am: Add rtems/fs.h, rtems/userenv.h. Add $(PROJECT_INCLUDE)/rtems. Remove libio_.h.
