* Only GRETH device supported for now
* Fix endian problem in GRETH driver
* Remove SPARC assembly from greth.c
* Builds with both autoconf and waf
This breaks AArch32-specific portions of the ARM GPT driver into their
own file so that the generic code can be moved for reuse by other
architectures.
This UART driver is now needed for BSPs other than ARM.
Update 3869
Update #3941.
Due to an unmaintained toolchain (internal errors in GCC, no FSF GDB
integration) the Epiphany architecture was obsoleted in RTEMS 5.1.
Update #3941.
Update #3951.
The PowerPC SPE support was removed from GCC.
Update #3951.
Update #4020.
start16.S is now only used for SMP configurations to start the
application processors.
This commit removes all unnecessary parts for this job,
i.e. video conssole initalisation, A20 gate activation
and all non-AP related code.
Update #3335
Some imx chips or boards don't use the same frequency for ECSPI and IPG.
Update #3869
Closes #3611.
This avoids to pull in via printk() the Termios support which pulls in
the file system support. This fixes a spconfig02 test failure.
Replace the BSP_DIRTY_MEMORY BSP option with a CONFIGURE_DIRTY_MEMORY
configuration option.
Update #3843.
Replaces the legacy termios API with new termios API (#3034)
Replaces the custom PL011 serial driver with RTEMS arm-pl011.
Update #3034
This commit adds FDT support to the BSP.
The BSP tried to get the size of the SDRAM based on the revision code.
Unfortunately the code had some bugs so that the default size has been
used. Beneath that the MMU table hasn't been adapted.
This patch queries the SDRAM size via a special VC Mailbox call instead.
For the MMU adaption a simmilar method to the one in the imx BSP is
used.
Update #3818.
Create the Xen BSP for Xen on ARM.
This BSP family uses only one linker command file. Use the standard
name.
Update #3818.
name.
Update #3818.
Update #3818.
Use the test state configuration instead.
Update #3818.
Update #3818.
name.
Update #3818.
name.
Update #3818.
Update #3785.
It is fine to build the drivers always.
Update #3818.
The small page MMU support reduces the granularity for memory settings
through the MMU from 1MiB sections to 4KiB small pages.
Enable it by default on the realview_pbx_a9_qemu BSP.
Bug was introduced by commit 1e1afa3779e594e09387fba1812d3028fb00cd9e.
LLVM/LLD does not support STARTUP and ALIGN_WITH_INPUT directives that
GNU LD support. INPUT and ALIGN(8) are supported by LLVM/LLD and can
replace the unsupported STARTUP/ALIGN_WITH_INPUT directives.
The commit conditionally adds the supported directive that linkers
can understand depending on the toolchain used to compile RTEMS
i.e., clang or gcc. Clang is assumed to use LLD by default.
This commit moves the existing linkcmds.base to linkcmds.base.in
in order to make it configurable by autotools.
Use NULL-pointer protection also for Qemu variant.
Do all calculations in the linker command file. This is a preparation
for the new build system.
Added support for Sifive Freedom FE310 soc on Arty A7 FPGA board.
Update #3785.
Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com>
Add support for _SMP_Send_message() to the own processor. This is
required by the smpmulticast01 test program.
- Update the linkcmd file to support configure settings
- Set the workspace size based on the revision value
- Port the jbang code from C++ to C to enable DBGEN.
- Hook the libdebugger ARM backend support to return the base address
of the debug register set.
This fixes the corruption of r3 by the call to
bsp_start_arm_drop_hyp_mode().
Moving the code makes it easier to review changes in start.S.
Close #3773.
This makes it easier to review changes in start.S.
Update #3773.
- Allow the RTEMS_ROOT to be conditionally supplied. This
can be a staging area before being moved to the final
install prefix location.
- Update the default.cfg to use RTEMS_ROOT and to not rely on
the exec_prefix so it's paths can be staged.
- Fix and add the needed configure subs.
Closes #3768
controller support.
Update #3269.
Update #3725.
