* bsplibc.c, bsppost.c: Merge GSOC project code to add simple device
only filesystem (devfs), optionally completely drop out filesystem,
and to clean up disabling newlib reentrancy support. This dropped 17K
from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K
code space.
* startup/bspstart.c: Merge GSOC project code to add simple device only
filesystem (devfs), optionally completely drop out filesystem, and to
clean up disabling newlib reentrancy support. This dropped 17K from
the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K code
space.
* bspgetworkarea.c: New file. This implementation should be useable
by most BSPs if they provide the proper support in their linker script.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* shared/m68kbspgetworkarea.c: Removed.
* Makefile.am, startup/bspstart.c, startup/linkcmds: Use top level
shared bsp_get_work_area() implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds_ROM: Use top level
* Makefile.am, startup/linkcmds, startup/linkcmdsflash: Use top level
* Makefile.am, startup/linkcmds, startup/linkcmdsflash,
startup/linkcmdsram: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am, start/start.S, startup/linkcmds: Use top level shared
* Makefile.am, startup/linkcmds, startup/linkcmds.flash: Use top level
* Makefile.am, startup/bspstart.c, startup/init548x.c,
startup/linkcmds, startup/linkcmds.m5484FireEngine.flash: Use top
level shared bsp_get_work_area() implementation.
* Makefile.am, include/bsp.h, startup/init68360.c, startup/linkcmds,
startup/linkcmds.bootp, startup/linkcmds.prom: Use top level shared
* startup/bspgetworkarea.c, startup/linkcmds.base: Do some prep work in
anticipation of gen5200 and gen83xx being able to shared
* Makefile.am, include/bsp.h, startup/linkcmds: Use top level shared
* shared/bspgetworkarea.c: Removed.
* Makefile.am, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds.sim: Use top level
* Makefile.am, startup/linkcmds, startup/linkcmds.rom,
startup/linkcmds.rom2ram: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds.ram,
startup/linkcmds.rom: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am: Use top level shared bsp_get_work_area() implementation.
* shared/include/nvram.h: Fix typo.
* clockdrv_shell.c: Remove unnecessary includes of rtems/libcsupport.h
and rtems/libio.h.
* bspstart.c: New file.
* clock/clock.c: Remove unnecessary includes of rtems/libcsupport.h and
rtems/libio.h.
* clock/ckinit.c: Remove unnecessary includes of rtems/libcsupport.h
and rtems/libio.h.
* startup/bspstart.c: Removed.
* shared/bspstart.c: Remove unnecessary includes of rtems/libcsupport.h
and rtems/libio.h.
* clock/ckinit.c: Add use of bsp_get_work_area() in its own file and
rely on BSP Framework to perform more initialization. Remove
unnecessary includes of rtems/libio.h and rtems/libcsupport.h. All
SuperH BSPs now share a common bsp_start() implementation.
* shared/clock/clock.c: Remove unnecessary includes of
rtems/libcsupport.h and rtems/libio.h.
* irq/FPGA.c: Remove unnecessary includes of rtems/libcsupport.h and
rtems/libio.h.
* Makefile.am, startup/bspstart.c: Add use of bsp_get_work_area() in
its own file and rely on BSP Framework to perform more
initialization. Remove unnecessary includes of rtems/libio.h and
* startup/bspgetworkarea.c: New file.
* startup/bspstart.c: Remove unnecessary includes of
* clock/clock.c, startup/bspstart.c: Remove unnecessary includes of
* Makefile.am, startup/bspstart.c: Split out bsp_get_work_area() into
its own file and use BSP Framework to perform more initialization.
* clock/ckinit.c, startup/bspstart.c: Remove unnecessary includes of
* shared/m68kbspgetworkarea.c: Add use of bsp_get_work_area() in its
own file and rely on BSP Framework to perform more initialization.
Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h.
* shared/m68kpretaskinghook.c: Removed.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds: Add
use of bsp_get_work_area() in its own file and rely on BSP Framework
to perform more initialization. Remove unnecessary includes of
* Makefile.am, configure.ac, startup/linkcmds: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
* console/debugio.c, startup/bsppredriverhook.c: New files.
* Makefile.am, configure.ac, clock/ckinit.c, startup/linkcmds: Add use
of bsp_get_work_area() in its own file and rely on BSP Framework to
* Makefile.am, configure.ac, clock/ckinit.c, startup/bspstart.c: Add
