* wrapup/Makefile.am: Added libfs.
* libfs created.
* src, src/imfs, wrapup: New directories.
* ChangeLog, Makefile.am, README, configure.in, src/Makefile.am,
wrapup/Makefile.am: New files.
* src/imfs/deviceio.c, src/imfs/imfs_getchild.c,
src/imfs/imfs_readlink.c, src/imfs/imfs.h, src/imfs/imfs_gtkn.c,
src/imfs/imfs_rmnod.c, src/imfs/imfs_chown.c,
src/imfs/imfs_handlers_device.c, src/imfs/imfs_stat.c,
src/imfs/imfs_creat.c, src/imfs/imfs_handlers_directory.c,
src/imfs/imfs_symlink.c, src/imfs/imfs_debug.c,
src/imfs/imfs_handlers_link.c, src/imfs/imfs_unixstub.c,
src/imfs/imfs_directory.c, src/imfs/imfs_handlers_memfile.c,
src/imfs/imfs_unlink.c, src/imfs/imfs_eval.c, src/imfs/imfs_init.c,
src/imfs/imfs_unmount.c, src/imfs/imfs_fchmod.c,
src/imfs/imfs_initsupp.c, src/imfs/imfs_utime.c, src/imfs/imfs_fcntl.c,
src/imfs/imfs_link.c, src/imfs/memfile.c, src/imfs/imfs_fdatasync.c,
src/imfs/imfs_mknod.c, src/imfs/miniimfs_init.c, src/imfs/imfs_free.c,
src/imfs/imfs_mount.c, src/imfs/imfs_fsunmount.c, src/imfs/imfs_ntype.c:
New files. Moved from libc.
* include/confdefs.h: Set CONFIGURE_INIT_TASK_STACK_SIZE to 0
if there is no Classic API Initialization Tasks Table defined.
* shared/include/cache.h: Improved file header.
* libfs created.
* configure.in: Added libfs subdirectory.
* libfs created.
* libc/deviceio.c, libc/imfs_getchild.c, libc/imfs_readlink.c,
libc/imfs.h, libc/imfs_gtkn.c, libc/imfs_rmnod.c, libc/imfs_chown.c,
libc/imfs_handlers_device.c, libc/imfs_stat.c, libc/imfs_creat.c,
libc/imfs_handlers_directory.c, libc/imfs_symlink.c, libc/imfs_debug.c,
libc/imfs_handlers_link.c, libc/imfs_unixstub.c, libc/imfs_directory.c,
libc/imfs_handlers_memfile.c, libc/imfs_unlink.c, libc/imfs_eval.c,
libc/imfs_init.c, libc/imfs_unmount.c, libc/imfs_fchmod.c,
libc/imfs_initsupp.c, libc/imfs_utime.c, libc/imfs_fcntl.c,
libc/imfs_link.c, libc/memfile.c, libc/imfs_fdatasync.c,
libc/imfs_mknod.c, libc/miniimfs_init.c, libc/imfs_free.c,
libc/imfs_mount.c, libc/imfs_fsunmount.c, libc/imfs_ntype.c:
Moved to libfs/src/imfs.
* Makefile.am: Modified to reflect above.
* pppd/ipxcp.c: Fixed a typo.
* comm/i386-stub-glue.c, comm/tty_drv.c, comm/uart.c, comm/uart.h:
Add the ability to set parity, number of data bits and
number of stop bits to the existing i386 serial drivers.
* console/console.c, console/serial_mouse.c, include/bsp.h:
* console/console.c: Added BSP dependent routine
mbx8xx_console_use_maximum_buffer_size() required by mbx8xx
console-generic code. This avoids libcpu use of bsp.h.
* mpc8xx/console-generic/console-generic.c: Removed include of
<bsp.h> by adding BSP dependent routine
mbx8xx_console_use_maximum_buffer_size() which can be hard coded
or check non-volatile memory for configuration.
* mpc8xx/console-generic/console-generic.c: Removed warnings.
* mpc6xx/clock/c_clock.h: Removed commented out reference to <bsp.h>.
* mpc6xx/timer/timer.c: Ditto.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h: Removed use of
bsp.h and replaced it with use of proper interfaces or explicit
externs of required functions and data.
* libc/Makefile.am: Added mallocfreespace.c.
* libc/mallocfreespace.c: New file based on work by Nick Simon
<Nick.SIMON@syntegra.bt.co.uk> which he included in malloc.c.
* libc/libcsupport.h: Added prototype for malloc_free_space().
* src/regiongetinfo.c, include/rtems/rtems/region.h,
include/rtems/rtems/types.h, src/Makefile.am: Added
region_get_information() and information control block.
* src/regiongetinfo.c: New file.
* src/heapgetinfo.c, include/rtems/score/heap.h, src/Makefile.am:
Added _Heap_Get_information() and information control block.
* src/heapgetinfo.c: New file.
* page.c: Replaced prototype of printk() with include of <bspIo.h>.
* ChangeLog: Corrected comment.
* clock/ckinit.c: Removed commented out include of bsp.h.
* libc/fcntl.c: Do not require every filesystem to have an fcntl()
handler. Most fcntl() operations can be performed with no
filesystem support.
* Makefile.am: Corrected condition CPU model selection so
multilib'ing and bare BSP works.
filesystem support.
* cpu_asm.S, rtems/score/cpu.h: Modified to better support
multilibing. These changes result in the code being able to
compile with the default gcc settings. It is not functional
in this configuration but does compile.
* rtems/score/c4x.h: Modified to properly multilib. This required
using only macros predefined by gcc.
* include/confdefs.h: Modified code that accounts for initialization
task/threads with greater than minimum stack sizes so it would
compile even if optional APIs are disabled.
* irq/Makefile.am, irq/idt.c: Added idt.c since it has been moved
libcpu/i386 to libbsp/i386/shared/irq.
* startup/Makefile.am: Added idt.c since it has been moved libcpu/i386
* idt.c, Makefile.am: Moved idt.c to libbsp/i386/shared so
i386 RTEMS can be multilib'ed.
* include/confdefs.h: Account for initialization tasks and
threads which use larger than minimum stack sizes.
* shared/src/cache_manager.c: Minor bug fix -- changed > to >= so the
last address is invalidated.
* start/start.c: Modified to support generation of ram_init.
* start/ram_init.ld, BSP/start/ram_init.sed: New files.
These changes enable RTEMS to automatically generate
the ram_init file used by gdb with the BDM patches. The 332 has
on-board chip select lines (for RAM and FLASH) that must be
configured before use of these peripherals. These patches parse
data from start.c where the chip select lines are configured in
the runtime executable and automatically generates the gdb
initialization file using the same settings. A great time saver.
A similar file, ram_init_FW (flash writable), is also generated
that the flash programming tool uses.
* start/Makefile.am: Modified to support above.
* CPU/sim.h: Modified to support above.
* startup/except_vect_332_ROM.S: Moved to start so it would not
be included in libbsp.a. Moving it to start ensures it is
available as a single object file.
* start/except_vect_332_ROM.S: Moved from startup.
* startup/linkcmds, startup/linkcmds_ROM: Fixes to the memory map
shown in the comments.
* sim.h: These changes enable RTEMS to automatically generate
* BSP/start/start.c: Must be modified to support above.
* BSP/start/ram_init.ld, BSP/start/ram_init.sed: New files.
* sp20/sp20.scn: Corrected to reflect new addition.
* sp20/system.h: Removed comment reflecting history.
* sp20/getall.c, sp20/init.c, sp20/system.h, sp20/task1.c:
Added new task to test sequence of altering a period's length
while it is still active.
* include/rtems/rtems/ratemon.h, src/ratemonperiod.c,
src/ratemontimeout.c: Add next_length field so period length
can be changed by the the sequence period(X), period(not X)
with no intervening cancel or expiration.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* monitor/mon-driver.c: Accounted for addition of "_entry" to
fields in rtems_driver_address_table.
* include/rtems/io.h (rtems_driver_address_table): Added "_entry"
to all names.
* src/io.c: Accounted for above.
* rtems_webserver/Makefile.am, rtems_webserver/base64.c,
rtems_webserver/base64.c: Renamed base64.c to wbase64.c.
* rtems_webserver/sock.c: Added file missed in merger.
* clock/ckinit.c: Removed include of <bsp.h>. Also switch to
macros to get configuration data.
* timer/timer.c: Removed include of <bsp.h>. Fixed comment
that said 4650 (a mips part).
* shmdr/shm_driver.h: Added _AM29K entry. May not be correct.
* include/bsp.h: tty_* renamed to console_*.
* tty/tty.c: Ditto.
* shmsupp/addrconv.c: Typo fixed.
* wrapup/Makefile.am: Merge startup not start directory.
* ChangeLog: Entry added to wrong file and moved.
* bsp_specs: Formatting more like other bsp_specs.
* include/bsp.h: CPU_CLOCK_RATE_MHZ not a real variable to
elimate need for including bsp.h in libcpu.
* startup/bspstart.c: Ditto.
* wrapup/Makefile.am: Did not list shmdr.
* rtems/system.h: Switched a29k and hppa1.1 to using cpuopts.h not
targopts.h to reduce dependency on BSP.
