for details.
* wrapup/Makefile.am: Many BSPs do not include any .rel files now so do
not fail if there are none.
* wrapup/Makefile.am: Add libflash.a to the libbsp library.
* libchip/Makefile.am, libchip/preinstall.am: Add the flash chip support.
* libchip/flash, libchip/flash/am29lv160.c,
libchip/flash/am29lv160.h: New.
* configure.ac, wrapup/Makefile.am: Remove RDBG.
* aclocal/check-rdbg.m4, aclocal/enable-rdbg.m4, librdbg/.cvsignore,
librdbg/Makefile.am, librdbg/preinstall.am,
librdbg/include/rdbg/rdbg.h, librdbg/include/rdbg/servrpc.h,
librdbg/include/rdbg/i386/rdbg_f.h, librdbg/include/rdbg/i386/reg.h,
librdbg/include/rdbg/m68k/rdbg_f.h, librdbg/include/rdbg/m68k/reg.h,
librdbg/include/rdbg/powerpc/rdbg_f.h,
librdbg/include/rdbg/powerpc/reg.h, librdbg/src/_servtgt.c,
librdbg/src/awk.svc, librdbg/src/excep.c, librdbg/src/ptrace.c,
librdbg/src/rdbg.c, librdbg/src/remdeb.x, librdbg/src/servbkpt.c,
librdbg/src/servcon.c, librdbg/src/servrpc.c, librdbg/src/servtgt.c,
librdbg/src/servtsp.c, librdbg/src/servutil.c,
librdbg/src/i386/excep_f.c, librdbg/src/i386/rdbg_cpu_asm.S,
librdbg/src/i386/rdbg_f.c, librdbg/src/i386/any/remdeb.h,
librdbg/src/i386/any/remdeb_f.x, librdbg/src/i386/any/remdeb_svc.c,
librdbg/src/i386/any/remdeb_xdr.c, librdbg/src/m68k/excep_f.c,
librdbg/src/m68k/rdbg_cpu_asm.S, librdbg/src/m68k/rdbg_f.c,
librdbg/src/m68k/any/remdeb.h, librdbg/src/m68k/any/remdeb_f.x,
librdbg/src/m68k/any/remdeb_svc.c, librdbg/src/m68k/any/remdeb_xdr.c,
librdbg/src/powerpc/excep_f.c, librdbg/src/powerpc/rdbg_cpu_asm.S,
librdbg/src/powerpc/rdbg_f.c,
librdbg/src/powerpc/new_exception_processing/remdeb.h,
librdbg/src/powerpc/new_exception_processing/remdeb_f.x,
librdbg/src/powerpc/new_exception_processing/remdeb_svc.c,
librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c: Removed.
* wrapup/Makefile.am: Create archive from a file for hosts with
a limited command line size.
* wrapup/Makefile.am: Use MKDIR_P instead of mkdir_p.
* libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-2b-eeprom.h,
libchip/i2c/i2c-ds1621.c, libchip/i2c/i2c-ds1621.h: New files.
* libchip/Makefile.am, libchip/preinstall.am, wrapup/Makefile.am:
added a simple API/library
for i2c devices and drivers for i2c 2-byte eeproms and a ds1621
temperature sensor; API is documented in libi2c.h
* configure.ac: Remove HAS_WRAPUP_LIBBSP.
* wrapup/Makefile.am: Remove HAS_WRAPUP_LIBBSP.
* libnetworking/rtems_servers/ftp.c,
libnetworking/rtems_servers/ftp.h,
libnetworking/rtems_servers/Makefile.am:
Remove (relocated to cpukit/ftpd).
* configure.ac, Makefile.am, wrapup/Makefile.am: Reflect having
removed move libnetworking/rtems_servers.
* wrapup/Makefile.am: Remove rtems-ctor.o.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am
support/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
PR 700/rtems_misc
* configure.ac, libnetworking/Makefile.am, wrapup/Makefile.am:
Remove libnetworking/rtems_webserver.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am,
wrapup/Makefile.am: Fix automake problems having been introduced
in previous patch.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am:
Preinstall dirs.
* wrapup/Makefile.am: Preinstall dirs. Cosmetics.
* aclocal/check-multiprocessing.m4: Cosmetics.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT.
* aclocal/project-root.m4: Remove obsolete comments. Remove PACKHEX.
* librdbg/Makefile.am: Merge-in librdbg/include/Makefile.am,
librdbg/src/Makefile.am.
* librdbg/include/Makefile.am, librdbg/src/Makefile.am: Remove.
Unconditionally apply RTEMS_CHECK_MULTIPROCESSING.
* Makefile.am: Add DIST_SUBDIRS = @BSP_SUBDIRS@.
* wrapup/Makefile.am: Reflect new location of librdbg.a.
* wrapup/Makefile.am: Don't include lib.am.
* automake/compile.am: Use automake compilation rules.
* aclocal/check-multiprocessing.m4: Remove AC_SUBST(HAS_MP).
Add AM_CONDITIONAL(HAS_MP).
* wrapup/Makefile.am: Fix path to ../libchip/shmdr.rel.
* configure.ac: Remove AM_CONDITIONAL(HAS_MP).
* aclocal/enable-cxx.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(Deprecated by autoconf 2.59).
* configure.ac: Add AM_CONDITIONAL HAS_WRAPUP_LIBBSP.
* wrapup/Makefile.am: Add AM_CONDITIONAL HAS_WRAPUP_LIBBSP.
* wrapup/Makefile.am: Reflect changes to librdbg.
* aclocal/enable-bare.m4: Convert to autoconf-2.59.
* wrapup/Makefile.am: Reflect changes to libchip/*.
* support/Makefile.am: Use automake compilation rules.
* wrapup/Makefile.am: Reflect changes to support/*.
* configure.ac: Remove libnetworking/wrapup/Makefile.
* wrapup/Makefile.am: Reflect change to libnetworking/*.
Use libnetworking/*/lib*.a instead of libnetapps.a
* wrapup/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* automake/lib.am: Remove TMPINSTALL_FILES.
* wrapup/Makefile.am: Reflect changes to shmdr.
* automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* wrapup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* acinclude.m4: Rework RTEMS_CONFIG_SUBDIR.
* Makefile.am: Reflect changes to RTEMS_CONFIG_SUBDIR.
* aclocal/env-rtemsbsp.m4: Add PROJECT_LIB.
* wrapup/Makefile.am: Use mkdir_p. Remove dirs from
* aclocal/env-rtemsbsp.m4: AC_SUBST(project_libdir).
* automake/lib.am: Remove project_libdir.
* wrapup/Makefile.am: Reworked.
* support/Makefile.am: Remove all-local: $(ARCH).
lib/Makefile.am: Reflect having moved automake.
support/Makefile.am: Reflect having moved automake.
* wrapup/Makefile.am: Use install-data-local to install librtemsbsp.a.
Let all-local: depend on $(LIB).
* wrapup/Makefile.am: Remove libmisc.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* wrapup/.cvsignore: Remove autom4te.cache.
Posix-BSP-Hacks:
* configure.ac: Add AM_CONDITIONAL(LIBCHIP).
Pass RTEMS_HOST to make/bsp.mak
* Makefile.am: Pass RTEMS_HOST to make/bsp.mak.
* wrapup/Makefile.am: Apply AM_CONDITIONAL(LIBCHIP).
