* Makefile.am: Remove subshell from *.a processing in librtemsall.a
rule.
* ChangeLog: New file.
* Makefile.am: Switch to GNU-canonicalized autoconf macros.
* configure.in: New file.
* .cvsignore: Add aclocal.m4, configure.
* wrapup/Makefile.am: Added libfs.
* wrapup/Makefile.am: Include compile.am.
which is an adaptation of a patch from Ian Lance Taylor plus a few
other changes that should significantly speed up building librtemsall.a.
<corsepiu@faw.uni-ulm.de>.
