path: root/c/src/wrapup/Makefile.am (unfollow)
2002-01-042001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-23/+4
* configure.ac: Remove references to POSIX, ITRON, MULTILIB. * Makefile.ac: Remove librtems, libposix, libitron. Build librtemsbsp instead of librtemsall.
2001-12-202001-12-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-5/+21
* configure.ac: Add AM_CONDITIONAL for enable_multilib, enable_posix, enable_itron. * Makefile.am: Compute MULTISUBDIR on-the-fly. Conditionally add libposix and libitron to SRCS. Apply MULTISUBDIR for picking up librtems, libposix and libitron.
2001-01-052001-01-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-4/+4
* Makefile.am: Remove subshell from *.a processing in librtemsall.a rule.
2000-11-092000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
2000-11-022000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
2000-10-312000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-3/+4
* ChangeLog: New file. * Makefile.am: Switch to GNU-canonicalized autoconf macros. * configure.in: New file. * .cvsignore: Add aclocal.m4, configure.
2000-10-182000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+1
* wrapup/Makefile.am: Added libfs.
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+1
* wrapup/Makefile.am: Include compile.am.
2000-07-26Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill1-2/+2
a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill1-12/+7
1999-12-13Patch rtems-rc-19991203-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>"""Joel Sherrill1-41/+40
which is an adaptation of a patch from Ian Lance Taylor plus a few other changes that should significantly speed up building librtemsall.a.
1999-11-23Missed in previous automake conversion patches from Ralf CorsepiusJoel Sherrill1-0/+77
<corsepiu@faw.uni-ulm.de>.
