path: root/c/src/wrapup/ChangeLog (follow)
* 2002-03-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-151-0/+6
| | | | | | * configure.ac: Special treatment of the bare BSP. Add RTEMS_BSP_ALIAS. Add HAS_LIBBSP. * Makefile.am: Append libbsp.a to SRC conditionally.
* 2002-02-28 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2002-02-281-0/+5
| | | | | * DOS filesystem including FAT12, FAT16, and FAT32 support submitted. * Makefile.am: Modified to reflect addition.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-0/+6
| | | | | | * configure.ac: Remove references to POSIX, ITRON, MULTILIB. * Makefile.ac: Remove librtems, libposix, libitron. Build librtemsbsp instead of librtemsall.
* 2001-12-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-201-0/+8
| | | | | | | | * configure.ac: Add AM_CONDITIONAL for enable_multilib, enable_posix, enable_itron. * Makefile.am: Compute MULTISUBDIR on-the-fly. Conditionally add libposix and libitron to SRCS. Apply MULTISUBDIR for picking up librtems, libposix and libitron.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-111-0/+6
* 2001-01-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-051-0/+5
| | | | | * Makefile.am: Remove subshell from *.a processing in librtemsall.a rule.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+4
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-311-0/+6
* ChangeLog: New file. * Makefile.am: Switch to GNU-canonicalized autoconf macros. * configure.in: New file. * .cvsignore: Add aclocal.m4, configure.
