and adding code which installed screens for itron tests.
with ITRON 3.0 data types regardless of how dumb it is to name
types with a simple letter.
for RTEMS.
BSP needs to be eliminated.
Disabled test of F_DUPFD since it does not work.
Added comment to indicate that seekdir(NULL) was being called.
was unnecessary. The real fix was an alignment error in the
object extend memory allocation scheme.
of space in the workspace.
removed.
the executive.
Charles-Antione Gauthier <charles.gauthier@iit.nrc.ca>.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
problem with the HAS_MP patch and regenerated files.
cd <srcdir>
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
