path: root/c/src/tests (follow)
* modified test to take into account change in default value ofJoel Sherrill1996-09-061-0/+5
| | | | | inheritsched pthread attribute from implicit to explicit scheduling parameters.
* added printf of status when not successfulJoel Sherrill1996-09-051-1/+3
* nanosleep no longer consider a negative value of tv_sec to be an error.Joel Sherrill1996-09-051-6/+7
| | | | Instead it is an indication of a request for a small delay.
* Changed all EFAULTS to EINVALsMark Johannes1996-08-231-14/+20
* filled in screenMark Johannes1996-08-231-0/+11
* Filled in screenMark Johannes1996-08-232-0/+78
* Filled in the screenMark Johannes1996-08-239-0/+479
* Added build_time statement to provide a tm for the testMark Johannes1996-08-231-2/+4
* Changed test 5 to test 10 at bottomMark Johannes1996-08-231-1/+1
* Commented out the EINVAL for mutex not acquired befor cond_wait callMark Johannes1996-08-221-4/+9
* updated to support ENOTSUPMark Johannes1996-08-211-10/+10
* Added Einval case for mutex not initializedMark Johannes1996-08-201-0/+10
* init: added tests for pthread_kill and kill errors.Mark Johannes1996-08-151-32/+186
* changed error codeJoel Sherrill1996-08-151-2/+2
* changed error for too many threads to EAGAINJoel Sherrill1996-08-151-2/+2
* pthread_mutex_init returns EAGAIN not ENOMEM when there are too many mutexes.Joel Sherrill1996-08-141-2/+2
* added test cases for NULL being passed to pthread attribute get routinesJoel Sherrill1996-08-141-0/+20
* added test case for pthread_attr_getscope being passed a NULL contentionscopeJoel Sherrill1996-08-141-0/+4
* system.h: added task3 and changed condition variable config to 1Mark Johannes1996-08-141-1/+6
* task3: added to test error case in Wait_support for lock on mutexMark Johannes1996-08-141-0/+46
* init: added error case for wait timedwait, and wait supportMark Johannes1996-08-141-8/+153
* pthread_attr_setscope: returns ENOTSUP not ENOSYS for unsupport scopeJoel Sherrill1996-08-141-2/+2
* task_2: added comments and print statement for task exitMark Johannes1996-08-131-0/+1
* task_1: added comments and print statement for task exitMark Johannes1996-08-131-0/+5
* Init.c: added timewait case, added broadcast caseMark Johannes1996-08-131-3/+28
* corrected problem in which sigtimedwait() was being invoked withJoel Sherrill1996-08-131-60/+3
| | | | | | the wrong mask. removed code which was commented out. This code was in another test.
* chenaged format of outputJoel Sherrill1996-08-131-2/+6
* added include of errno.h so the test can check for EINTR.Joel Sherrill1996-08-131-0/+1
* nanosleep now returns -1 and EINTR when a signal interrupts EINTR.Joel Sherrill1996-08-131-2/+8
* task_1: added to handle cases of waiting tasks on condition variablesMark Johannes1996-08-121-0/+60
* system.h: added protoypes for task and task2, added mutex id, and task idsMark Johannes1996-08-121-1/+10
* Init.c: added cases for signal, wait and broadcastMark Johannes1996-08-121-7/+26
* Task2: new task for broadcast caseMark Johannes1996-08-121-0/+46
* added test cases for clock_getresJoel Sherrill1996-08-121-9/+27
* added test case for stack too largeJoel Sherrill1996-08-121-0/+7
* added test cases for clock_gettime (invalid id), clock_settime (invalid_id),Joel Sherrill1996-08-121-0/+48
| | | | nanosleep (yield cpu), and numerous error cases in nanosleep
* added test case for non-NULL parameter to time()Joel Sherrill1996-08-121-0/+6
* added numerous error test cases.Joel Sherrill1996-08-122-14/+157
* Init: added pthread_cond_init with an attr non-NULL, initialized the attr againMark Johannes1996-08-121-0/+8
* Init: added prliminary phtread_cond_init and destroy cases.Mark Johannes1996-08-121-0/+9
* system.h: added condition variable #define for 10 condition variablesMark Johannes1996-08-121-0/+2
* added test cases for errors in pthread_mutexattr_getpsharedJoel Sherrill1996-08-091-1/+16
* added test cases for EINVAL cases in pthread_mutexattr_destroyJoel Sherrill1996-08-091-1/+21
* added test case for pthread_mutexattr_init being passed a null pointer.Joel Sherrill1996-08-091-0/+4
* changed style of output to match other testsJoel Sherrill1996-08-091-40/+51
* system.h: initial cvsMark Johannes1996-08-091-0/+53
* lowered maximum number of threads to 2 to make test case easier.Joel Sherrill1996-08-091-0/+3
| | | | include sched.h so test can invoke scheduler routines.
* added test case for sched_yield.Joel Sherrill1996-08-091-6/+14
| | | | changed format of some output.
* added test cases for errors in sched_get_priority_min andJoel Sherrill1996-08-091-5/+30
| | | | | | sched_get_priority_max. added test case for sched_yield.
* Init: added condattr - destroy, init, set and get casesMark Johannes1996-08-091-5/+6
